Start Up Freezing
Discussion in 'Windows XP' started by bmartin, 2009/06/09.
  1. 2009/06/09
    bmartin
    bmartin Well-Known Member Thread Starter
    My computer is freezing on startup. It as done this before, but I have always got around it by unplugging and replugging the power cord to the computer, but now this trick no longer works. Here's what I know.
    1. The first thing I attempted was to boot from my CD. I went into to setup and only found the hard drive and floppy drive, no CD drive was shown. This missing CD drive makes me wonder if this may be the problem. How do I get setup to see my CD Drive maybe a cable problem?
    2. I have tried to start the computer in every mode available, safe mode, last configuration known, recovery, etc. No matter what I try the computer seems to freeze at the same point.
    The computer appears to be looking for something that it can't find. Could it be hardware related?
  2. 2009/06/09
    I would not think that a faulty CD-ROM drive would freeze the computer, but stranger things have happened in Windows :)
    Disconnect the CD-ROM drive - remove both the power lead and the ribbon cable - try to boot. If the boot is successful you have the answer!
    If not the first step is to determine why the CD-ROM drive is not recognised - it may have failed. When attempting to boot does the light on the drive flash? If it does it is getting power, if not no power. Try another power feed from the PSU. If it powers up it may be a problem with the ribbon cable - reseat at each end - if no joy try another cable.
    If still no success two possibilities - the drive is dead or the PSU has a problem - may be related to
    Without a CD-ROM drive you are stuck.
    Get the drive sorted and we can proceed further.
    bmartin
    Thanks for the response. It was just as I suspected. Right after I posted this message I removed the case and disconnected the cable from the CD drive and the computer started right up. I could tell something wasn't responsing and when I didn't see the CD drive in my setup with the other drive I got very suspicious. The CD Drive is getting power so I suspected a bad cable of maybe the CD Drive. I will replace the cable first. I should have another cable laying around here somewhere
  5. 2009/06/09
    Ah well, live and learn :) Glad to hear you pinpointed the problem.
