Resolved Shrink drive "C" question
Discussion in 'Windows 7' started by savagcl, 2009/11/11.
  1. 2009/11/11
    savagcl Lifetime Subscription
    Windows7 64-Bit.
    I know other partitions can be shrunk/expanded but
    can i shrink the OS drive, drive "C" without any complications?
    thanks,
    savagcl
  2. 2009/11/11
    Yes, but only to the point where any unmovable files are located.
    As always an image of the drive before shrinking is good insurance - Windows 7 can image for you.
    Thanks, PeteC.
    Thought so but new OS's can surprise you.
    Got an image already.
    savagcl
  5. 2009/11/11
    Good luck - you should not need it :) I have performed the same operation in Vista without issue.
