Slow network writes, fast reads after upgrading to WinXP Pro
Discussion in 'Networking (Hardware & Software)' started by mkeast, 2006/02/14.
  1. 2006/02/14
    mkeast
    mkeast Inactive Thread Starter
    I upgraded my Dell Precision 530 workstation from Windows 2000 to Windows XP Pro SP2. The machine is fully patched. The NIC is a 3COM 3C920 integrated fast ethernet controller compatible with the 3COM 3C905C-TX.
    This machine is a member of a large domain (Windows 2000 currently migrating to Windows 2003 - not sure how many servers have been migrated). Since I'm a developer and SQL Server DBA for a 30-person office that is part of a larger organization, I upgraded the machine myself (most users have an imaged desktop). After upgrading, I get the same read performance from any network server (I have access to several different domain member servers, including 5 that I maintain) that I got with Win2K, but the write performance is abysmal. Using PerfMon, for Network bytes received/sec I get close to 6 MB / sec, while network writes are about 120 KB / sec. We use Cisco switches, not sure what models. Usually, this type of problem is due to mismatch between the switch port duplex/type setting and the associated setting on the client PC. I tried all of the various settings (should be 100 MBit/Full Duplex), but nothing works.
    Does anybody have any ideas at what else to look for? Thanks
    Mike
  2. 2006/02/15
    Might try this:
    Speed up network (LAN) browsing in Win2K/XP
    Open the Registry Editor (REGEDIT.EXE)
    Rename the following registry entry:
    HKEY_LOCAL_MACHINE
    \Software
    \Microsoft
    \Windows
    \CurrentVersion
    \Explorer
    \RemoteComputer
    \Namespace
    \{D6277990-4C6A-11CF-8D87-00AA0060F5BF}
    For example, you can rename it to:
    DISABLED {xxD6277990-4C6A-11CF-8D87-00AA0060F5BF}
    This change prevents the browsing computer from checking for scheduled tasks on the remote machine before connecting, which is apparently the reason for the slowness.
    You can check this Knowledge Base article for further reference:
    http://support.microsoft.com/?id=kb;en-us;Q245800
