Strange Process Running
Discussion in 'Legacy Windows' started by JimmyB, 2002/04/25.
  1. 2002/04/25
    JimmyB
    JimmyB Inactive Thread Starter
    Anyone heard of Winkuv.exe?
    This process seems to be using almost 50% of the CPU time and 2,460k of memory. It also runs in cycles, slamming the CPU usage to 100% for a second or so then turning itself off. -?
    I cannot end this process.
    Help?
    Thanks-Jimmy
  2. 2002/04/25
    Daizy
    Daizy Inactive
    Hi JimmyB
    I've not only not heard of it, I can't pull up any kind of search on it. Are you sure you have the spelling right?
    You can get a form of msconfig here perhaps? And see if you can stop it from loading at start up?
    Daizy
    Zephyr
    Zephyr Inactive
