SFC /SCANNOW problem?
Discussion in 'Windows XP' started by tric171, 2003/03/21.
  1. 2003/03/21
    tric171
    tric171 Inactive Thread Starter
    SFC /SCANNOW problem>mflynn?
    Hi Mike and others,
    Furher to the powedown issue that I'm having I was advised by a friend to run SFC /SCANNOW to see if windows had to re-instal any files. It starts then just flashes up on the screen and disappears........got me puzzled,why won't it display/run? Hoping Mike or someone can help me here,please?
    regards and thanks:(
  2. 2003/03/21
    Rod
    Rod Well-Known Member
    tric171:
    What you are seeing flash by on the screen is a command window opening and closing. After this happens you should see a File Protection progress window open. If it doesn't open on the screen, check the taskbar and see if its minimized.
    If that still doesn't take care of it. Open a command window Start>Run>cmd and type sfc /scannow at the command prompt.
    HTH
    Rod,
    tric171
    Thanks Rod, the command option worked,ran SFC then as nothing else happened I presume all was ok with it.Don't know if I have to run anything else.Guess I'll wait till I shut down!
    many thanks for your help and advice:)
  5. 2003/03/22
    Rod
    Rod,
    tric171
    Hi Rod,
    The problem is that XP Pro will not powerdown.It just sits there after shutting down everything,except for the monitor which sits there saying "windows is shutting down ".I have been to every windows help site and Mike Flynn has been trying to help me with this.A friend suggested trying SFC to see if that would help,but it didn't.I guess I will have to go into the BIOS :) and look at the power settings as Mike suggested.The thread is on the 2nd page of this forum under slooooow shutdown if you are interested!
    I have done all suggested cleanups etc and it does shutdown everything much faster,just won't powerdown!:confused:
    many thanks for your interest
