sfc /scannow problems
Discussion in 'Windows XP' started by Granv, 2006/01/23.
  1. 2006/01/23
    Granv
    Granv Inactive Thread Starter
    I am running Windows XP Home Edition and after looking in the 'Event Viewer' i noticed that there were files missing or damaged so i tried to run sfc /scannow so as to replace or repair the files. But i am constantly asked for the Windows Installation disk which i don't have. The reason being is that when i purchased my computer everything was pre-installed by the manufacturer before it was delivered to me. Can anyone tell me where i can get a work around for this problem please. Many thanks Granv
  2. 2006/01/23
    There is a workaround here which may work if you have an i386 folder on your drive of around 450 Mb. If it exists point sfc to it as described.
    Are the damaged or missing files causing a problem other than an entry in even viewer?
    You could try borrowing a cd from a friend.
  5. 2006/01/23
    Whiskeyman Inactive Alumni
    I don't have an installation CD for Windows XP - what if I need one?
    You may need to tweak some registry settings. See below. Adjust as necessary.
    Scannow sfc
