speed test
Discussion in 'General Internet' started by flamshlo, 2012/02/28.
  1. 2012/02/28
    flamshlo
    flamshlo Inactive Thread Starter
    xp.
    my server set for 15 mbps. when i check the speed i get 6-7 mbps.
    if i turn on the procmon i get the full 15 mbps. it is as if the procmon is suppressing some hidden application.
    i verified this using netlimiter
  2. 2012/02/28
    What server?
    flamshlo
    bezeqint.net (in israel)
  5. 2012/02/28
    I don't believe you mean "server ".
    I think you mean "Internet speed of your ISP." Correct?
  6. 2012/02/29
    flamshlo
    you are quite right.
    since my last entering the problem i tweaked my computer which was sitting at 8mbps setting.
    today i retested the speed and came up with the following results for 4 runs:
    without procmon: 11.52 mbs and 9.33 mbs (
    with procmon running: 15.75 mbs and 15.92 mbs
    the site i use for testing is: http://speedtest.bezeq.co.il/index.html
  7. 2012/03/01
    flamshlo
    i finally solved my problem. i downloaded a tweaktester from:
    Admin: deleted URL, bad site see: http://www.mywot.com/en/scorecard/3d2f.com
    the program is DSL SPEED 7.1.
    after tweaking my computer, for 2 runs i got:
    without procmon: 14.85 mbps and 15.04 mbps (which suits me fine)
    with procmon: 15.75 mbps and 15.54 mbps (slightly higher but who cares)
    thanks for your help
  8. 2012/03/02
    flamshlo
    i noticed you deleted the site for the tweaker. be that it may, today i again checked my speed and lo and behold i am back to my original problem of 6.5 mbps. i again tried the tweaker but to no avail. i am back at square 1. help!
    i didn't get a chance to indicate that my problem was resolved. how do i do that (for the future)?
  9. 2012/03/03
    SpywareDr
    Click the Thread Tools link on the right end of the bar above the first post and a menu will drop down showing you some options. If you created the Thread, one of those options will be "Mark Thread Resolved ".
    Note that the options that do show will vary from site to site.
  10. 2012/03/03
    The email notification you receive when there's a reply to your thread start with this information:
