Setting icons for Shortcuts That Use 'cmd'
Discussion in 'Windows 7' started by gw1500se, 2021/12/05.
  1. 2021/12/05
    gw1500se
    gw1500se Well-Known Member Thread Starter
    I have a shortcut that launches 'cmd' with a command. I wanted that particular shortcut to have a different icon. Unfortunately, when I set that icon on that shortcut, it changed all cmd icons. How do I change just that one shortcut icon? TIA.
  2. 2021/12/05
    Try and make a copy of cmd.exe and copy it somewhere else.....
    gw1500se
    Hmm. Or change the name do it is in the PATH.
  5. 2021/12/06
    I'm not sure what you attempted to say..... You can only change the if the file has been copied to where the path is pointing.
  6. 2021/12/07
    Don't make a shortcut to cmd with a command.
    Make a .bat file or a .cmd file. Then make a shortcut to it. The shortcut icon you choose will be used just for that shotrtcut only.
