Startup Lines? Logon UI Boot Randomiser problem,
Discussion in 'Windows XP' started by Nic99, 2004/11/24.
  1. 2004/11/24
    Nic99
    Nic99 Inactive Thread Starter
    Hi all,
    Recently I tried to uninstall the above program, because it was not needed anymore. But the way this program works, is it puts a "new line" in the startup value of the registry code. (I think)
    For instance after you install this program, the next time you reboot, the computer asks you weather you want to start using the new startup code, or the old original.
    I proceeded to uninstall it, & when it was done, I thought everything was ok.
    So, the problem is this, on the next reboot I realised that the uninstallation had not uninstalled the startup code, so I still have two options when ever I reboot.
    Now I need to know how to get rid of the new (not original) startup code.
    Thanks.
  2. 2004/11/24
    Probably need to edit the boot.ini file which is a "hidden" file. See the attached picture.
    Nic99
    Thanks for the advice, you fixed it for me. :)
