Resolved Shut down does not working
Discussion in 'Windows 7' started by jennyvlas, 2012/02/19.
  1. 2012/02/19
    jennyvlas
    jennyvlas Inactive Thread Starter
    hi,I have a problem with my laptop.Shut down command is not responding either restart.Any suggestions ?
  2. 2012/02/19
    SpywareDr
    Click the Start button, type in:
    shutdown -s -t 0 -f​
    and press [Enter].
    Let us know what happens ...
    BTW, that "0" in the command above is a zero, not an uppercase "oh ".
    I just clicked the Start Button on my PC and couldn't type what you said. It won't let me type anything. Do I have to go someplace else after I click Start?
  5. 2012/02/19
    You have to click Start< Run then type shutdown -s -t 0 -f and press enter for the command to work.
    The zero in the command is how many seconds before your system will shut down. If you want to test the command but you don't want your system to shut down immediately then replace the zero with a number like 500 for example which is how much time in seconds. If you want to stop the shut down request you can click Start< Run and type shutdown -a to cancel it.
  6. 2012/02/19
    The "Run" command is not available via the Start menu unless you customize the start menu. Easier, faster way is to go to Start button > All Programs > Accessories > Command prompt and put the command in there.
    jennyvlas likes this.
  7. 2012/02/21
    jennyvlas
    It worked !!! Thank you very much ! Can you tell me which was the problem ?
    Than you very much again.
  8. 2012/02/21
    Can you now shutdown & restart using the Start Menu?
  9. 2012/02/22
    SpywareDr
    Right-click the Desktop, select New > Shortcut, then use the:
    string for the command.
    Now whenever you want to shutdown, simply double-click your new shortcut.
  10. 2012/02/22
    lj50 Lifetime Subscription
    I have Start and Restart pinned to the taskbar. Saves time.
    lj50,
    #9
  11. 2012/02/24
    jennyvlas
    Yes I can after I did what you said.But....yesterday I had a problem with a payment I had to do via internet (After I put my the number of my card and press enter site was stucked) and I was checking the settings of my firewall.When I opened the window of security (low-medium-high)and after that I could not close the window.I forced it to shut down but after that I couldn t shut down my laptop.I typed again the command and everythig came back to normal
  12. 2012/02/24
    Sometimes, depending on the online credit card processing company, it can take over a full minute for the transaction to take place and the browser to display it.
    I suggest you start a new thread in the appropriate browser forum here if continue to have similar issues with using the WWW and your browser.
