security problem downloading 7.1
Discussion in 'Firefox, Thunderbird & SeaMonkey' started by fp2nc, 2004/05/01.
  1. 2004/05/01
    fp2nc
    fp2nc Inactive Thread Starter
    Hi! I'm trying to d/l 7.1 to my p.c.( win98se, newest free zonelabs) but keep getting an error that says because of my security settings, I can't download it. Any idea what I need to change? I'm using ns4.72 to download with. Thanx in advance.
  2. 2004/05/01
    Ramona
    Ramona Geek Member Alumni
    Welcome to the Forum, fp2nc!
    Hi fp2nc,
    Check your settings in Zone Alarm:
    Try lowering Trusted Zone security to medium.
    Disengage the Internet lock, if engaged.
    Go through all the settings to see if you have inadvertently changed a setting that is causing this problem.
    Ramona :)
    fp2nc
    Thanks for replying! I checked ZA and settings are where you suggested. I am still getting the same message when trying to d/l. Would it do any good to try to d/l from a different site?
  5. 2004/05/01
    Ramona
    fp2nc,
    Try this site, and see if the same thing happens. If it does, then disable Zone Alarm and try downloading.
    Ramona :)
  6. 2004/05/01
    fp2nc
    Is this a d/l for 7.0 or 7.1?
  7. 2004/05/01
    Ramona
    Big fat double DUH!!! Might be nice if I gave you the link...
    http://sillydog.org/narchive/sd/71.html
    It's for Netscape 7.1, and if you do a "Custom" install you can select which components you like. That is, if you are able to download.
    Ramona :)
  8. 2004/05/01
    fp2nc
    That does help. Before I try again, I read that 7.1 might not work well on win98se or is it just on the first win98( something about resources )? I don't want to d/l and set myself up for more problems.
    I went to the link you gave me and saw that was where I read about the resource leak. I looked at the problem link and the work-around link and both seem to be about a year old. Has anything changed since then or do you think I should d/l 7.02 instead?
  9. 2004/05/01
    Ramona
    fp2nc,
    Nothing has changed, and if you want my suggestion for a browser, then I suggest Mozilla 1.6. This is a very stable browser, fast, and doesn't have the resource leak. Or if you want to wait, AOL plans a new Netscape release in early summer, which will be based on Mozilla 1.7 code.
    Ramona :)
