Resolved Seamonkey Email & Composer Printing Problems
Discussion in 'Firefox, Thunderbird & SeaMonkey' started by car13lin, 2016/08/18.
  1. 2016/08/18
    car13lin
    car13lin Well-Known Member Thread Starter
    Seamonkey (Latest version) will not print Email or Composed message drafts (Before they are sent). Ex: I write an address and want to print it to use as a label.... Won't do it. I must send it first. Then it will print.
    I've had similar problems before and used 2.30 (?) and avoided updates because several had strange quirks. I installed latest version when I changed to Windows 10.
  2. 2016/08/18
    Works OK in TB.
    BOBBO
    BOBBO Geek Member
    When you have the message open and you click on File>Print Preview, does the message show up there OK?
  5. 2016/08/19
    car13lin
    Bobbo-
    Yes it does!!! And, it prints after I've previewed. Any idea why?
    As I mentioned I tried several versions of Seamonkey. All had quirks except 2.30 (I think) which worked well for me.
    With your advise to work around this little glitch I'll keep this version. I DO ENJOY SEAMONKEY! I've used it for years.
    THANK YOU VERY MUCH-
    Carl
    I'll mark thread as solved.
