SD Card is 3 GB less than it should be
Discussion in 'PC Hardware' started by CPUDude521, 2009/05/23.
  1. 2009/05/23
    CPUDude521
    CPUDude521 Inactive Thread Starter
    Alright so I got a 4 GB SD card that I was told to format with a program called SDFormatter. Well I used it and it shrunk the space on my card to less than 1 GB. I tried formatting it again with every option the program has and nothing changes. Can someone help?
  2. 2009/05/23
    Whiskeyman Inactive Alumni
    From what I read SD Formatter is not to be used on SD cards over 1GB in size. Also this program and some readers have an issue with formatting the entire card. I would try another formatting utilty.
    CPUDude521
    Well I tried both programs mentioned here but neither worked. Are there any other options?
  5. 2009/05/24
    Is your reader SDHC capable? Did you try the HP USB Disk Storage Format Tool? Is your card a Sandisk?
  6. 2009/05/24
    CPUDude521
    The card is a Transcend 4 GB non-HC so it should be compatible. It's also in FAT format. And I did try the HP USB Formatting Tool with pretty much every option possible. FAT, FAT16, FAT32, NTFS, etc. All of them either left the capacity the same or lost a little bit of space that I could get back by reformatting it back to FAT.
  7. 2009/05/24
    I would guess that it is a problem with the card reader not able to format beyond 1GB.
  8. 2009/05/24
    CPUDude521
    Thanks that was the problem. I was using a junky USB reader but it worked fine when I tried it on another computer's built in reader.
