Site givethe error Won't accept cookies
Discussion in 'General Internet' started by purplemtn, 2002/01/07.
  1. 2002/01/07
    purplemtn
    purplemtn Inactive Thread Starter
    A frienrd of mine [ a PC Repair person } is working on a machine {win98 , IE5]that when going to EBay and trying to sign in says " won't accept cookies "..
    It is set up to accept cookies {followed all the setps listed on ebay also] , tried deleteing old cookies and resiging in { sign in info works on another PC, and had worked on this one before} ..
    EBay appears to work..
    Any Ideas out there ?
    Thank You......purplemtn.....
  2. 2002/01/07
    purplemtn
    Mr
    FYI
    Installed NS 6 every thing works , the customer is happy with NS 6 , but for my own infomation I still would like to know [what now appears to be a IE problem] how to fix it if it happens again..
    purplemtn
    eddie5659
    eddie5659 Inactive
    Hiya
    If he was using IE, he could have tried a few things. One is a repair:
    Control Panel | AddRemove. Doubleclick Microsoft Internet Explorer. Choose Repair, apply and restart.
    After that, its just a matter of pinpointing. Maybe looking for the SAM file.
    Regards
    eddie
  5. 2002/01/07
    purplemtn
    Mr
    eddie5659
    Thanks for the ideas , I forgot about Repiar myself , will try that next time..
    What is SAM file ?
    purplemtn
  6. 2002/01/08
    eddie5659
    eddie5659 Inactive
    Hiya
    Start>Find>Files, key in Hosts and press enter. If you see a file named just Hosts with no extension, right click on it and rename it Hosts.old
    you may find a Hosts.sam file but that won't be related to your problem. You're only interested in renaming any file just called Hosts with no file extension on the end. Make sure that you have closed all instances of Internet Explorer.
    Also, check for how many versions of wsock32.dll is on the system. Duplicates can cause problems.
    Regards
    eddie
  7. 2002/01/08
    purplemtn
    eddie5659
    Thanks .
    I had read a post about Host files a while back , anf even looked them up on my PC [forget why now] , but didn't even think about them{seems it's getting to where I know more and more about less and less untill I know almost evrything about nothing} , I'll pass this information on to my friend..
    FYI what ever ver. of IE that was on the machine did not have a repaire , I was told IE5 , he tried to check for that ..
    purplemtn
  8. 2002/01/08
    Kevin Lifetime Subscription
    Kevin Well-Known Member
    purplemtn
    Hi Kevin
    Iteresting site [ bookmarked it] and as usual from you another great source of information and or a answer for a problem. Will pass it on..
    thank for your help..
    purplemtn
  10. 2002/01/09
    eddie5659
    eddie5659 Inactive
    Hiya
    as for the repair not working, if it was IE6 I'd understand. But IE5 should have it. Have a look at this:
    http://support.microsoft.com/default.aspx?scid=kb;EN-US;q194177
    and at the bottom
    Regards
    eddie
  11. 2002/01/09
    purplemtn
    eddie5659
    Thanks for the ideas , will look into the MSKB site and try the other command ..
    I really appreciate you hard work on this problem..
    purplemtn
