Resolved Smart doctor and BSOD
Discussion in 'Windows 7' started by TCHAPAIEV, 2013/02/25.
  1. 2013/02/25
    TCHAPAIEV Lifetime Subscription
    TCHAPAIEV Well-Known Member Thread Starter
    Since several days I have BSO from time to time completely random ; usually not during a session only when the PC is still stand ;the event observer telles me that the error stems out the EIO. sys driver which apperas to be related to Asus Smart Doctor installed and working ; what should I do ? any clue ( uninstall Smart doctor and see what is happening ? ) Thnaks in advance
  2. 2013/02/25
    Thank you very much for your reply ; I got the following error upon installing along instructions (log joined ) ; any clue on what I should do next?
    === Logging started: 04/03/2013 07:49:11 ===
    Action start 07:49:11: INSTALL.
    Action start 07:49:11: DDSE_CA_Uninstall_InstallExecuteSequenceStarts_amd64.
    03/04/13 07:49:12 DDSet_Status: LANGID: 1033
    03/04/13 07:49:12 DDSet_Entry: ImmediateDispatch: DDSE_CA_Uninstall_InstallExecuteSequenceStarts entry
    03/04/13 07:49:12 DDSet_Error: Patch Hooks: Missing required property 'ProductFamily': Setup cannot continue.
    03/04/13 07:49:12 DDSet_Warning: Setup failed while calling 'getDLLName'. System error: 0xb7
    03/04/13 07:49:13 DDSet_CARetVal: 0
    03/04/13 07:49:13 DDSet_Exit: ImmediateDispatch: DDSE_CA_Uninstall_InstallExecuteSequenceStarts exit
    Action ended 07:49:13: DDSE_CA_Uninstall_InstallExecuteSequenceStarts_amd64. Return value 1.
    Action start 07:49:13: FindRelatedProducts.
    Action ended 07:49:13: FindRelatedProducts. Return value 0.
    Action start 07:49:13: AppSearch.
    Action ended 07:49:13: AppSearch. Return value 0.
    Action start 07:49:13: LaunchConditions.
    Action ended 07:49:13: LaunchConditions. Return value 1.
    Action start 07:49:13: ValidateProductID.
    Action ended 07:49:13: ValidateProductID. Return value 1.
    Action start 07:49:13: DDSE_CA_Uninstall_CostInitializePre_amd64.
    03/04/13 07:49:13 DDSet_Status: LANGID: 1033
    03/04/13 07:49:13 DDSet_Entry: ImmediateDispatch: DDSE_CA_Uninstall_CostInitializePre entry
    03/04/13 07:49:13 DDSet_Error: Patch Hooks: Missing required property 'ProductFamily': Setup cannot continue.
    03/04/13 07:49:13 DDSet_Warning: Setup failed while calling 'getDLLName'. System error: 0xb7
    03/04/13 07:49:13 DDSet_Exit: ImmediateDispatch: DDSE_CA_Uninstall_CostInitializePre exit
    Action ended 07:49:13: DDSE_CA_Uninstall_CostInitializePre_amd64. Return value 1.
    Action start 07:49:13: CostInitialize.
    Action ended 07:49:13: CostInitialize. Return value 1.
    Action start 07:49:13: DDSE_CA_Uninstall_CostInitializePost_amd64.
    03/04/13 07:49:14 DDSet_Status: LANGID: 1033
    03/04/13 07:49:14 DDSet_Entry: ImmediateDispatch: DDSE_CA_Uninstall_CostInitializePost entry
    03/04/13 07:49:14 DDSet_Error: Patch Hooks: Missing required property 'ProductFamily': Setup cannot continue.
    03/04/13 07:49:14 DDSet_Warning: Setup failed while calling 'getDLLName'. System error: 0xb7
    03/04/13 07:49:14 DDSet_CARetVal: 0
    03/04/13 07:49:14 DDSet_Exit: ImmediateDispatch: DDSE_CA_Uninstall_CostInitializePost exit
    Action ended 07:49:15: DDSE_CA_Uninstall_CostInitializePost_amd64. Return value 1.
    Action start 07:49:15: FileCost.
    Action ended 07:49:15: FileCost. Return value 1.
    Action start 07:49:15: DDSE_CA_Uninstall_CostFinalizePre_amd64.
    03/04/13 07:49:15 DDSet_Status: LANGID: 1033
    03/04/13 07:49:15 DDSet_Entry: ImmediateDispatch: DDSE_CA_Uninstall_CostFinalizePre entry
    03/04/13 07:49:15 DDSet_Error: Patch Hooks: Missing required property 'ProductFamily': Setup cannot continue.
    03/04/13 07:49:15 DDSet_Warning: Setup failed while calling 'getDLLName'. System error: 0xb7
    03/04/13 07:49:15 DDSet_CARetVal: 0
    03/04/13 07:49:15 DDSet_Exit: ImmediateDispatch: DDSE_CA_Uninstall_CostFinalizePre exit
    Action ended 07:49:15: DDSE_CA_Uninstall_CostFinalizePre_amd64. Return value 1.
    Action start 07:49:15: CostFinalize.
    Action ended 07:49:15: CostFinalize. Return value 1.
    Action start 07:49:15: DDSE_CA_Uninstall_CostFinalizePost_amd64.
    03/04/13 07:49:16 DDSet_Status: LANGID: 1033
    03/04/13 07:49:16 DDSet_Entry: ImmediateDispatch: DDSE_CA_Uninstall_CostFinalizePost entry
    03/04/13 07:49:16 DDSet_Error: Patch Hooks: Missing required property 'ProductFamily': Setup cannot continue.
    03/04/13 07:49:16 DDSet_Warning: Setup failed while calling 'getDLLName'. System error: 0xb7
    03/04/13 07:49:16 DDSet_CARetVal: 0
    03/04/13 07:49:16 DDSet_Exit: ImmediateDispatch: DDSE_CA_Uninstall_CostFinalizePost exit
    Action ended 07:49:16: DDSE_CA_Uninstall_CostFinalizePost_amd64. Return value 1.
    Action start 07:49:16: SetODBCFolders.
    Action ended 07:49:16: SetODBCFolders. Return value 0.
    Action start 07:49:16: MigrateFeatureStates.
    Action ended 07:49:16: MigrateFeatureStates. Return value 0.
    Action start 07:49:16: DDSE_CA_Uninstall_InstallValidatePre_amd64.
    03/04/13 07:49:16 DDSet_Entry: ImmediateDispatch: DDSE_CA_Uninstall_InstallValidatePre entry
    03/04/13 07:49:16 DDSet_Exit: ImmediateDispatch: DDSE_CA_Uninstall_InstallValidatePre exit
    Action ended 07:49:16: DDSE_CA_Uninstall_InstallValidatePre_amd64. Return value 1.
    Action start 07:49:16: InstallValidate.
    Action ended 07:49:16: InstallValidate. Return value 1.
    Action start 07:49:16: DDSE_CA_Uninstall_InstallValidatePost_amd64.
    03/04/13 07:49:16 DDSet_Entry: ImmediateDispatch: DDSE_CA_Uninstall_InstallValidatePost entry
    03/04/13 07:49:16 DDSet_Exit: ImmediateDispatch: DDSE_CA_Uninstall_InstallValidatePost exit
    Action ended 07:49:16: DDSE_CA_Uninstall_InstallValidatePost_amd64. Return value 1.
    Action start 07:49:16: RemoveExistingProducts.
    Action ended 07:49:16: RemoveExistingProducts. Return value 0.
    Action start 07:49:16: DDSE_CA_Uninstall_InstallInitializePre_amd64.
    03/04/13 07:49:17 DDSet_Status: LANGID: 1033
    03/04/13 07:49:17 DDSet_Entry: ImmediateDispatch: DDSE_CA_Uninstall_InstallInitializePre entry
    03/04/13 07:49:17 DDSet_Error: Patch Hooks: Missing required property 'ProductFamily': Setup cannot continue.
    03/04/13 07:49:17 DDSet_Warning: Setup failed while calling 'getDLLName'. System error: 0xb7
    03/04/13 07:49:17 DDSet_CARetVal: 0
    03/04/13 07:49:17 DDSet_Exit: ImmediateDispatch: DDSE_CA_Uninstall_InstallInitializePre exit
    Action ended 07:49:17: DDSE_CA_Uninstall_InstallInitializePre_amd64. Return value 1.
    Action start 07:49:17: InstallInitialize.
    Action ended 07:49:18: InstallInitialize. Return value 1.
    Action start 07:49:18: DDSE_CA_Uninstall_InstallInitializePost_amd64.
    03/04/13 07:49:18 DDSet_Status: LANGID: 1033
    03/04/13 07:49:18 DDSet_Entry: ImmediateDispatch: DDSE_CA_Uninstall_InstallInitializePost entry
    03/04/13 07:49:18 DDSet_Error: Patch Hooks: Missing required property 'ProductFamily': Setup cannot continue.
    03/04/13 07:49:18 DDSet_Warning: Setup failed while calling 'getDLLName'. System error: 0xb7
    03/04/13 07:49:19 DDSet_CARetVal: 0
    03/04/13 07:49:19 DDSet_Exit: ImmediateDispatch: DDSE_CA_Uninstall_InstallInitializePost exit
    Action ended 07:49:19: DDSE_CA_Uninstall_InstallInitializePost_amd64. Return value 1.
    Action start 07:49:19: ProcessComponents.
    Action ended 07:49:19: ProcessComponents. Return value 1.
    Action start 07:49:19: MsiUnpublishAssemblies.
    Action ended 07:49:19: MsiUnpublishAssemblies. Return value 1.
    Action start 07:49:19: UnpublishComponents.
    Action ended 07:49:19: UnpublishComponents. Return value 0.
    Action start 07:49:19: UnpublishFeatures.
    Action ended 07:49:19: UnpublishFeatures. Return value 1.
    Action start 07:49:19: StopServices.
    Action ended 07:49:19: StopServices. Return value 1.
    Action start 07:49:19: DeleteServices.
    Action ended 07:49:19: DeleteServices. Return value 1.
    Action start 07:49:19: UnregisterComPlus.
    Action ended 07:49:19: UnregisterComPlus. Return value 0.
    Action start 07:49:19: SelfUnregModules.
    Action ended 07:49:19: SelfUnregModules. Return value 1.
    Action start 07:49:19: UnregisterTypeLibraries.
    Action ended 07:49:19: UnregisterTypeLibraries. Return value 0.
    Action start 07:49:19: RemoveODBC.
    Action ended 07:49:19: RemoveODBC. Return value 1.
    Action start 07:49:19: UnregisterFonts.
    Action ended 07:49:19: UnregisterFonts. Return value 1.
    Action start 07:49:19: RemoveRegistryValues.
    Action ended 07:49:19: RemoveRegistryValues. Return value 1.
    Action start 07:49:19: UnregisterClassInfo.
    Action ended 07:49:19: UnregisterClassInfo. Return value 0.
    Action start 07:49:19: UnregisterExtensionInfo.
    Action ended 07:49:19: UnregisterExtensionInfo. Return value 0.
    Action start 07:49:20: UnregisterProgIdInfo.
    Action ended 07:49:20: UnregisterProgIdInfo. Return value 0.
    Action start 07:49:20: UnregisterMIMEInfo.
    Action ended 07:49:20: UnregisterMIMEInfo. Return value 0.
    Action start 07:49:20: RemoveIniValues.
    Action ended 07:49:20: RemoveIniValues. Return value 1.
    Action start 07:49:20: RemoveShortcuts.
    Action ended 07:49:20: RemoveShortcuts. Return value 1.
    Action start 07:49:20: RemoveEnvironmentStrings.
    Action ended 07:49:20: RemoveEnvironmentStrings. Return value 1.
    Action start 07:49:20: RemoveDuplicateFiles.
    Action ended 07:49:20: RemoveDuplicateFiles. Return value 1.
    Action start 07:49:20: RemoveFiles.
    Action ended 07:49:20: RemoveFiles. Return value 0.
    Action start 07:49:20: RemoveFolders.
    Action ended 07:49:20: RemoveFolders. Return value 1.
    Action start 07:49:20: CreateFolders.
    Action ended 07:49:20: CreateFolders. Return value 1.
    Action start 07:49:20: MoveFiles.
    Action ended 07:49:20: MoveFiles. Return value 1.
    Action start 07:49:20: InstallFiles.
    Action ended 07:49:20: InstallFiles. Return value 1.
    Action start 07:49:20: PatchFiles.
    Action ended 07:49:20: PatchFiles. Return value 0.
    Action start 07:49:20: DuplicateFiles.
    Action ended 07:49:20: DuplicateFiles. Return value 1.
    Action start 07:49:20: BindImage.
    Action ended 07:49:20: BindImage. Return value 1.
    Action start 07:49:20: CreateShortcuts.
    Action ended 07:49:20: CreateShortcuts. Return value 1.
    Action start 07:49:21: RegisterClassInfo.
    Action ended 07:49:21: RegisterClassInfo. Return value 0.
    Action start 07:49:21: RegisterExtensionInfo.
    Action ended 07:49:21: RegisterExtensionInfo. Return value 0.
    Action start 07:49:21: RegisterProgIdInfo.
    Action ended 07:49:21: RegisterProgIdInfo. Return value 0.
    Action start 07:49:21: RegisterMIMEInfo.
    Action ended 07:49:21: RegisterMIMEInfo. Return value 0.
    Action start 07:49:21: WriteRegistryValues.
    Action ended 07:49:21: WriteRegistryValues. Return value 1.
    Action start 07:49:21: WriteIniValues.
    Action ended 07:49:21: WriteIniValues. Return value 1.
    Action start 07:49:21: WriteEnvironmentStrings.
    Action ended 07:49:21: WriteEnvironmentStrings. Return value 1.
    Action start 07:49:21: RegisterFonts.
    Action ended 07:49:21: RegisterFonts. Return value 1.
    Action start 07:49:21: InstallODBC.
    Action ended 07:49:21: InstallODBC. Return value 0.
    Action start 07:49:21: RegisterTypeLibraries.
    Action ended 07:49:21: RegisterTypeLibraries. Return value 0.
    Action start 07:49:21: SelfRegModules.
    Action ended 07:49:21: SelfRegModules. Return value 1.
    Action start 07:49:21: RegisterComPlus.
    Action ended 07:49:21: RegisterComPlus. Return value 0.
    Action start 07:49:21: InstallServices.
    Action ended 07:49:21: InstallServices. Return value 1.
    Action start 07:49:21: StartServices.
    Action ended 07:49:21: StartServices. Return value 1.
    Action start 07:49:21: RegisterUser.
    Action ended 07:49:21: RegisterUser. Return value 0.
    Action start 07:49:21: RegisterProduct.
    Action ended 07:49:21: RegisterProduct. Return value 1.
    Action start 07:49:22: PublishComponents.
    Action ended 07:49:22: PublishComponents. Return value 0.
    Action start 07:49:22: MsiPublishAssemblies.
    Action ended 07:49:22: MsiPublishAssemblies. Return value 1.
    Action start 07:49:22: PublishFeatures.
    Action ended 07:49:22: PublishFeatures. Return value 1.
    Action start 07:49:22: PublishProduct.
    Action ended 07:49:22: PublishProduct. Return value 1.
    Action start 07:49:22: DDSE_CA_Uninstall_InstallFinalizePre_amd64.
    03/04/13 07:49:22 DDSet_Status: LANGID: 1033
    03/04/13 07:49:22 DDSet_Entry: ImmediateDispatch: DDSE_CA_Uninstall_InstallFinalizePre entry
    03/04/13 07:49:22 DDSet_Error: Patch Hooks: Missing required property 'ProductFamily': Setup cannot continue.
    03/04/13 07:49:22 DDSet_Warning: Setup failed while calling 'getDLLName'. System error: 0xb7
    03/04/13 07:49:22 DDSet_CARetVal: 0
    03/04/13 07:49:22 DDSet_Exit: ImmediateDispatch: DDSE_CA_Uninstall_InstallFinalizePre exit
    Action ended 07:49:22: DDSE_CA_Uninstall_InstallFinalizePre_amd64. Return value 1.
    Action start 07:49:22: InstallFinalize.
    Action ended 07:49:23: InstallFinalize. Return value 1.
    Action start 07:49:23: DDSE_CA_Uninstall_InstallFinalizePost_amd64.
    03/04/13 07:49:23 DDSet_Status: LANGID: 1033
    03/04/13 07:49:23 DDSet_Entry: ImmediateDispatch: DDSE_CA_Uninstall_InstallFinalizePost entry
    03/04/13 07:49:23 DDSet_Error: Patch Hooks: Missing required property 'ProductFamily': Setup cannot continue.
    03/04/13 07:49:23 DDSet_Warning: Setup failed while calling 'getDLLName'. System error: 0xb7
    03/04/13 07:49:23 DDSet_CARetVal: 0
    03/04/13 07:49:23 DDSet_Exit: ImmediateDispatch: DDSE_CA_Uninstall_InstallFinalizePost exit
    Action ended 07:49:23: DDSE_CA_Uninstall_InstallFinalizePost_amd64. Return value 1.
    Action start 07:49:23: DDSE_CA_Uninstall_InstallExecuteSequenceEnds_amd64.
    03/04/13 07:49:23 DDSet_Entry: ImmediateDispatch: DDSE_CA_Uninstall_InstallExecuteSequenceEnds entry
    03/04/13 07:49:24 DDSet_Exit: ImmediateDispatch: DDSE_CA_Uninstall_InstallExecuteSequenceEnds exit
    Action ended 07:49:24: DDSE_CA_Uninstall_InstallExecuteSequenceEnds_amd64. Return value 1.
    Action start 07:49:24: DDSE_CA_Uninstall_CleanupDDSEDir_amd64.
    03/04/13 07:49:24 DDSet_Status: LANGID: 1033
    03/04/13 07:49:24 DDSet_Entry: DDSE_CA_Uninstall_CleanupDDSEDir entry
    03/04/13 07:49:24 DDSet_Error: Patch Hooks: Missing required property 'ProductFamily': Setup cannot continue.
    03/04/13 07:49:24 DDSet_Warning: Setup failed while calling 'getDLLDirectory'. System error: 0xb7
    03/04/13 07:49:24 DDSet_CARetVal: 1603
    03/04/13 07:49:24 DDSet_Exit: DDSE_CA_Uninstall_CleanupDDSEDir exit
    CustomAction DDSE_CA_Uninstall_CleanupDDSEDir_amd64 returned actual error code 1603 but will be translated to success due to continue marking
    Action ended 07:49:24: DDSE_CA_Uninstall_CleanupDDSEDir_amd64. Return value 1.
    Action ended 07:49:24: INSTALL. Return value 1.
    Property(S): UpgradeCode = {20550C92-0A08-4B07-9D5A-533BAAA890BB}
    Property(S): WinSDK_VC.14794 = C:\Program Files\Microsoft SDKs\Windows\v7.1\Redist\VC\
    Property(S): INSTALLLOCATION = C:\Program Files\Microsoft SDKs\Windows\v7.1\
    Property(S): WinSDK_License.8160 = C:\Program Files\Microsoft SDKs\Windows\v7.1\License\
    Property(S): WinSDK_Setup.9036 = C:\Program Files\Microsoft SDKs\Windows\v7.1\Setup\
    Property(S): WinSDK_Setup_1033 = C:\Program Files\Microsoft SDKs\Windows\v7.1\Setup\1033\
    Property(S): WinSDK_VS.9045 = C:\Program Files\Microsoft SDKs\Windows\v7.1\Setup\ShippedConfigFiles\VS\
    Property(S): WinSDK_SDK.9042 = C:\Program Files\Microsoft SDKs\Windows\v7.1\Setup\ShippedConfigFiles\SDK\
    Property(S): WinSDK_SDKVC.9043 = C:\Program Files\Microsoft SDKs\Windows\v7.1\Setup\ShippedConfigFiles\SDKVC\
    Property(S): WinSDK_VS.9040 = C:\Program Files\Microsoft SDKs\Windows\v7.1\Setup\PristineConfigFiles\VS\
    Property(S): WinSDK_VC.9039 = C:\Program Files\Microsoft SDKs\Windows\v7.1\Setup\PristineConfigFiles\VC\
    Property(S): WinSDK_SDK.9038 = C:\Program Files\Microsoft SDKs\Windows\v7.1\Setup\PristineConfigFiles\SDK\
    Property(S): WinSDK_VC.9044 = C:\Program Files\Microsoft SDKs\Windows\v7.1\Setup\ShippedConfigFiles\VC\
    Property(S): WinSDK_Bin.8052 = C:\Program Files\Microsoft SDKs\Windows\v7.1\Bin\
    Property(S): MSBuild_MicrosoftNetFrameworkTargets_ImportAfter = C:\Program Files (x86)\MSBuild\4.0\Microsoft.NETFramework.targets\ImportAfter\
    Property(S): MSBuild_Windows7.1SDK_Win32 = C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\Platforms\Win32\PlatformToolsets\Windows7.1SDK\
    Property(S): MSBuild_Windows7.1SDK_x64 = C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\Platforms\x64\PlatformToolsets\Windows7.1SDK\
    Property(S): MSBuild_Windows7.1SDK_Itanium = C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\Platforms\Itanium\PlatformToolsets\Windows7.1SDK\
    Property(S): WinSDK_SFX.14788 = C:\Program Files\Microsoft SDKs\Windows\v7.1\Setup\SFX\
    Property(S): WinSDK_SDKMenuDir.2 = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Microsoft Windows SDK v7.1\
    Property(S): WinSDK_SDKMenuDir_VSREG.18 = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Microsoft Windows SDK v7.1\Visual Studio Registration\
    Property(S): TARGETDIR = Q:\
    Property(S): WinSDK_Redist.8821 = C:\Program Files\Microsoft SDKs\Windows\v7.1\Redist\
    Property(S): WinSDK_INSTALLLOCATIONBASE.32 = C:\Program Files\Microsoft SDKs\Windows\
    Property(S): WinSDK_INSTALLEDSDKSROOT.24 = C:\Program Files\Microsoft SDKs\
    Property(S): ProgramFiles64Folder = C:\Program Files\
    Property(S): ProgramMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\
    Property(S): StartMenuFolder_amd64.3643236F_FC70_11D3_A536_0090278A1BB8 = Q:\StrtFldr\
    Property(S): INSTALLLOCATION_Bin = C:\Program Files\Microsoft SDKs\Windows\v7.1\Bin\
    Property(S): INSTALLLOCATION_Help = C:\Program Files\Microsoft SDKs\Windows\v7.1\Help\
    Property(S): INSTALLLOCATION_Include = C:\Program Files\Microsoft SDKs\Windows\v7.1\Include\
    Property(S): INSTALLLOCATION_Lib = C:\Program Files\Microsoft SDKs\Windows\v7.1\Lib\
    Property(S): INSTALLLOCATION_Setup = C:\Program Files\Microsoft SDKs\Windows\v7.1\Setup\
    Property(S): INSTALLLOCATION_Bin_WMI = C:\Program Files\Microsoft SDKs\Windows\v7.1\WMI\
    Property(S): WinSDK_ShippedConfigFiles.9041 = C:\Program Files\Microsoft SDKs\Windows\v7.1\Setup\ShippedConfigFiles\
    Property(S): WinSDK_PristineConfigFiles.9037 = C:\Program Files\Microsoft SDKs\Windows\v7.1\Setup\PristineConfigFiles\
    Property(S): MSBuild_MicrosoftNetFrameworkTargets = C:\Program Files (x86)\MSBuild\4.0\Microsoft.NETFramework.targets\
    Property(S): MSBuild_ToolsVersion4 = C:\Program Files (x86)\MSBuild\4.0\
    Property(S): MSBuild = C:\Program Files (x86)\MSBuild\
    Property(S): ProgramFilesFolder = C:\Program Files (x86)\
    Property(S): MSBuild_PlatformToolsets_Win32 = C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\Platforms\Win32\PlatformToolsets\
    Property(S): MSBuild_Win32 = C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\Platforms\Win32\
    Property(S): MSBuild_Platforms = C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\Platforms\
    Property(S): MSBuild_v4.0 = C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\
    Property(S): MSBuild_Microsoft.Cpp = C:\Program Files (x86)\MSBuild\Microsoft.Cpp\
    Property(S): MSBuild_PlatformToolsets_x64 = C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\Platforms\x64\PlatformToolsets\
    Property(S): MSBuild_x64 = C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\Platforms\x64\
    Property(S): MSBuild_PlatformToolsets_Itanium = C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\Platforms\Itanium\PlatformToolsets\
    Property(S): MSBuild_Itanium = C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\Platforms\Itanium\
    Property(S): VersionNT = 601
    Property(S): Manufacturer = Microsoft Corporation
    Property(S): ProductCode = {3156336D-8E44-3671-A6FE-AE51D3D6564E}
    Property(S): ProductLanguage = 1033
    Property(S): ProductName = Microsoft Windows SDK for Windows 7 (7.1)
    Property(S): ProductVersion = 7.1.30514
    Property(S): ProductShortName = Microsoft Windows SDK
    Property(S): VSAssemblyVersion = 10.0.0.0
    Property(S): WmiDirKey = INSTALLLOCATION_Bin_WMI
    Property(S): DirectoryTable71_amd64 = DirectoryTable
    Property(S): Accept = No
    Property(S): ALLUSERS = 1
    Property(S): ARPCOMMENTS = Update/Uninstall/Repair this SDK
    Property(S): ARPHELPLINK = http://go.microsoft.com/fwlink/?linkid=156449
    Property(S): ARPURLUPDATEINFO = http://go.microsoft.com/fwlink/?linkid=156449
    Property(S): ARPINFOABOUT = http://go.microsoft.com/fwlink/?linkid=156449
    Property(S): ARPPRODUCTICON = Icon_msi.ico
    Property(S): ARPNOMODIFY = 1
    Property(S): ARPNOREMOVE = 1
    Property(S): ARPNOREPAIR = 1
    Property(S): ARPSYSTEMCOMPONENT = 1
    Property(S): BackupDir = None
    Property(S): ButtonFont = {\MsShellD8}
    Property(S): CmdArgs = "
    Property(S): CmdProp = cmd.exe
    Property(S): DefaultFont = {\MsShellD8}
    Property(S): DefaultUIFont = MsShellD8
    Property(S): DISABLEADVTSHORTCUTS = 1
    Property(S): EXISTINGINSTALLLOCATION = None
    Property(S): HelpDirKey = INSTALLLOCATION_Help
    Property(S): HelpFile = SdkHelp.chm
    Property(S): HelpURL = http://go.microsoft.com/fwlink/?linkid=156449
    Property(S): INSTALLLEVEL = 10
    Property(S): InstallMode = Typical
    Property(S): MaintenanceMode = AddRemove
    Property(S): MsiexecProp = MsiExec.Exe
    Property(S): NewFolder = NewFolder-NOTUSED
    Property(S): PIDKEY = 111-1111111
    Property(S): PIDTemplate = 12345<###-%%%%%%%>@@@@@
    Property(S): PRIMARYFOLDER = INSTALLLOCATION
    Property(S): Registraton = No
    Property(S): ReinstallChoice = Normal
    Property(S): ReinstallFileVersion = o
    Property(S): ReinstallRepair = r
    Property(S): RootDirKey = INSTALLLOCATION
    Property(S): SDKsRootDirKey = INSTALLEDSDKSROOT
    Property(S): SetupDirKey = INSTALLLOCATION_Setup
    Property(S): Uninstall = False
    Property(S): UpgradeMode = Upgrade
    Property(S): ProductVersionExternal = 7.1.7600.0.30514
    Property(S): NTBuildBranch = win7_rtm
    Property(S): NTBuildType = Main
    Property(S): NTBuildNumberMajor = 7
    Property(S): NTBuildNumberMinor = 1
    Property(S): NTBuildNumberBuild = 7600
    Property(S): NTBuildNumberIncremental = 0
    Property(S): NTBuildNumberCSD = 090713-1255
    Property(S): FrameworkBuild = 30319.01
    Property(S): SecureCustomProperties = EXISTINGPRODUCTS;EXISTINGPRODUCTSNEWER;NEWERPRODUCTVERSIONDETECTED
    Property(S): MsiLogFileLocation = C:\Users\OLIVIER\AppData\Local\Temp\SDKSetup_7.0.6918.0.log
    Property(S): PackageCode = {93CE58D4-DCFC-408E-8682-55B43993AA5E}
    Property(S): ProductState = 5
    Property(S): REMOVE = ALL
    Property(S): REBOOT = ReallySuppress
    Property(S): CURRENTDIRECTORY = q:\b453970da414ebeebccfb0d80c
    Property(S): CLIENTUILEVEL = 3
    Property(S): MSICLIENTUSESEXTERNALUI = 1
    Property(S): CLIENTPROCESSID = 1908
    Property(S): MsiSystemRebootPending = 1
    Property(S): PRODUCTLANGUAGE = 1033
    Property(S): VersionDatabase = 200
    Property(S): VersionMsi = 5.00
    Property(S): VersionNT64 = 601
    Property(S): WindowsBuild = 7601
    Property(S): ServicePackLevel = 1
    Property(S): ServicePackLevelMinor = 0
    Property(S): MsiNTProductType = 1
    Property(S): WindowsFolder = C:\Windows\
    Property(S): WindowsVolume = C:\
    Property(S): System64Folder = C:\Windows\system32\
    Property(S): SystemFolder = C:\Windows\SysWOW64\
    Property(S): RemoteAdminTS = 1
    Property(S): TempFolder = C:\Users\OLIVIER\AppData\Local\Temp\
    Property(S): CommonFilesFolder = C:\Program Files (x86)\Common Files\
    Property(S): CommonFiles64Folder = C:\Program Files\Common Files\
    Property(S): AppDataFolder = C:\Users\OLIVIER\AppData\Roaming\
    Property(S): FavoritesFolder = C:\Users\OLIVIER\Favorites\
    Property(S): NetHoodFolder = C:\Users\OLIVIER\AppData\Roaming\Microsoft\Windows\Network Shortcuts\
    Property(S): PersonalFolder = C:\Users\OLIVIER\Documents\
    Property(S): PrintHoodFolder = C:\Users\OLIVIER\AppData\Roaming\Microsoft\Windows\Printer Shortcuts\
    Property(S): RecentFolder = C:\Users\OLIVIER\AppData\Roaming\Microsoft\Windows\Recent\
    Property(S): SendToFolder = C:\Users\OLIVIER\AppData\Roaming\Microsoft\Windows\SendTo\
    Property(S): TemplateFolder = C:\ProgramData\Microsoft\Windows\Templates\
    Property(S): CommonAppDataFolder = C:\ProgramData\
    Property(S): LocalAppDataFolder = C:\Users\OLIVIER\AppData\Local\
    Property(S): MyPicturesFolder = C:\Users\OLIVIER\Pictures\
    Property(S): AdminToolsFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools\
    Property(S): StartupFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup\
    Property(S): StartMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\
    Property(S): DesktopFolder = C:\Users\Public\Desktop\
    Property(S): FontsFolder = C:\Windows\Fonts\
    Property(S): GPTSupport = 1
    Property(S): OLEAdvtSupport = 1
    Property(S): ShellAdvtSupport = 1
    Property(S): MsiAMD64 = 6
    Property(S): Msix64 = 6
    Property(S): Intel = 6
    Property(S): PhysicalMemory = 16326
    Property(S): VirtualMemory = 26275
    Property(S): AdminUser = 1
    Property(S): MsiTrueAdminUser = 1
    Property(S): LogonUser = OLIVIER
    Property(S): UserSID = S-1-5-21-1570443390-2798732455-3955044424-1000
    Property(S): UserLanguageID = 1036
    Property(S): ComputerName = GASPARD
    Property(S): SystemLanguageID = 1036
    Property(S): ScreenX = 1024
    Property(S): ScreenY = 768
    Property(S): CaptionHeight = 22
    Property(S): BorderTop = 1
    Property(S): BorderSide = 1
    Property(S): TextHeight = 16
    Property(S): TextInternalLeading = 3
    Property(S): ColorBits = 32
    Property(S): TTCSupport = 1
    Property(S): Time = 07:49:29
    Property(S): Date = 04/03/2013
    Property(S): MsiNetAssemblySupport = 4.0.30319.1
    Property(S): MsiWin32AssemblySupport = 6.1.7601.17514
    Property(S): RedirectedDllSupport = 2
    Property(S): MsiRunningElevated = 1
    Property(S): Privileged = 1
    Property(S): ProductID = 12345-111-1111111-35211
    Property(S): USERNAME = OLIVIER
    Property(S): Installed = 00:00:00
    Property(S): DATABASE = C:\Windows\Installer\118ecb4.msi
    Property(S): OriginalDatabase = C:\Users\OLIVIER\AppData\Local\Temp\SDKSetup\WinSDK\WinSDK_amd64\WinSDK_amd64.msi
    Property(S): UILevel = 2
    Property(S): MsiUISourceResOnly = 1
    Property(S): Preselected = 1
    Property(S): ACTION = INSTALL
    Property(S): ROOTDRIVE = Q:\
    Property(S): CostingComplete = 1
    Property(S): OutOfDiskSpace = 0
    Property(S): OutOfNoRbDiskSpace = 0
    Property(S): PrimaryVolumeSpaceAvailable = 218151928
    Property(S): PrimaryVolumeSpaceRequired = -6464
    Property(S): PrimaryVolumeSpaceRemaining = 218158392
    Property(S): PrimaryVolumePath = C:
    === Logging stopped: 04/03/2013 07:49:29 ===
    MSI (s) (A0:AC) [07:49:29:807]: Product: Microsoft Windows SDK for Windows 7 (7.1) -- Removal completed successfully.
    MSI (s) (A0:AC) [07:49:29:828]: Windows Installer a supprimé le produit. Nom du produit*: Microsoft Windows SDK for Windows 7 (7.1). Version du produit*: 7.1.30514. Langue du produit*: 1033. Fabricant : Microsoft Corporation. Réussite de la suppression ou état d’erreur*: 0.
    07:49:07 lundi 4 mars 2013: SFX C:\Program Files\Microsoft SDKs\Windows\v7.1\Setup\SFX\vcredist_x64.exe installation started with log file C:\Users\OLIVIER\AppData\Local\Temp\Microsoft Windows SDK for Windows 7_45008540-58d4-4d68-af83-5a7aa8471a90_SFX.log
    07:49:11 lundi 4 mars 2013: C:\Program Files\Microsoft SDKs\Windows\v7.1\Setup\SFX\vcredist_x64.exe installation failed with return code 5100
    07:49:29 lundi 4 mars 2013: [SDKSetup:Error] Config_Products_Install: Installation of Product Microsoft Windows SDK for Windows 7 (failed): Please refer to Samples\Setup\HTML\ConfigDetails.htm document for further information. Stack: à SDKSetup.Product.ConfigureRelatedSfx() à SDKSetup.Product.ConfigureNewProduct(ManualResetEvent CancelEvent)
    07:49:29 lundi 4 mars 2013: [SDKSetup:Info] Config_Products_InstallNew: End installation of new product: Microsoft Windows SDK for Windows 7
    07:50:40 lundi 4 mars 2013: [SDKSetup:Info] Successfully downloaded the file http://download.microsoft.com/downl...etup\WinSDKDebuggingTools_amd64\dbg_amd64.msi to C:\Users\OLIVIER\AppData\Local\Temp\SDKSetup\WinSDKDebuggingTools\WinSDKDebuggingTools_amd64\dbg_amd64.msi
    07:50:40 lundi 4 mars 2013: [SDKSetup:Info] File succesfully downloaded - source:http://download.microsoft.com/downl...etup/WinSDKDebuggingTools_amd64/dbg_amd64.msi target:file:///C:/Users/OLIVIER/AppData/Local/Temp/SDKSetup/WinSDKDebuggingTools/WinSDKDebuggingTools_amd64/dbg_amd64.msi size:17529856
    07:50:40 lundi 4 mars 2013: [SDKSetup:Error] Config_Products_Install: Windows SDK Setup (failed): Installation of the "Microsoft Windows SDK for Windows 7" product has reported the following error: Please refer to Samples\Setup\HTML\ConfigDetails.htm document for further information. Stack: à SDKSetup.Product.ConfigureNewProduct(ManualResetEvent CancelEvent) à SDKSetup.Product.SetupProduct(TaskMode taskMode, ManualResetEvent CancelEvent) à SDKSetup.ProductCollection.SetupProducts(TaskMode taskMode, DownloadManager downloadManager, ManualResetEvent cancelEvent) à SDKSetup.ConfigProducts.DoCurrentTask(TaskMode Task)
  5. 2013/03/04
    Congratulations
    Your recommandations worked perfectly; you are an olympic champion OLIVIER GEBUHRER
