scanner problem:LEXMARK X63
Discussion in 'PC Hardware' started by Jerry72, 2003/04/19.
  1. 2003/04/19
    Jerry72
    Jerry72 Inactive Thread Starter
    Just installed a All-in-One LEXMARK X63(Printer-scanner-fax).The printer works fine,but the scanner does not.I can not copy either.When I fax a document,the other party receives a blank page.If they try to fax me,they say that the phone does not pick up.Win 98.USB port(PC card).
    Jerry
  2. 2003/04/20
    Dennis L Inactive Alumni
    Hi Jerry72
    When I fax a document, the other party receives a blank page.
    The most commom problem, you have the print side up. When you place them in the document feeder, they "generally" have to be print side down. IF you have been doing it that way, then reverse what you been doing. Never used a X63, most require print side down.
    If they try to fax me, they say that the phone does not pick up.
    The printer may be in telephone mode. (per Lexmart F&Q)
    Lexmart X63 - support - Type the word... FAXING ...in search field
