Resolved Script error continuous
Discussion in 'Windows 7' started by garsar, 2011/07/21.
  1. 2011/07/21
    garsar
    garsar Well-Known Member Thread Starter
    Suddenly getting continuous script werror notification box. Took IE8 out of computer. Use FF 3.6 (hate 4).
    In the error box: cannot create file when already exists.
    https:secure.wlxrs.com/N4AGNifi3Dhv9tELZE8B9Q/loader.cxp.is
    Do not have to be online but it does happen when online.
    Am on an all the time connection.
    My Win7 updates are uptodate. Same for FF up to 4.
    Wondering why suddenly happening and if it's a java or FF problem. Ran malwarebytes and it picked up something but hasn't changed anything. Read that it could be a spyware issue but ran spybot and lavasoft and still getting it. Whether I click yes or no on the scriptt error it keeps on coming.
    Anyone else have this happen? Any advice as to a solution.
  2. 2011/07/21
    https:secure.wlxrs.com is a Microsoft site for Windows Live.
    You probably have one or more Windows Live products running, or when run the error is produced.
    And you'd be better off using Firefox 5 now.
    garsar
    script error
    Thanks Tony. I found the same thing as I kept digging deeper. Was Windows Live. Appreciate the input as was not quite sure till I read your reply. Reworked FF to not be the problem.
    Interesting you mention FF5. Didn't care for FF4, basically if I wanted that interface, I'd use Chrome, which I sometimes do. Will look at 5. Really appreciate the reply.
  5. 2011/07/22
    You're welcome!
    FYI, FF interface can easily be customized. Just rt click the top toolbar area and select "customize ". Once the customize toolbar window opens you can drag & drop back and forth, and you can even move the buttons that are already on the toolbar.
    This is what my FF5 looks like, not much different than FF3.x versions:
      File size:
      123.7 KB
      8
    garsar likes this.
