Some web pages will not load. WHY?
Discussion in 'General Internet' started by EL CONJUNTO, 2007/08/30.
  1. 2007/08/30
    EL CONJUNTO
    EL CONJUNTO Well-Known Member Thread Starter
    This seems to be getting worse! Some very common web sites (like Google) will no longer load. All others have no problem. Did basic adware/spyware and virus scans...nothing found. I looked for any blocked Url's...none. She is using XP home with IE7. I loaded Firefox and have the exact same problems! I shut off the firewalls and chose a minimal startup...no help. Any Clues?
  2. 2007/08/30
    surferdude2
    surferdude2 Inactive
    It sounds like a DNS resolution problem with her ISP.
    Try this for a fix. It's a simple change and can work wonders.
    You can also use this to cut directly to the XP instructions:
    Direct link to instructions for XP
    EL CONJUNTO
    Thanks, that is a good site. The computer is better "(google now loads), but other sites like any Time Warner cable site (The ISP) still will not load. Any ideas?
  5. 2007/08/31
    surferdude2
    That would be an ISP problem so give their customer service department a shot at it.
  6. 2007/09/04
    EL CONJUNTO
    Everythings fine now. There were several routers connected (like for Vonage) and a complete reboot of all of them did the trick.
