Standby issue
Discussion in 'Windows XP' started by rodger, 2003/12/19.
  1. 2003/12/19
    rodger
    rodger Inactive Thread Starter
    running windows xp home inc service p1a
    and just bought a multi media keyboard installed and all seems to be working well except when I use the sleep button the pc goes into standby and a move of the mouse appears to make the system come back to life but only have background desktop no icons are visable mouse is visable but no keyboard instructions
    except the only way out is to reboot and then get a message saying system has recovered from a serious error and all else seems ok has anyone else had this is there a hot fix for this ?
    Rodger...
  2. 2003/12/20
    goddez1
    goddez1 Inactive
    Perhaps something here:
    http://www.kellys-korner-xp.com/xp_standby.htm
    I would look at your new keyboard and check for a hibernation/sleep problem, updated drivers/patch.
    Power management can be and has been a real bugger. I would turn these features off until I figured out what the problem is. Data loss and corrupted files are a real danger while this is going on. Cached read/write tasks (those that windows does during idle time or at shutdown/restarts) are also suspended and not written to disk. Foul ups on wakeups causes the lose of this data.
    rodger
    Hi thanks for reply I have sorted the problem now it was down to the hard drive when I installed it I had it as a slave and forgot to put it back as the primary once I changed this all now works well
    Regards rodger
  5. 2003/12/21
    goddez1
    goddez1 Inactive
    Hi rodger,
    Well, that would have taken a crystal ball and some tarrot cards. I'm glad you took the time to share it. This would definitely fall into the category of "uncommon and rare reason ".
    I know somewhere down the line it will help another who finds themselves trying to figure out why they are having the same sleep /wake problem.
    Again, thank you for the update. :D
  6. 2003/12/23
    rodger
    Merry Christmas Ann
    Rodger.......:p
