shortcut icon on desktop not working
Discussion in 'Windows XP' started by BIG RED, 2005/04/09.
  1. 2005/04/09
    BIG RED
    BIG RED Inactive Thread Starter
    When I click on the shortcut icon on the desktop and click "open" nothing happens. Am i missing part of a program.
    Sounds simple but i do not have an answer. Any help would be appreciated.
    Thank You
    Big Red
  2. 2005/04/09
    BIG RED - Welcome to the Board :)
    Which shortcut icon are you referring to or are you referring to all desktop (shortcut) icons?
    Right click on 'the shortcut icon' > Properties - do you see a path there, e.g. "G:\Process Explorer\procexpnt\procexp.exe "?
    If none are working there is a possible fix here under 'Short Cut - Links Not Working'
    Welshjim
    Welshjim Inactive
    Just adding to PeteC's suggestion. If the problem is confined to just one shortcut, perhaps it has become corrupt. Find the application's .exe file, right click|SendTo|Desktop (create Shortcut). If you are asked if you want to replace the existing shortcut, click Yes.
  5. 2005/04/10
    BIG RED
    Thanks to Pete c and Welshjim - I had failed to mention that the problem was confined to one shortcut only. The shortcut is now working by process of the applications .exe and replacing the existing shortcut.
    Thank you both
    Big Red
  6. 2005/04/11
    Welshjim
    Welshjim Inactive
    BIG RED--You are welcome. Thanks for posting back and letting us know what helped.
