Resolved SeaMonkey 2.21 Email Compose Spell Check Problem
Discussion in 'Firefox, Thunderbird & SeaMonkey' started by car13lin, 2013/10/31.
  1. 2013/10/31
    car13lin
    car13lin Well-Known Member Thread Starter
    SeaMonkey 2.21:
    Auto Spell Check only works about 50-60% of the time IN THE COMPOSE MESSAGE AREA. It works fine in every other box including the Email SUBJECT line.
    I have Re-installed several times and checked settings (O to 1,etc.). I can't find anything on Mozilla/SeaMonkey...regarding this go/no-go issue. Then I remembered Windows BBS.
    Frustrating! Winter is coming. I can't afford to loose any more hair!!!
    Thanks,
    Carl
  2. 2013/10/31
    James Martin
    James Martin Geek Member
    I hate I can't offer any help with this issue other than to tell you about a program called Tiny Spell.
    My aunt uses it as a spell checker for Windows 8 Word Pad, and it also checks the spelling of typed words in most any other application, too. It's not a bad little program.
    EDIT: There is a newer version of Sea Monkey available...​
    Maybe this new release will address your problem.​
    car13lin
    James-
    Thanks for your response.
    I just downloaded 2.22 and tried spell-check several times. OK so far.
    I'll keep Tiny Spell in mind.
    This was a frustrating problem because it only occurred some of the time. I've been using SeaMonkey for a very long time and love it!!!
    I'll mark the problem solved and keep my fingers crossed.
    Carl
  5. 2013/11/01
    James Martin
    Glad I could be of some help, car13lin. :)
