slight Java problem
Discussion in 'Firefox, Thunderbird & SeaMonkey' started by gpb59, 2009/04/03.
  1. 2009/04/03
    gpb59
    gpb59 Well-Known Member Thread Starter
    I use a program called market trader with etrade. Recently, instead of just launching from the webpage, it puts a "bali-launch" icon on my desktop which I then have to double click and then it launches. The etrade technical support was unable to figure it out. They suggested I uninstall firefox and reinstall it.
    Sounds like there my be a quick fix if anybody has an idea.
  2. 2009/04/03
    Westside
    Westside Inactive Alumni
    Can you give a link? The problem is unusual, and there is no way that it can be checked with the information provided. Which version Firefox, and Java.
    gpb59
    fire fox is 3.08, Java 6 update 11. I'd have to give you my login if I gave you the link. It's not a big deal, I can just do the extra step or use explore.
  5. 2009/04/04
    Ramona
    Ramona Geek Member Alumni
    bernyx,
    Install the IETab Add-on, and use it to access the page. Let us know if this helps.
  6. 2009/04/07
    gpb59
    that works, thanks
  7. 2009/04/13
    gpb59
    I wound up uninstalling and reinstalling firefox and now it works fine without the IE tab. When going to launch the program a box opens and asks whether to open with java webstart or save file. Some how it must have got to default to save file. I think it could have been changed in the applications tab for future reference.
  8. 2009/04/14
    JSS3rd Lifetime Subscription
    JSS3rd Geek Member
    bernyx ...
    Update 13 is the latest update to Java 6 (build 1.6.0_13-b03). If you haven't updated Java since you posted your info on the 3rd, you might want to do so at your earliest convenience.
