Simple problem: Flash Drive virus and Recycle folder;autorun
Discussion in 'Malware and Virus Removal Archive' started by clubECGR, 2009/03/26.
  1. 2009/03/26
    clubECGR
    clubECGR Inactive Thread Starter
    EDIT: The virus is a Trojan Dropper Win32 Flystud ko and Flystudio.b
    It says no traces available.
    I'm doing a Kasperky scan and it detected 3 files, One of which is a duplicated infected folder.
    I'll determine if I can clean this myself.
    Thank you for your time
    Regards,
    Chris
    EDIT: Here's the Kasperky Scan in Safe Mode. I deleted the said files. Wish for luck and no more files generated in Flash Drives
    KASPERSKY ONLINE SCANNER 7 REPORT
    Friday, March 27, 2009
    Operating System: Microsoft Windows Vista Home Basic Edition, 32-bit Service Pack 1 (build 6001)
    Kaspersky Online Scanner 7 version: 7.0.25.0
    Program database last update: Friday, March 27, 2009 08:27:18
    Records in database: 1975760
    Scan settings:
    Scan using the following database: extended
    Scan archives: yes
    Scan mail databases: yes
    Scan area - My Computer:
    C:\
    D:\
    E:\
    G:\
    Scan statistics:
    Files scanned: 195182
    Threat name: 4
    Infected objects: 5
    Suspicious objects: 0
    Duration of the scan: 02:22:18
    File name / Threat name / Threats count
    C:\Users\Chris\Desktop\YSMenu\TTMenu.exe Infected: Trojan-Dropper.Win32.Flystud.ko 1
    C:\Windows\System32\5A8DCC\AK63A1C.EXE Infected: not-a-virus:AdWare.Win32.FlyStudio.b 1
    C:\Windows\System32\5A8DCC\nmurnxp.exe Infected: not-a-virus:AdWare.Win32.FlyStudio.b 1
    D:\Files from SD\ComboFix.exe Infected: Trojan.Win32.Agent2.doi 1
    D:\Files from SD\ComboFix.exe Infected: Trojan.Win32.Agent2.fft 1
    The selected area was scanned.
    EDIT: Seems fine by now. No more files nor my folders being hidden away and replaced by application folders.
    I do hope I can confirm this to be clean.
    Thank you for your time. It seems my problems are over. I need to confirm this. Thanks again for your time
