Slow Wireless Connection
Discussion in 'Networking (Hardware & Software)' started by cosmeo3000, 2007/12/14.
  1. 2007/12/14
    cosmeo3000
    cosmeo3000 Inactive Thread Starter
    My wireless connection is slower than what it's supposed to be. I use Verizon FiOS, which is at 20Mbps when I use an ethernet connection. That usually means my download rate is from 1mb-1.5mb. But when I go wireless, it's only around 200kb. I always have an excellent connection and use a 54MBPs.
  2. 2007/12/15
    visionof
    visionof Inactive
    Do you believe in the tooth fairy ?
    The number 54 mb/s on the box has nothing to do with reality
    Your limiting factor in most user's cases is their internet connection not the wireless speeds.
    Wireless speeds at most are 1/2 of the stated maximum ( networking overhead)
    Speed drops off with distance
    After 30 feet it drops off like a stone ( g and b)
    Change the channel of the router from the default 6 to any other channel
    Channel 1 and 11 are first picks
    You may have a neighbors rogue signal drifting in and causing interference
    You may not even see it in the windows wireless utility
    Netstumbler may see it
    Change the ssid from the default - even if to change a digit
    If you think that you have an intruder on your system turn on the encryption
    Make sure that the router is high and uncluttered
    Basements are not a good place for wireless routers
    You may want to move the router - even a foot or so over
    Also if you have only g network adapters change the signal to g only
    Check the wireless speed setting in the router control panel as well
    A very useful home networking utility is network magic
    http://www.networkmagic.com/
    In most cases even the older b wireless is faster than most internet users connection speeds
    The faster speeds on the box will not help you with internet speeds but rather with transfers of large files within your home network
    Wired connections are always faster than wireless , although wireless is very high tech and impressive
    You might also want to look into powerline ethernet adapters if the remote computer is staying put - say on a desk , rather than a mobile laptop
    Scott Smith
    Scott Smith Inactive Alumni
    Is that a typo?
    If you have a 20Mb connection your download speed should be 20Mbps.
  5. 2007/12/15
    Which gives a (theoretical) max. download speed of 2.5 MB/sec, so seeing 1-1.5 MB/sec isn't that bad.
    Scott Smith
    Ahh didn't notice the Capitol "B" :) Because it isn't there. :confused:
    20 Mb = approximately 2.5 MB
    I always try to keep my bits and Bytes consistent when talking speeds.
