STOP Error #2: DRIVER_IRQL_NOT_LESS_OR_EQUAL
Discussion in 'Windows XP' started by Dave932932, 2006/07/25.
  1. 2006/07/25
    Dave932932
    Dave932932 Inactive Thread Starter
    "A problem has been detected and Windows has been shut down to prevent further damage to your computer.
    If this is the first time you've seen this STOP error screen, restart your computer. If this screen appears again, follow these steps:
    Check to make sure any new hardware or softwareis properly installed. If this is a new installation, ask your hardware or software manufacturer for any Windows updates you might need.
    If problems continue, disable or remove and newly installed hardware or software. Disable BIOS memory options such as caching or shadowing. If you need to use Safe Mode to remove or disable components, restart your computer, press F8 to select Advanced Startup options, and then the select Safe Mode.
    Technical Information:
    ***STOP: 0x000000D1 (0x00000034, 0x00000002, 0x00000000, 0xF83BA8F0)
    ***IdeChnDr.sys Address F83BA8F0 base at F83B5000, Date Stamp 3d99eac3
    Beginning dump of physical memory
    Physical memory dump complete.
    Contact your system administrator or techincal support group for further assistance. "
  2. 2006/07/25
    IdeChnDr.sys is all/part of the Intel Application Accelerator Driver - see here
    Check that the file is in the location stated and is of the size quoted. This will establish if malware is involved - I rather think not.
    0x000000D1: DRIVER_IRQL_NOT_LESS_OR_EQUAL
    Several troubleshooting suggestions there, but reloading/updating the Intel software may resolve the problem.
    I would test your memory using Windows Memory Diagnostic Tool or Memtest
