Screen Saver not function properly
Discussion in 'Windows XP' started by Nickhm, 2004/05/27.
  1. 2004/05/27
    Nickhm
    Nickhm Inactive Thread Starter
    Occasionally screen saver won’t come on automatically. Been this way since day one. Windows XP PRO….
    He climbs the highest who helps another up. Zig Ziglar
  2. 2004/05/27
    Most likely the PC is doing something the screensaver piece thinks is user activity so it doesn't start.
    I know this isn't very specific or helpful but you will need more info. Check your event logs for possible entries that might give you a clue.
    You might also try setting a different delay time for the thing to start and see if that helps. No idea why but it sometimes does.
    Nickhm
    Scrensaver not functioning properly
    I will work from there. You have to know where to start.
    THANK YOU.... :)
    Joy is not the absence of trouble but the presence of Christ. -
    Vance Haven
  5. 2004/05/27
    Hopefully it will work. If not, post back.
    Johanna
    Johanna Inactive Alumni
    I constantly toggle mine from 3 minutes to 4 minutes. I don't know why, but it "sticks ", too. I have a QL icon directly to it for when my kids burst in and I'm doing something private. I'll tell you how to do that if you want to know.
    Johanna
  7. 2004/05/28
    BillyBob Inactive
    I was having the same problem plus other display problems. ( with the BBS no less )
    Come time to get down and dirty and check into things it was the SS itself that was causing the problem.
    Since I changed the SS a couple of hours ago the problem(s) have seemed to be gone.
    BillyBob
  8. 2004/05/28
    Nickhm
    Billy Bob,
    If that works out OK I will try it :)
    I can run system restore & it works OK for about two weeks. Been doing this for two years.
  9. 2004/05/28
    Nickhm
    Joanna,
    If I don't get it to work properly I may have to get you to tell me how to install icon....Look @ the quote on Newt's advice....:)
