Shutdown Batch Help please
Discussion in 'Legacy Windows' started by quackbal, 2004/08/10.
  1. 2004/08/10
    quackbal
    quackbal Inactive Thread Starter
    Hello all,
    I know its possible in Win9x/ME, and XP, but is it possible in 2K to use a batch command to restart the operating system?
    We have a public kiosk in our lobby and we'd like it to restart every 6 hours, which can be done via task scheduler. Problem is, I don't know what command to put in the batch file for the automatic restart.
    Specs:
    Windows 2000 Professional w/ SP4
    64.0MB RAM.
    Public kiosk for internet, runs kiosk program. Needs to restart every 6 hours and on restart the program sweeps the URL history, etc.
  2. 2004/08/10
    JoeHobart
    JoeHobart Inactive Alumni
    dobhar Lifetime Subscription
    dobhar Inactive
    EDIT: JoeHobart's suggestion of PsShutdown sounds much better...Kent
    Hi quackbal...
    I think the command for the batch file would be, using the following MS link for info => http://support.microsoft.com/default.aspx?scid=kb;en-us;317371&sd=tech, shutdown /l /t:21600 /y /c
    It sounds like you will need the Win2000 Resource kit to get the "Shutdown.exe" tool.
  5. 2004/08/11
    quackbal
    I have got it from XP, and it runs fine.
    Thank you, everyone.
