Shut down problem
Discussion in 'Windows XP' started by sgarber1, 2005/11/16.
  1. 2005/11/16
    sgarber1
    sgarber1 Inactive Thread Starter
    With Windows 98, when I wanted to shut down, I could turn the computer off simply by pressing the power switch. With Windows XP installed, the power switch has some effect (I can hear something stop - perhaps the hard drive) but something is still running (perhaps the fan), and the only way I can come to a dead stop is by unplugging the power cord. That doesn't seem right. How can I change it?
  2. 2005/11/16
    Control Panel->Power Options->Advanced tab
    Whiskeyman Inactive Alumni
    http://aumha.org/win5/a/shutcut.php
  5. 2005/11/17
    sgarber1
    Thanks for your help, Whiskeyman. I did what you suggested: Control Panel/Performance & Maintenance/Power Options/Advanced. There was no Power Button section under the Advanced Tab, so, as you say, my computer evidently does not have the capability. I accept that. However, there still seems to be something wrong, because of two things. First, I can't shut down completely without disconnecting the power cord, and second I have to disconnect and re-connect the power cord before I can start up again (by pressisng the start switch). Also, as I said in my original message, with Windows 98, the computer, in fact, did shut down completely when I clicked on that option, and I could start it back up with the start switch - no unplugging the power cord.
    What could be wrong?
    Sam
  6. 2005/11/17
    or the capability is disabled in CMOS
    Did you go into your BIOS settings and see if power management was disabled there?
    #5
  7. 2005/11/19
    sgarber1
    Can't disable Power Management in CMOS
    Newt, there appears to be no way of disabling Power Management in the BIOS. In fact, I found nothing in any of the Setup Menu selections that relates to the problem I am having. I'm still in a quandary as to what might be causing this. It doesn't make sense (at least not to me) that there would be an intentional shut-down mode that involves pulling the plug before you can completely shut down and restart. Once Windows says it's safe to shut down, I would like to be able to shut down from the power switch, and then start up from the power switch. I would welcome further suggestions.
