SSD/Regular Drive hybrid idea
Discussion in 'PC Hardware' started by melchior, 2009/04/02.
  1. 2009/04/02
    melchior
    melchior Inactive Thread Starter
    Hi, my name's Mel and this is my first post.
    I joined because I had an idea about building a machine with two drives: a smaller solid state device (32gb) for the operating system, and a second conventional drive. The idea is to put the page file and event log on the conventional drive to bypass the write-endurance problem of flash memory.
    1) Has anyone done something like this before? Any opinions/input?
    2) What else besides the page and event log are frequently written to, in windows xp?
    3) any other ideas on how to minimize writes? Should I turn off system restore since I can't move that to a separate drive?
  2. 2009/04/02
    temp dirs
    Not done it, but researched it & rejected it. SSD drives are no good (except the expensive Intel drives). I choose to go with SAS instead.
    YusufTech
    YusufTech Inactive
    thanks
  6. 2009/04/03
    Lukeno1
    Lukeno1 Well-Known Member
    As far as I'm concerned, solid-state drives are far too expensive at present - and small. For the price of a 32 GB solid-state drive, you could get a 1 TB hard drive easily, with change!
    What would the advantage of a SSD be in a normal desktop anyway? I can see it in a laptop on a very bumpy road, but otherwise...
