Smithfraud, generic3 & other problems!!!
Discussion in 'Malware and Virus Removal Archive' started by CidHawg, 2007/03/14.
  1. 2007/03/14
    CidHawg
    CidHawg Inactive Thread Starter
    I need assistance with removing several unwanted things, including some rougue bogus security protection. "asecureguide.com" I think is the rougue security program. Also, in my add/remove programs there is an internet security add-on that I'm not sure that needs to be there.
  2. 2007/03/14
    TeMerc
    TeMerc Inactive Alumni
    Hello and welcome to WindowsBBS Removing Spyware & Viruses forum.
    Here is how we like to begin our analysis of your pc:
    For starters, if you do not have them yet, please DL and run AdAware & Spybot Search & Destroy. AdAware and Spybot Search & Destroy are 2 of the most trusted apps in the security area. They are both free, compliment each other nicely, and do not use a lot of resources. They can be found here:
    Spybot Search & Destroy v.1.4
    AdAware SE Free v1.06r
    With AdAware and Spybot: DL, follow the install instructions, check for updates, then scan, repair/remove/quarantine anything found. Reboot before next scan with whichever app is next. The reason for running these apps, is to clean up some of the other 'crapware' on your pc, which, in turn, will make deciphering your HJT log, easier.
    Then we use HiJackThis v1.99.1
    Please download HijackThis! SetUp from here. Save the file to your desktop.
    Double-click the HijackThis! SetUp icon to begin the installation. Follow the prompts for the default install location of:'C:\Program Files\HijackThis'. Tick the 'Create a desktop' button when the option appears. Select next, then allow HijackThis! to start.
    Then press the [Scan] button. You will notice the [Scan] button will turn into a [Save Log] button. Click the [Save Log] button and notepad will open up with the contents of the scan. Right-click in the saved log, and select 'copy'. Then proceed to your original thread, unless otherwise instructed and click the '[Reply]' button and paste the saved contents to be reviewed. Do not make any modifications to the log or perform any 'fixes' until told to do so.
    Someone will be along to look at your log soon as possible, we appreciate your patience. Remember, we are ALL VOLUNTEERS, those of us who help. And we do the best we can to answer posts as soon as we can. Logs are generally looked at in the order in which they are posted.
    TeMerc
    I didn't notice that you had a second thread, is this for the same machine or a different one?
    If it is the same machine, I will lock this topic, no need for a new topic for the same machine.
  5. 2007/03/14
    CidHawg
    I have run both AdAware and Spybot. It seems that Spybot could not repair everything. I have also run an AVG virus scan. Here is my HJT:
    Logfile of HijackThis v1.99.1
    Scan saved at 8:50:23 PM, on 3/14/2007
    MSIE: Internet Explorer v7.00 (7.00.6000.16414)
    C:\PROGRA~1\Grisoft\AVGFRE~1\avgamsvr.exe
    C:\PROGRA~1\Grisoft\AVGFRE~1\avgupsvc.exe
    C:\PROGRA~1\Grisoft\AVGFRE~1\avgemc.exe
    C:\WINDOWS\system32\hkcmd.exe
    C:\WINDOWS\system32\igfxpers.exe
    C:\Program Files\Analog Devices\Core\smax4pnp.exe
    C:\Program Files\CyberLink\PowerDVD\DVDLauncher.exe
    C:\PROGRA~1\Grisoft\AVGFRE~1\avgcc.exe
    C:\Program Files\Winamp\winampa.exe
    C:\WINDOWS\system32\cmd.exe
    C:\WINDOWS\NOTEPAD.EXE
    C:\Program Files\Hijackthis\killer.exe.exe
    R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Window Title = Microsoft Internet Explorer provided by CenturyTel
    O2 - BHO: Adobe PDF Reader Link Helper - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Common Files\Adobe\Acrobat\ActiveX\AcroIEHelper.dll
    O2 - BHO: (no name) - {53707962-6F74-2D53-2644-206D7942484F} - C:\Program Files\Spybot - Search & Destroy\SDHelper.dll
    O2 - BHO: (no name) - {A6ACAE64-F798-4930-AD86-BD3FB32038DB} - C:\Program Files\Video Access ActiveX Object\isadd.dll
    O4 - HKLM\..\Run: [IgfxTray] C:\WINDOWS\system32\igfxtray.exe
    O4 - HKLM\..\Run: [HotKeysCmds] C:\WINDOWS\system32\hkcmd.exe
    O4 - HKLM\..\Run: [Persistence] C:\WINDOWS\system32\igfxpers.exe
    O4 - HKLM\..\Run: [SoundMAXPnP] C:\Program Files\Analog Devices\Core\smax4pnp.exe
    O4 - HKLM\..\Run: [DVDLauncher] "C:\Program Files\CyberLink\PowerDVD\DVDLauncher.exe "
    O4 - HKLM\..\Run: [AVG7_CC] C:\PROGRA~1\Grisoft\AVGFRE~1\avgcc.exe /STARTUP
    O4 - HKLM\..\Run: [WinampAgent] C:\Program Files\Winamp\winampa.exe
    O4 - HKCU\..\Run: [MSMSGS] "C:\Program Files\Messenger\msmsgs.exe" /background
    O4 - Global Startup: Adobe Reader Speed Launch.lnk = C:\Program Files\Adobe\Reader 8.0\Reader\reader_sl.exe
    O4 - Global Startup: Adobe Reader Synchronizer.lnk = C:\Program Files\Adobe\Reader 8.0\Reader\AdobeCollabSync.exe
    O4 - Global Startup: Microsoft Office.lnk = C:\Program Files\Microsoft Office\Office10\OSA.EXE
    O9 - Extra button: (no name) - {e2e2dd38-d088-4134-82b7-f2ba38496583} - %windir%\Network Diagnostic\xpnetdiag.exe (file missing)
    O9 - Extra 'Tools' menuitem: @xpsp3res.dll,-20001 - {e2e2dd38-d088-4134-82b7-f2ba38496583} - %windir%\Network Diagnostic\xpnetdiag.exe (file missing)
    O11 - Options group: [INTERNATIONAL] International*
    O16 - DPF: {5ED80217-570B-4DA9-BF44-BE107C0EC166} (Windows Live Safety Center Base Module) - http://cdn.scan.onecare.live.com/resource/download/scanner/wlscbase9602.cab
    O16 - DPF: {6414512B-B978-451D-A0D8-FCFDF33E833C} (WUWebControl Class) - http://update.microsoft.com/windowsupdate/v6/V5Controls/en/x86/client/wuweb_site.cab?1161272375375
    O16 - DPF: {6E32070A-766D-4EE6-879C-DC1FA91D2FC3} (MUWebControl Class) - http://update.microsoft.com/microsoftupdate/v6/V5Controls/en/x86/client/muweb_site.cab?1162605523229
    O16 - DPF: {DCDC28C5-831C-43EA-9C02-78872CCCA409} (VPlayer Control) - http://thesecret.tv/movie/player/vivid_ocx.jpeg
    O16 - DPF: {E7DBFB6C-113A-47CF-B278-F5C6AF4DE1BD} - http://download.abacast.com/download/files/abasetup162.cab
    O21 - SSODL: WPDShServiceObj - {AAA288BA-9A4C-45B0-95D7-94D524869DB5} - C:\WINDOWS\system32\WPDShServiceObj.dll
    O23 - Service: AVG7 Alert Manager Server (Avg7Alrt) - GRISOFT, s.r.o. - C:\PROGRA~1\Grisoft\AVGFRE~1\avgamsvr.exe
    O23 - Service: AVG7 Update Service (Avg7UpdSvc) - GRISOFT, s.r.o. - C:\PROGRA~1\Grisoft\AVGFRE~1\avgupsvc.exe
    O23 - Service: AVG E-mail Scanner (AVGEMS) - GRISOFT, s.r.o. - C:\PROGRA~1\Grisoft\AVGFRE~1\avgemc.exe
  6. 2007/03/14
    CidHawg
    Here are the results of a smithfraud:
    SmitFraudFix v2.148
    Scan done at 20:58:42.40, Wed 03/14/2007
    Run from C:\Documents and Settings\Owner\Desktop\SmitfraudFix
    OS: Microsoft Windows XP [Version 5.1.2600] - Windows_NT
    The filesystem type is NTFS
    Fix run in normal mode
    »»»»»»»»»»»»»»»»»»»»»»»» hosts
    »»»»»»»»»»»»»»»»»»»»»»»» C:\
    »»»»»»»»»»»»»»»»»»»»»»»» C:\WINDOWS
    »»»»»»»»»»»»»»»»»»»»»»»» C:\WINDOWS\system
    »»»»»»»»»»»»»»»»»»»»»»»» C:\WINDOWS\Web
    »»»»»»»»»»»»»»»»»»»»»»»» C:\WINDOWS\system32
    »»»»»»»»»»»»»»»»»»»»»»»» C:\WINDOWS\system32\LogFiles
    »»»»»»»»»»»»»»»»»»»»»»»» C:\Documents and Settings\Owner
    »»»»»»»»»»»»»»»»»»»»»»»» C:\Documents and Settings\Owner\Application Data
    »»»»»»»»»»»»»»»»»»»»»»»» Start Menu
    »»»»»»»»»»»»»»»»»»»»»»»» C:\DOCUME~1\Owner\FAVORI~1
    C:\DOCUME~1\Owner\FAVORI~1\Online Security Test.url FOUND !
    »»»»»»»»»»»»»»»»»»»»»»»» Desktop
    »»»»»»»»»»»»»»»»»»»»»»»» C:\Program Files
    C:\Program Files\Video Access ActiveX Object\ FOUND !
    »»»»»»»»»»»»»»»»»»»»»»»» Corrupted keys
    »»»»»»»»»»»»»»»»»»»»»»»» Desktop Components
    [HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\Desktop\Components\0]
    "Source "= "About:Home "
    "SubscribedURL "= "About:Home "
    "FriendlyName "= "My Current Home Page "
    »»»»»»»»»»»»»»»»»»»»»»»» Sharedtaskscheduler
    !!!Attention, following keys are not inevitably infected!!!
    SrchSTS.exe by S!Ri
    Search SharedTaskScheduler's .dll
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\SharedTaskScheduler]
    "{aed6f6a3-183c-488d-9f90-23db99f56e7f} "= "apathies "
    [HKEY_CLASSES_ROOT\CLSID\{aed6f6a3-183c-488d-9f90-23db99f56e7f}\InProcServer32]
    @= "C:\WINDOWS\system32\geplxss.dll "
    [HKEY_LOCAL_MACHINE\Software\Classes\CLSID\{aed6f6a3-183c-488d-9f90-23db99f56e7f}\InProcServer32]
    »»»»»»»»»»»»»»»»»»»»»»»» AppInit_DLLs
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Windows]
    "AppInit_DLLs "=" "
    »»»»»»»»»»»»»»»»»»»»»»»» Winlogon.System
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon]
    "System "=" "
    »»»»»»»»»»»»»»»»»»»»»»»» pe386-msguard-lzx32-huy32
    »»»»»»»»»»»»»»»»»»»»»»»» Scanning wininet.dll infection
    »»»»»»»»»»»»»»»»»»»»»»»» End
  7. 2007/03/14
    Geri Lifetime Subscription
    Geri Inactive Alumni
    Hi Tom
    Please lock this thread.
    Geri
    Geri,
    #6
  8. 2007/03/14
    TeMerc
    Done
