Resolved Some websites work fine others won't load or are slow to load
Discussion in 'General Internet' started by Nanou, 2010/03/26.
  1. 2010/03/26
    Nanou
    Nanou Inactive Thread Starter
    I tried to search this but due to this problem it is impossible. Sorry!
    I am using Windows XP and usually Internet Explorer 8 but problem is also with firefox. It is also effecting both home computers, one is plug directly into the router and the other is wireless. I have tried turning off Zone Alarm but no help. Internet connectivity is good, downloading is not a problem if you can load the site to find something to download!
    So again, some sites seem to work perfectly, some won't load at all just sits there like it's trying but doesn't work and others if you refresh enough times (like this one) it will eventually go. HELP!! PLEASE!! I am going crazy!!
  2. 2010/03/26
    Do you have AVG installed as well?
    Nanou
    Yes I do....Could that be it?
  5. 2010/03/26
    Nanou
    Yes it did!!!! THANK YOU!!! I hope it was just that version of it. I have never had a problem before!
  7. 2010/03/26
    Nanou
    Thank you Broni! I will try one of those out! I really appreciate it! :D
  9. 2010/03/26
    You're very welcome :)
