Serial 2 Event Viewer Error's and IRQ assignment
Discussion in 'Windows XP' started by Rockit, 2004/11/19.
  1. 2004/11/19
    Rockit
    Rockit Inactive Thread Starter
    Anybody know how to fix this one?
    I believe it's in the BIOS setup but can't figure it out. I've changed the options for the IRQ's but no matter which ones I choose I either get conflicts on boot or this error in the event viewer.
    Rockit
    Event Type: Warning
    Event Source: Serial
    Event Category: None
    Event ID: 4
    Date: 11/19/2004
    Time: 9:55:42 AM
    User: N/A
    Computer: COMPUTER
    Description:
    Unable to create the symbolic link for \Device\Serial2.
    For more information, see Help and Support Center at http://go.microsoft.com/fwlink/events.asp.
    Data:
    0000: 00 00 00 00 02 00 4e 00 ......N.
    0008: 00 00 00 00 04 00 06 80 .......€
    0010: 34 00 00 00 35 00 00 c0 4...5..À
    0018: 00 00 00 00 00 00 00 00 ........
    0020: 00 00 00 00 00 00 00 00 ........
  2. 2004/11/19
    If it were me, I'd set things so I could boot without conflicts and ignore that particular warning message.
    It is probably left over from some application you removed that didn't go quietly or cleanly. I'm betting on a bad API call rather than any real problem on the PC.
    Rockit
    Thanks Newt,
    I disabled both serial ports in the BIOS and the error went away. Don't know if I need them at all at this time anyway cause everything seems to be working fine. ;)
    Thanks Again
    Rockit
  5. 2004/11/20
    Generally with 2K/XP/2K3 I think it works fine to disable serial ports in BIOS and just let the OS operate them.
    In fact, I vaguely remember having to disable com ports in the BIOS on NT4 systems to get a piece of hardware to function since otherwise the OS and BIOS would fight for control and the dang thing wouldn't work.
    I'm not hardware savvy enough to know why but our hardware tech suggested it and things did fine.
