Sound over HDMI
Discussion in 'Windows 11' started by boutells, 2024/10/21.
Tags:
  1. 2024/10/21
    boutells
    boutells Well-Known Member Thread Starter
    I have a new computer and am having a problem getting sound through the HDMI connection. I don't think it is a faulty port as I get sound sometimes and the video is fine.
    I sometimes get it and then it drops, sometimes when it drops I can get it back if I switch to mono sound but not always.
    Last night I did a "Fix without resetting" and it was working after that but now it is struggling again.
    The sound is functioning properly through the 3.5mm port and via Bluetooth.
    Any ideas?
  2. 2024/10/21
    Have you tried a different cable?
    boutells
    Yes, several.
  5. 2024/10/21
    Have you tried contacting the manufacturer if it is a new computer?
  6. 2024/10/21
    boutells
    Yes. No joy. Cheap computer and a small outfit in China.
  7. 2024/10/23
    Hi, What Brand of motherboard is in the comp?
    What shows up in Device Manager?
    Do you need a sound card added?
  8. 2024/10/28
    Hi boutells, Have you fixed your problem?o_O
  9. 2024/10/29
    boutells
    No. Apparently a one off problem.
    I suspect only a reset may solve it but that's a hassle and no guarantee of success.
  10. 2024/10/30
    If you no longer wish to get help, please mark this as Resolved.
  11. 2024/11/09
    boutells
    For the time being at least, this seems to have corrected itself but I haven't a clue how. However, it seems to get disengaged when the Bluetooth Speaker is connected and re-engages when it is not. Keeping an eye on it for a bit before I mark this as solved but does anyone know why a Bluetooth connection might interfere with and HDMI connection?
  12. 2024/11/11
    boutells
    Nope. That didn't work either. If I reboot, then I get sound over the HDMI connection but after a while, it disappears. This is after removing the Bluetooth pairing completely.
    the 3.5mm connection is working.
  13. 2024/11/12
    This may in fact be your complete answer!:oops::eek:
