Resolved Slow Installation, Slow Set up,Slow Start up, Slow shut down,
Discussion in 'Windows 7' started by Spanner, 2013/09/13.
  1. 2013/09/13
    Spanner
    Spanner Inactive Thread Starter
    I installed Windows 7 in a PC with a new 160 GB HD, New drive had not been used before?, owner upgrading from XP/ 40 GB HD, looking to increase drive capacity to enable graphic design by adding partitioned Slave drive, ( what would be the best total GB for this, as a starter? ).
    Installation took well over 2 hours, now get very long start up and shut down.
    Disk has about 90% free. Control Panel loads very slowlym
    PC has over 220 system drivers according to System Info, what should I be looking for ?
    Spanner..
  2. 2013/09/13
    lj50 Lifetime Subscription
    lj50,
    Post the specs of the PC.
  5. 2013/09/13
    Spanner
    Thanks lJ50, didn't give it a thought, should have done.
    To Admin, I am running Piriform Speccy at the moment on the computer, do you want results of that or the 'System Information' System Drivers.?
    Spanner
  6. 2013/09/13
    Hook the old HD back up as Master then leave the NEW one unhooked then go to MS and see what it says about upgrading.
  7. 2013/09/13
    You're welcome Spanner. Thanks for the backup MrBill should have suggested it in my original post. Got side tracked.
    lj50,
    #6
  8. 2013/09/14
    Spanner
    To MrBill.
    Please explain the reason for the suggestion that I re-con the old HD with XP on it,'unhook' the new HD and run the MS upgrade advisor from the old HD. I assumed this would not be required because Windows7 was being installed on a new HD.
    Spanner
  9. 2013/09/14
    To go to the link that was suggested in post # 2 to see if that machine is even capable of running Windows 7.
    http://windows.microsoft.com/en-us/windows/downloads/upgrade-advisor
  10. 2013/09/14
    Spanner
    Thank you Mr Bill I will give that a try,however for reasons best known to itself, the new OS system is working , a little slow but improving, it seems that every time I start and the shut down it gets a little quicker, or is that my imagination ?. The system information shows about 160 system drivers now , it was 220 + at the start.
    To Admin, your request to post specs of PC, I can provide the following Speccy scan, but if you need the system drivers list I will post them separately.
    System Spec,
    OS. Windows 7 Pro, 32 bit.SP1
    CPU. Intel Celeron, Northwood 0.13 Technology.
    Motherboard. Micro-star, P4M266-8233 (socket 478 )
    RAM.5ir-MB. DDR 0136Mhz (3.5-3-3-6 )
    Graphics.LCD1960NXi (800x600 )
    Hard D. 149GB, Seagate sT 316025ace ATA
    Optical Drives, Matshita DVD-ROM Sr-8584A ATA
    Audio. No audio card detected.
    I hope these details will help.
    Spanner.
  11. 2013/09/14
    Speccy is incomplete ....
    That doesn't make sense - typo?
    from from here. In practice more needed - never expect a computer to run an OS well on minimum specs.
    Processor speed ?? -
    Graphics -
    That's the monitor, not the graphics card/chip.
    Hence MrBill's post to run the Windows 7 Upgrade Advisor. To put it bluntly you can't throw Wndows 7 into any old computer - there are basic requirements in terms of specs.
    Driver list NOT required.
  12. 2013/09/14
    Spanner
    Thanks Pete C, I will check Speccy results again,be back SAP .
    Now the OS is running, (as it is ) should I run the MS Windows7 upgrade advisor, or will this be opening the stable door after the horse has bolted ?
    Spanner
  14. 2013/09/14
    Yes - it will run and advise - I have just run it on my Win 7 desktop to check.
  15. 2013/09/14
    James Martin
    James Martin Geek Member
    Is it possible to run Windows 7 on a board with a 478 socket?
    I have a 10 year old MSI - 6738 board, but according to Windows upgrade adviser, running Windows 7 would be difficult.
  16. 2013/09/14
    Lots of versions of Windows would run on some old junk PC's. But not very good. Seen where XP was pretty fast and then when upgrading just Windows 7 on the same PC, it was slower than molasses in January at the North Pole.
  17. 2013/09/15
    Could be 512 MB RAM Pete. But this board is 13 years old!! Talk about pushing your brown stuff up hill MrBill. Neil.
  18. 2013/09/15
    Sure could, but if data is posted it must be accurate :) as I have posted many times in the past - 'we do not have a crystal ball' !
  19. 2013/09/15
    The site I posted in post #2 works. My computer is 13 years old. in 2009 I installed an OEM 32 bit version of windows 7 Ultimate. Its still running.
  20. 2013/10/07
    Spanner
    Just got update from Owner of PC, he has gone back to OS XP and is working ok, I think he is waiting for someone to buy him a new PC for Christmas, hope its not an ipad.
    Incidentally his son (54) has read my posts/threads ( as guest) in Windows BBS, he recognised the problem and worked out that it was me by someone telling him my nickname when I was a kid.
    Have to be careful what we write.
    Marking this Resolved .
    Thanks, Spanner
