Send To does not work
Discussion in 'Internet Explorer & Microsoft Edge' started by spook, 2009/04/01.
  1. 2009/04/01
    spook
    spook Well-Known Member Thread Starter
    When I select a link to send via e-mail (file-send-link by e-mail) I get a message "Not implemented ". Can tjhis be fixed?
  2. 2009/04/01
    BurrWalnut
    BurrWalnut Well-Known Member Alumni
    I'm guessing but it could be because you haven’t made your email program the default in the Start menu.
    1. In XP. Right-click Start > Properties > Start Menu Tab > Customize and make the email link point to your email program. You should now be able to right-click a document or photograph > Send To > Mail Recipient > and key in your email details.
    2. In Vista. Right-click the Windows Orb (Start) > Properties > Start Menu Tab > Customize and make the email link point to your email program. You should now be able to right-click a document or photograph > Send To > Mail Recipient > and key in your email details.
    spook
    Thanks. The "right" click on docs etc. works fine. My problem is when I try to send a "link by e-mail" via OE from IE I get the "Not Implemented" message. When I select "Page by e-mail" it works fine.
