Seeking help to interpret MiniDumps
Discussion in 'Windows XP' started by whatboutbob, 2009/03/23.
  1. 2009/03/23
    whatboutbob
    whatboutbob Inactive Thread Starter
    Hi folks,
    I've a big favour to ask. Is someone able to interpret the minidumps below to point me in the right direction to resolve a sporadic (once or twice / week) BSOD issue I've been having (somewhat embarrassingly) pretty much since I built a PC ~ a year ago.
    I don't usually like to admit defeat, but I've spent weeks reading through countless threads on here / hundreds of articles/blog posts elsewhere, but I'm just chasing my tail.
    I assume (probably incorrectly) that it is a driver issue, but have been unable to determine which driver.
    Anyway, below are the last few minidumps - please let me know if you need any further info from me (I don't mean to get presumptuous, but many thanks in advance!!!!):
    Microsoft (R) Windows Debugger Version 6.11.0001.404 X86
    Loading Dump File [C:\WINDOWS.1\Minidump\Mini032309-01.dmp]
    Symbol search path is: srv*C:\SymbolCache*http://msdl.microsoft.com/download/symbols
    Executable search path is:
    Windows XP Kernel Version 2600 (Service Pack 2) UP Free x86 compatible
    Product: WinNt, suite: TerminalServer SingleUserTS
    Built by: 2600.xpsp.050928-1517
    Machine Name:
    Kernel base = 0x804d7000 PsLoadedModuleList = 0x80553320
    Debug session time: Mon Mar 23 23:11:43.203 2009 (GMT+11)
    System Uptime: 2 days 9:03:40.786
    Loading Kernel Symbols
    Loading User Symbols
    Loading unloaded module list
    * Bugcheck Analysis *
    BugCheck 1000000A, {eff0c7b3, 2, 1, 805004a1}
    Probably caused by : hardware ( nt!KiWaitTest+15 )
    Followup: MachineOwner
    kd> !analyze -v
    IRQL_NOT_LESS_OR_EQUAL (a)
    interrupt request level (IRQL) that is too high. This is usually
    caused by drivers using improper addresses.
    If a kernel debugger is available get the stack backtrace.
    Arguments:
    Arg1: eff0c7b3, memory referenced
    Arg2: 00000002, IRQL
    Arg3: 00000001, bitfield :
    bit 0 : value 0 = read operation, 1 = write operation
    bit 3 : value 0 = not an execute operation, 1 = execute operation (only on chips which support this level of status)
    Arg4: 805004a1, address which referenced memory
    Debugging Details:
    WRITE_ADDRESS: eff0c7b3
    CURRENT_IRQL: 2
    FAULTING_IP:
    nt!KiWaitTest+15
    805004a1 088b038955f8 or byte ptr [ebx-7AA76FDh],cl
    CUSTOMER_CRASH_COUNT: 1
    BUGCHECK_STR: 0xA
    PROCESS_NAME: firefox.exe
    MISALIGNED_IP:
    nt!KiWaitTest+15
    LAST_CONTROL_TRANSFER: from 804ff2b8 to 805004a1
    STACK_TEXT:
    f79b3e98 804ff2b8 485472ed 00000032 f79b3fc0 nt!KiWaitTest+0x15
    f79b3fa4 804ff477 48547251 000001de ffdff000 nt!KiTimerListExpire+0x7a
    f79b3fd0 80540ead 80552100 00000000 00c89b32 nt!KiTimerExpiration+0xaf
    f79b3ff4 80540b7a f341ad44 00000000 00000000 nt!KiRetireDpcList+0x46
    f79b3ff8 f341ad44 00000000 00000000 00000000 nt!KiDispatchInterrupt+0x2a
    WARNING: Frame IP not in any known module. Following frames may be wrong.
    80540b7a 00000000 00000009 bb835675 00000128 0xf341ad44
    STACK_COMMAND: kb
    FOLLOWUP_IP:
    nt!KiWaitTest+15
    SYMBOL_STACK_INDEX: 0
    SYMBOL_NAME: nt!KiWaitTest+15
    FOLLOWUP_NAME: MachineOwner
    IMAGE_NAME: hardware
    DEBUG_FLR_IMAGE_TIMESTAMP: 0
    MODULE_NAME: hardware
    FAILURE_BUCKET_ID: IP_MISALIGNED
    Loading Dump File [C:\WINDOWS.1\Minidump\Mini031509-01.dmp]
    Machine Name:
    Debug session time: Sun Mar 15 09:48:10.826 2009 (GMT+11)
    System Uptime: 0 days 6:06:21.122
    BugCheck 100000D1, {c5dd66e3, 5, 0, f73f5c16}
    Probably caused by : atapi.sys ( atapi!AtapiInterrupt+564 )
    kd> !analyze -v
    DRIVER_IRQL_NOT_LESS_OR_EQUAL (d1)
    If kernel debugger is available get stack backtrace.
    Arguments:
    Arg1: c5dd66e3, memory referenced
    Arg2: 00000005, IRQL
    Arg3: 00000000, value 0 = read operation, 1 = write operation
    Arg4: f73f5c16, address which referenced memory
    Debugging Details:
    READ_ADDRESS: c5dd66e3
    CURRENT_IRQL: 5
    FAULTING_IP:
    f73f5c16 ff7324 push dword ptr [ebx+24h]
    BUGCHECK_STR: 0xD1
    PROCESS_NAME: Idle
    LAST_CONTROL_TRANSFER: from f73f865a to f73f5c16
    STACK_TEXT:
    80548f08 f73f865a 50fcb370 86fc926c 80548fd0 atapi!AtapiInterrupt+0x564
    80548f1c 8054086d 86fc9008 86fcb030 00010005 atapi!IdePortInterrupt+0x18
    80548f1c f76d1c4e 86fc9008 86fcb030 00010005 nt!KiInterruptDispatch+0x3d
    80548fd0 80540e10 00000000 0000000e 00000000 processr!AcpiC1Idle+0x12
    80548fd4 00000000 0000000e 00000000 00000000 nt!KiIdleLoop+0x10
    STACK_COMMAND: kb
    FOLLOWUP_IP:
    SYMBOL_NAME: atapi!AtapiInterrupt+564
    MODULE_NAME: atapi
    IMAGE_NAME: atapi.sys
    DEBUG_FLR_IMAGE_TIMESTAMP: 42cb1b92
    FAILURE_BUCKET_ID: 0xD1_atapi!AtapiInterrupt+564
    Loading Dump File [C:\WINDOWS.1\Minidump\Mini030709-01.dmp]
    Machine Name:
    Debug session time: Sat Mar 7 12:54:09.421 2009 (GMT+11)
    System Uptime: 0 days 2:37:52.000
    BugCheck 1000007F, {8, 80042000, 0, 0}
    *** WARNING: Unable to verify timestamp for SiWinAcc.sys
    *** ERROR: Module load completed but symbols could not be loaded for SiWinAcc.sys
    Probably caused by : hardware ( SiWinAcc+325 )
    kd> !analyze -v
    UNEXPECTED_KERNEL_MODE_TRAP_M (1000007f)
    This means a trap occurred in kernel mode, and it's a trap of a kind
    that the kernel isn't allowed to have/catch (bound trap) or that
    is always instant death (double fault). The first number in the
    bugcheck params is the number of the trap (8 = double fault, etc)
    Consult an Intel x86 family manual to learn more about what these
    traps are. Here is a *portion* of those codes:
    If kv shows a taskGate
    use .tss on the part before the colon, then kv.
    Else if kv shows a trapframe
    use .trap on that value
    Else
    .trap on the appropriate frame will show where the trap was taken
    (on x86, this will be the ebp that goes with the procedure KiTrap)
    Endif
    kb will then show the corrected stack.
    Arguments:
    Arg1: 00000008, EXCEPTION_DOUBLE_FAULT
    Arg2: 80042000
    Arg3: 00000000
    Arg4: 00000000
    Debugging Details:
    BUGCHECK_STR: 0x7f_8
    PROCESS_NAME: jqs.exe
    MISALIGNED_IP:
    nt!MiLocateAndReserveWsle+a
    80502a6e c3 ret
    LAST_CONTROL_TRANSFER: from 8051163b to 80502a6e
    STACK_TEXT:
    f2db0894 8051163b c6081000 c0630408 81ea5cb0 nt!MiLocateAndReserveWsle+0xa
    f2db08cc 80512d28 00000000 c6081000 c0630408 nt!MiCompleteProtoPteFault+0x1c5
    f2db0944 8051bf00 e13ca608 c6081000 c0630408 nt!MiDispatchFault+0x618
    f2db09a8 805170a0 00000000 c6081000 00000000 nt!MmAccessFault+0x7b4
    f2db0a04 8055d860 c6081000 00000000 85633c20 nt!MmCheckCachedPageState+0x56c
    f2db0a90 f72c2368 855f9028 f2db0b44 00001000 nt!CcCopyRead+0x3da
    f2db0b6c f72c2016 855c4008 85633c08 00000001 Ntfs!NtfsCommonRead+0xcc2
    f2db0c0c 804edf35 86bea340 85633c08 86f6b270 Ntfs!NtfsFsdRead+0x22d
    f2db0c1c f7363459 f2db0c6c 804edf35 86beabf0 nt!IopfCallDriver+0x31
    f2db0c24 804edf35 86beabf0 85633c08 86f6a4e0 sr!SrPassThrough+0x31
    f2db0c34 f79a4325 f79a49ea 86bdef00 85633c08 nt!IopfCallDriver+0x31
    f2db0c6c 804edf35 86bdef00 86beabf0 806d02d0 SiWinAcc+0x325
    f2db0c7c 80573cd6 85633dbc 85633c08 855f9028 nt!IopfCallDriver+0x31
    f2db0c90 80570d1e 86bdef00 85633c08 855f9028 nt!IopSynchronousServiceTail+0x60
    f2db0d38 8053c958 00000214 00000000 00000000 nt!NtReadFile+0x580
    f2db0d38 7c90eb94 00000214 00000000 00000000 nt!KiFastCallEntry+0xf8
    00acfbf0 00000000 00000000 00000000 00000000 0x7c90eb94
    STACK_COMMAND: kb
    FOLLOWUP_IP:
    SiWinAcc+325
    f79a4325 ?? ???
    SYMBOL_STACK_INDEX: b
    SYMBOL_NAME: SiWinAcc+325
    Loading Dump File [C:\WINDOWS.1\Minidump\Mini030409-01.dmp]
    Machine Name:
    Debug session time: Wed Mar 4 12:57:42.734 2009 (GMT+11)
    System Uptime: 2 days 3:00:26.316
    BugCheck 19, {20, 86be6d60, 86be7350, abe6d68}
    Probably caused by : ntkrnlpa.exe ( nt!ExFreePoolWithTag+2a0 )
    kd> !analyze -v
    BAD_POOL_HEADER (19)
    The pool is already corrupt at the time of the current request.
    This may or may not be due to the caller.
    The internal pool links must be walked to figure out a possible cause of
    the problem, and then special pool applied to the suspect tags or the driver
    verifier to a suspect driver.
    Arguments:
    Arg1: 00000020, a pool block header size is corrupt.
    Arg2: 86be6d60, The pool entry we were looking for within the page.
    Arg3: 86be7350, The next pool entry.
    Arg4: 0abe6d68, (reserved)
    Debugging Details:
    BUGCHECK_STR: 0x19_20
    POOL_ADDRESS: 86be6d60
    PROCESS_NAME: BrMfcMon.exe
    LAST_CONTROL_TRANSFER: from 80543e06 to 804f8a51
    STACK_TEXT:
    f3456c34 80543e06 00000019 00000020 86be6d60 nt!KeBugCheckEx+0x1b
    f3456c84 805b550f 86be6d68 e56c6946 86fe9090 nt!ExFreePoolWithTag+0x2a0
    f3456ca8 805af6db 86be6d70 00000000 00000000 nt!ObpFreeObject+0x18d
    f3456cc0 80521f73 86be6d88 00000000 000000e8 nt!ObpRemoveObjectRoutine+0xe7
    f3456ce4 805b06d3 856929e0 e248d180 855ccbd8 nt!ObfDereferenceObject+0x5f
    f3456cfc 805b0769 e248d180 86be6d88 000000e8 nt!ObpCloseHandleTableEntry+0x155
    f3456d44 805b08a1 000000e8 00000001 00000000 nt!ObpCloseHandle+0x87
    f3456d58 8053c958 000000e8 00c1fa6c 7c90eb94 nt!NtClose+0x1d
    f3456d58 7c90eb94 000000e8 00c1fa6c 7c90eb94 nt!KiFastCallEntry+0xf8
    00c1fa6c 00000000 00000000 00000000 00000000 0x7c90eb94
    STACK_COMMAND: kb
    FOLLOWUP_IP:
    80543e06 8b45f8 mov eax,dword ptr [ebp-8]
    SYMBOL_STACK_INDEX: 1
    SYMBOL_NAME: nt!ExFreePoolWithTag+2a0
    MODULE_NAME: nt
    IMAGE_NAME: ntkrnlpa.exe
    DEBUG_FLR_IMAGE_TIMESTAMP: 433b28b7
    FAILURE_BUCKET_ID: 0x19_20_nt!ExFreePoolWithTag+2a0
    Loading Dump File [C:\WINDOWS.1\Minidump\Mini022809-01.dmp]
    Machine Name:
    Debug session time: Sat Feb 28 17:57:36.258 2009 (GMT+11)
    System Uptime: 3 days 21:43:49.748
    BugCheck C2, {7, cd4, 7ee, 85c1c65c}
    Probably caused by : afd.sys ( afd!AfdFreeConnectionResources+38 )
    kd> !analyze -v
    BAD_POOL_CALLER (c2)
    The current thread is making a bad pool request. Typically this is at a bad IRQL level or double freeing the same allocation, etc.
    Arguments:
    Arg1: 00000007, Attempt to free pool which was already freed
    Arg2: 00000cd4, (reserved)
    Arg3: 000007ee, Memory contents of the pool block
    Arg4: 85c1c65c, Address of the block of pool being deallocated
    Debugging Details:
    BUGCHECK_STR: 0xc2_7
    PROCESS_NAME: System
    STACK_TEXT:
    f79d7c64 80543e06 000000c2 00000007 00000cd4 nt!KeBugCheckEx+0x1b
    f79d7cb4 805b54c9 85c1c65c 00000000 00000000 nt!ExFreePoolWithTag+0x2a0
    f79d7ce4 805af6db 859f0768 00000000 00000000 nt!ObpFreeObject+0x147
    f79d7cfc 80521f73 859f0780 00000000 80521f14 nt!ObpRemoveObjectRoutine+0xe7
    f79d7d20 f59cf9fd 85a214b0 85a21438 f59cccb6 nt!ObfDereferenceObject+0x5f
    f79d7d34 f59cf9aa 85a21438 f59ce7a8 f79d7d60 afd!AfdFreeConnectionResources+0x38
    f79d7d44 f59cc86a 85a214b0 85b5d490 85b79490 afd!AfdFreeConnection+0x5c
    f79d7d60 8056ad5b 85b79490 00000000 8055a37c afd!AfdDoWork+0x51
    f79d7d74 80533f22 85b5d490 00000000 86fc4da8 nt!IopProcessWorkItem+0x13
    f79d7dac 805c4bc0 85b5d490 00000000 00000000 nt!ExpWorkerThread+0x100
    f79d7ddc 805410f2 80533e22 00000001 00000000 nt!PspSystemThreadStartup+0x34
    00000000 00000000 00000000 00000000 00000000 nt!KiThreadStartup+0x16
    STACK_COMMAND: kb
    FOLLOWUP_IP:
    f59cf9fd 895e0c mov dword ptr [esi+0Ch],ebx
    SYMBOL_STACK_INDEX: 5
    SYMBOL_NAME: afd!AfdFreeConnectionResources+38
    MODULE_NAME: afd
    IMAGE_NAME: afd.sys
    DEBUG_FLR_IMAGE_TIMESTAMP: 41107eb5
    FAILURE_BUCKET_ID: 0xc2_7_afd!AfdFreeConnectionResources+38
  2. 2009/03/24
    I doubt we can help you with this. The few people that are capable of reading these dumps are no longer visiting WindowsBBS.
    I'd suggest testing your hardware.
    pjamme
    pjamme Inactive
    whatboutbob
    ok, thanks guys.
