Solved Rundll32.exe booting problems
Discussion in 'Malware and Virus Removal Archive' started by mahisa78, 2010/11/22.
  1. 2010/11/22
    mahisa78
    mahisa78 Inactive Thread Starter
    [Resolved] Rundll32.exe booting problems
    I think I have a virus in my laptop. When I shut down my laptop, there will be a flash of BSOD then my computer will just restart. When I entered my desktop, usually there will be a box that says "Setting Up Personalized Setting For C:\Windows\System\Run\Rundll32.exe ". It will just hang there and I have to turn of all Rundll32.exe via Task Manager so that I can access my desktop. After that, usually there will be a second explorer.exe that I must close or else the computer will hang. My computer will sometimes restart by itself like when I scan it by GMER and when I try to quarantine the viruses by SuperAntiSpyware. When I run SuperAntiSpyware, I get this error "The Ordinal 325 could not be located in the dynamic link library SHDOCVW.dll "
    MBAM-Log
    Malwarebytes' Anti-Malware 1.46
    www.malwarebytes.org
    Database version: 4052
    Windows 5.1.2600 Service Pack 3
    Internet Explorer 6.0.2900.2180
    11/22/2010 4:42:07 PM
    mbam-log-2010-11-22 (16-42-07).txt
    Scan type: Quick scan
    Objects scanned: 135132
    Time elapsed: 8 minute(s), 14 second(s)
    Memory Processes Infected: 0
    Memory Modules Infected: 1
    Registry Keys Infected: 4
    Registry Values Infected: 1
    Folders Infected: 0
    Files Infected: 9
    (No malicious items detected)
    C:\WINDOWS\system32\winmty32.dll (Trojan.Agent) -> Delete on reboot.
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Active Setup\Installed Components\{m2g84f8g-7v0g-v6td-4ww3-s314pppo1143} (Generic.Bot.H) -> Quarantined and deleted successfully.
    HKEY_CURRENT_USER\SOFTWARE\Trymedia Systems (Adware.TryMedia) -> Quarantined and deleted successfully.
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\MSSMGR (Trojan.Downloader) -> Quarantined and deleted successfully.
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon\Notify\winmty32 (Trojan.Dialer) -> Quarantined and deleted successfully.
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run\adobe flash installer (Trojan.Agent) -> Quarantined and deleted successfully.
    Folders Infected:
    Files Infected:
    C:\WINDOWS\system\run\rundll32.exe (Generic.Bot.H) -> Quarantined and deleted successfully.
    C:\Documents and Settings\Mahisa Andara\Local Settings\Temp\IELOGIN.abc (Malware.Trace) -> Quarantined and deleted successfully.
    C:\WINDOWS\system32:Shdll.exe (Trojan.Agent) -> Quarantined and deleted successfully.
    C:\Documents and Settings\Mahisa Andara\Local Settings\Temp\UuU.uUu (Malware.Trace) -> Quarantined and deleted successfully.
    C:\Documents and Settings\Mahisa Andara\Local Settings\Temp\XxX.xXx (Malware.Trace) -> Delete on reboot.
    C:\WINDOWS\system32\wineay32.dll (Trojan.Agent) -> Quarantined and deleted successfully.
    C:\WINDOWS\system32\winqto32.dll (Trojan.Agent) -> Quarantined and deleted successfully.
    C:\WINDOWS\system32\winugy32.dll (Trojan.Agent) -> Quarantined and deleted successfully.
    GMER log
    GMER 1.0.15.15530 - http://www.gmer.net
    Rootkit scan 2010-11-22 19:49:04
    Windows 5.1.2600 Service Pack 3 Harddisk0\DR0 -> \Device\Ide\IdeDeviceP0T0L0-3 WDC_WD1600BEVS-00UST0 rev.01.01A01
    Running: v67crihq.exe; Driver: C:\DOCUME~1\MAHISA~1\LOCALS~1\Temp\kwtdypog.sys
    ---- System - GMER 1.0.15 ----
    SSDT E1C0E1C0 ZwConnectPort
    ---- Devices - GMER 1.0.15 ----
    AttachedDevice \FileSystem\Ntfs \Ntfs SYMEVENT.SYS (Symantec Event Library/Symantec Corporation)
    AttachedDevice \Driver\Tcpip \Device\Ip SYMTDI.SYS (Network Dispatch Driver/Symantec Corporation)
    AttachedDevice \Driver\Tcpip \Device\Tcp SYMTDI.SYS (Network Dispatch Driver/Symantec Corporation)
    AttachedDevice \Driver\Tcpip \Device\Udp SYMTDI.SYS (Network Dispatch Driver/Symantec Corporation)
    AttachedDevice \Driver\Tcpip \Device\RawIp SYMTDI.SYS (Network Dispatch Driver/Symantec Corporation)
    ---- Registry - GMER 1.0.15 ----
    Reg HKLM\SYSTEM\CurrentControlSet\Services\BTHPORT\Parameters\Keys\001f81000200
    Reg HKLM\SYSTEM\CurrentControlSet\Services\BTHPORT\Parameters\Keys\001f81000250
    Reg HKLM\SYSTEM\CurrentControlSet\Services\BTHPORT\Parameters\Keys\001f81000250@5fc1f2a26601 0xDF 0x2C 0x8D 0x6C ...
    Reg HKLM\SYSTEM\ControlSet002\Services\BTHPORT\Parameters\Keys\001f81000200 (not active ControlSet)
    Reg HKLM\SYSTEM\ControlSet002\Services\BTHPORT\Parameters\Keys\001f81000250 (not active ControlSet)
    Reg HKLM\SYSTEM\ControlSet002\Services\BTHPORT\Parameters\Keys\001f81000250@5fc1f2a26601 0xDF 0x2C 0x8D 0x6C ...
    Reg HKLM\SOFTWARE\Classes\CLSID\{33D9A760-90C8-11d0-BD43-00A0C911CE86}\Instance\Indeo
    Reg HKLM\SOFTWARE\Classes\CLSID\{33D9A760-90C8-11d0-BD43-00A0C911CE86}\Instance\Indeo@FriendlyName Indeo? video 5.10 Compression Filter
    Reg HKLM\SOFTWARE\Classes\CLSID\{33D9A760-90C8-11d0-BD43-00A0C911CE86}\Instance\Indeo@CLSID {1F73E9B1-8C3A-11D0-A3BE-00A0C9244436}
    Reg HKLM\SOFTWARE\Classes\CLSID\{33D9A760-90C8-11d0-BD43-00A0C911CE86}\Instance\Indeo@FilterData 0x02 0x00 0x00 0x00 ...
    Reg HKLM\SOFTWARE\Classes\CLSID\{33D9A760-90C8-11d0-BD43-00A0C911CE86}\Instance\Indeo@EncoderType 1
    Reg HKLM\SOFTWARE\Classes\CLSID\{33D9A761-90C8-11d0-BD43-00A0C911CE86}\Instance\Indeo
    Reg HKLM\SOFTWARE\Classes\CLSID\{33D9A761-90C8-11d0-BD43-00A0C911CE86}\Instance\Indeo@FriendlyName Indeo? audio software
    Reg HKLM\SOFTWARE\Classes\CLSID\{33D9A761-90C8-11d0-BD43-00A0C911CE86}\Instance\Indeo@CLSID {B4CA2970-DD2B-11D0-9DFA-00AA00AF3494}
    Reg HKLM\SOFTWARE\Classes\CLSID\{33D9A761-90C8-11d0-BD43-00A0C911CE86}\Instance\Indeo@FilterData 0x02 0x00 0x00 0x00 ...
    Reg HKCU\Software\Microsoft\Windows\CurrentVersion\Shell Extensions\Approved\{73F8686D-FDAF-F515-4E11-8ABCC6BB7C6D}
    ---- EOF - GMER 1.0.15 ----
    MBRCheck Log
    MBRCheck, version 1.2.3
    (c) 2010, AD
    Command-line:
    Windows Version: Windows XP Professional
    Windows Information: Service Pack 3 (build 2600)
    Logical Drives Mask: 0x0000003c
    Kernel Drivers (total 136):
    0x804D7000 \WINDOWS\system32\ntkrnlpa.exe
    0x806E4000 \WINDOWS\system32\hal.dll
    0xF7B0D000 \WINDOWS\system32\KDCOM.DLL
    0xF7A1D000 \WINDOWS\system32\BOOTVID.dll
    0xF74DE000 ACPI.sys
    0xF7B0F000 \WINDOWS\system32\DRIVERS\WMILIB.SYS
    0xF74CD000 pci.sys
    0xF760D000 isapnp.sys
    0xF7A21000 compbatt.sys
    0xF7A25000 \WINDOWS\system32\DRIVERS\BATTC.SYS
    0xF7BD5000 pciide.sys
    0xF788D000 \WINDOWS\system32\DRIVERS\PCIIDEX.SYS
    0xF761D000 MountMgr.sys
    0xF74AE000 ftdisk.sys
    0xF7B11000 dmload.sys
    0xF7488000 dmio.sys
    0xF7A29000 ACPIEC.sys
    0xF7BD6000 \WINDOWS\system32\DRIVERS\OPRGHDLR.SYS
    0xF7895000 PartMgr.sys
    0xF762D000 VolSnap.sys
    0xF7470000 atapi.sys
    0xF763D000 disk.sys
    0xF764D000 \WINDOWS\system32\DRIVERS\CLASSPNP.SYS
    0xF7450000 fltmgr.sys
    0xF743E000 sr.sys
    0xF7427000 KSecDD.sys
    0xF739A000 Ntfs.sys
    0xF736D000 NDIS.sys
    0xF765D000 uagp35.sys
    0xF7B13000 speedfan.sys
    0xF7353000 Mup.sys
    0xF7BD7000 giveio.sys
    0xF785D000 \SystemRoot\system32\DRIVERS\intelppm.sys
    0xF7B05000 \SystemRoot\system32\DRIVERS\CmBatt.sys
    0xF7B09000 \SystemRoot\system32\DRIVERS\wmiacpi.sys
    0xF6F6B000 \SystemRoot\system32\DRIVERS\sisgrp.sys
    0xF6F57000 \SystemRoot\system32\DRIVERS\VIDEOPRT.SYS
    0xF786D000 \SystemRoot\system32\DRIVERS\i8042prt.sys
    0xF7945000 \SystemRoot\system32\DRIVERS\kbdclass.sys
    0xF794D000 \SystemRoot\system32\DRIVERS\mouclass.sys
    0xF7955000 \SystemRoot\system32\DRIVERS\usbohci.sys
    0xF6F33000 \SystemRoot\system32\DRIVERS\USBPORT.SYS
    0xF795D000 \SystemRoot\system32\DRIVERS\usbehci.sys
    0xF787D000 \SystemRoot\system32\DRIVERS\SiSGbeXP.sys
    0xF767D000 \SystemRoot\system32\DRIVERS\imapi.sys
    0xF768D000 \SystemRoot\system32\DRIVERS\cdrom.sys
    0xF769D000 \SystemRoot\system32\DRIVERS\redbook.sys
    0xF6F10000 \SystemRoot\system32\DRIVERS\ks.sys
    0xF6EFC000 \SystemRoot\system32\DRIVERS\sdbus.sys
    0xF6ED4000 \SystemRoot\system32\DRIVERS\HDAudBus.sys
    0xF732B000 \SystemRoot\system32\DRIVERS\fsvga.sys
    0xF7D09000 \SystemRoot\system32\DRIVERS\audstub.sys
    0xF76AD000 \SystemRoot\system32\DRIVERS\rasl2tp.sys
    0xF7327000 \SystemRoot\system32\DRIVERS\ndistapi.sys
    0xF6EBD000 \SystemRoot\system32\DRIVERS\ndiswan.sys
    0xF76BD000 \SystemRoot\system32\DRIVERS\raspppoe.sys
    0xF76CD000 \SystemRoot\system32\DRIVERS\raspptp.sys
    0xF7965000 \SystemRoot\system32\DRIVERS\TDI.SYS
    0xF6EAC000 \SystemRoot\system32\DRIVERS\psched.sys
    0xF76DD000 \SystemRoot\system32\DRIVERS\msgpc.sys
    0xF796D000 \SystemRoot\system32\DRIVERS\ptilink.sys
    0xF7975000 \SystemRoot\system32\DRIVERS\raspti.sys
    0xF6E7C000 \SystemRoot\system32\DRIVERS\rdpdr.sys
    0xF76ED000 \SystemRoot\system32\DRIVERS\termdd.sys
    0xF6E5F000 \SystemRoot\system32\DRIVERS\mcdbus.sys
    0xF6E47000 \SystemRoot\system32\DRIVERS\SCSIPORT.SYS
    0xF7B3D000 \SystemRoot\system32\DRIVERS\swenum.sys
    0xF6DE9000 \SystemRoot\system32\DRIVERS\update.sys
    0xF6FE3000 \SystemRoot\system32\DRIVERS\mssmbios.sys
    0xF68F8000 \SystemRoot\system32\drivers\RtkHDAud.sys
    0xF68D4000 \SystemRoot\system32\drivers\portcls.sys
    0xF76FD000 \SystemRoot\system32\drivers\drmk.sys
    0xF67E3000 \SystemRoot\system32\DRIVERS\smserial.sys
    0xF797D000 \SystemRoot\System32\Drivers\Modem.SYS
    0xF770D000 \SystemRoot\System32\Drivers\NDProxy.SYS
    0xF774D000 \SystemRoot\system32\DRIVERS\usbhub.sys
    0xF7B41000 \SystemRoot\system32\DRIVERS\USBD.SYS
    0xA6E21000 \??\C:\Program Files\Symantec AntiVirus\savrt.sys
    0xA6E0E000 \??\C:\Program Files\Symantec\SYMEVENT.SYS
    0xF779D000 \??\C:\Program Files\Symantec AntiVirus\Savrtpel.sys
    0xA6B4C000 \??\C:\PROGRA~1\COMMON~1\SYMANT~1\VIRUSD~1\20091008.003\navex15.sys
    0xA6B38000 \??\C:\PROGRA~1\COMMON~1\SYMANT~1\VIRUSD~1\20091008.003\naveng.sys
    0xF79A5000 \SystemRoot\system32\DRIVERS\usbccgp.sys
    0xA619A000 \SystemRoot\System32\Drivers\usbvideo.sys
    0xF7AED000 \SystemRoot\system32\DRIVERS\hidusb.sys
    0xF77BD000 \SystemRoot\system32\DRIVERS\HIDCLASS.SYS
    0xF79AD000 \SystemRoot\system32\DRIVERS\HIDPARSE.SYS
    0xF7AF1000 \SystemRoot\system32\DRIVERS\mouhid.sys
    0xF7B45000 \SystemRoot\System32\Drivers\Fs_Rec.SYS
    0xF7C2A000 \SystemRoot\System32\Drivers\Null.SYS
    0xF7B4F000 \SystemRoot\System32\Drivers\Beep.SYS
    0xF79BD000 \SystemRoot\System32\drivers\vga.sys
    0xF7B51000 \SystemRoot\System32\Drivers\mnmdd.SYS
    0xF7B53000 \SystemRoot\System32\DRIVERS\RDPCDD.sys
    0xF79C5000 \SystemRoot\System32\Drivers\Msfs.SYS
    0xF79CD000 \SystemRoot\System32\Drivers\Npfs.SYS
    0xF7B01000 \SystemRoot\system32\DRIVERS\rasacd.sys
    0xA6087000 \SystemRoot\system32\DRIVERS\ipsec.sys
    0xA602E000 \SystemRoot\system32\DRIVERS\tcpip.sys
    0xA6008000 \SystemRoot\system32\DRIVERS\ipnat.sys
    0xA5FC8000 \SystemRoot\System32\Drivers\SYMTDI.SYS
    0xF77CD000 \SystemRoot\system32\DRIVERS\wanarp.sys
    0xA5FA0000 \SystemRoot\system32\DRIVERS\netbt.sys
    0xA5F7E000 \SystemRoot\System32\drivers\afd.sys
    0xF77DD000 \SystemRoot\system32\DRIVERS\netbios.sys
    0xF79D5000 \SystemRoot\system32\DRIVERS\srvkp.sys
    0xA5F5C000 \??\C:\Program Files\SUPERAntiSpyware\SASKUTIL.SYS
    0xF79DD000 \??\C:\Program Files\SUPERAntiSpyware\SASDIFSV.SYS
    0xA5F31000 \SystemRoot\system32\DRIVERS\rdbss.sys
    0xA5EC1000 \SystemRoot\system32\DRIVERS\mrxsmb.sys
    0xF77ED000 \SystemRoot\System32\Drivers\Fips.SYS
    0xF780D000 \SystemRoot\System32\Drivers\Cdfs.SYS
    0xA5E81000 \SystemRoot\System32\Drivers\dump_atapi.sys
    0xF7B55000 \SystemRoot\System32\Drivers\dump_WMILIB.SYS
    0xBF800000 \SystemRoot\System32\win32k.sys
    0xA6F2C000 \SystemRoot\System32\drivers\Dxapi.sys
    0xF79ED000 \SystemRoot\System32\watchdog.sys
    0xBF9C3000 \SystemRoot\System32\drivers\dxg.sys
    0xF7D56000 \SystemRoot\System32\drivers\dxgthk.sys
    0xBF9D5000 \SystemRoot\System32\SiSGRV.dll
    0xBFFA0000 \SystemRoot\System32\ATMFD.DLL
    0xA5CDB000 \SystemRoot\system32\DRIVERS\nwlnkipx.sys
    0xA60BA000 \SystemRoot\system32\DRIVERS\nwlnknb.sys
    0xA5E21000 \SystemRoot\system32\DRIVERS\ndisuio.sys
    0xA5ACE000 \SystemRoot\system32\DRIVERS\mrxdav.sys
    0xA5DB1000 \SystemRoot\system32\DRIVERS\nwlnkspx.sys
    0xA5964000 \SystemRoot\system32\DRIVERS\srv.sys
    0xF79FD000 \??\C:\WINDOWS\system32\drivers\WMDrive.sys
    0xA5903000 \SystemRoot\System32\Drivers\Udfs.SYS
    0xA5736000 \SystemRoot\system32\drivers\wdmaud.sys
    0xAAF90000 \SystemRoot\system32\drivers\sysaudio.sys
    0xA53FD000 \SystemRoot\System32\Drivers\HTTP.sys
    0xF7B73000 \??\E:\Program Files\RMClock\RTCore32.sys
    0xA5022000 \??\C:\DOCUME~1\MAHISA~1\LOCALS~1\Temp\kwtdypog.sys
    0xA4AF7000 \SystemRoot\system32\drivers\kmixer.sys
    0x7C900000 \WINDOWS\system32\ntdll.dll
    Processes (total 46):
    0 System Idle Process
    4 System
    620 C:\WINDOWS\system32\smss.exe
    668 csrss.exe
    692 C:\WINDOWS\system32\winlogon.exe
    736 C:\WINDOWS\system32\services.exe
    772 C:\WINDOWS\system32\lsass.exe
    916 C:\WINDOWS\system32\svchost.exe
    984 svchost.exe
    1024 C:\WINDOWS\system32\svchost.exe
    1144 svchost.exe
    1208 svchost.exe
    1380 C:\WINDOWS\system32\spoolsv.exe
    1504 svchost.exe
    1556 C:\Program Files\Symantec AntiVirus\DefWatch.exe
    1720 E:\Program Files\java\ire6\bin\jqs.exe
    1784 C:\Program Files\CyberLink\Shared Files\RichVideo.exe
    1876 C:\WINDOWS\system32\svchost.exe
    2004 alg.exe
    968 C:\WINDOWS\explorer.exe
    1112 C:\Program Files\TortoiseSVN\bin\TSVNCache.exe
    1544 C:\Program Files\CyberLink\Power2Go\CLMLSvc.exe
    1580 C:\Program Files\HP\HP Software Update\hpwuSchd2.exe
    2080 C:\Program Files\CyberLink\PowerDVD\PDVDServ.exe
    2100 C:\WINDOWS\RTHDCPL.exe
    2116 C:\Program Files\Motorola\SMSERIAL\sm56hlpr.exe
    2128 C:\Program Files\Sony Ericsson\Mobile2\Application Launcher\Application Launcher.exe
    2136 C:\PROGRA~1\SYMANT~1\VPTray.exe
    2144 C:\Program Files\Common Files\Java\Java Update\jusched.exe
    2184 C:\Program Files\Common Files\Teleca Shared\CapabilityManager.exe
    2208 C:\WINDOWS\system32\ctfmon.exe
    2392 E:\Program Files\RMClock\RMClock.exe
    2456 C:\Program Files\HP\Digital Imaging\bin\hpqtra08.exe
    2496 C:\WINDOWS\system32\sistray.exe
    2644 C:\Program Files\MagicDisc\MagicDisc.exe
    2744 C:\Program Files\HP\Digital Imaging\bin\hpqste08.exe
    2796 C:\Program Files\Common Files\Teleca Shared\Generic.exe
    2980 C:\Program Files\Sony Ericsson\Mobile2\Mobile Phone Monitor\epmworker.exe
    2244 C:\Documents and Settings\Mahisa Andara\Local Settings\Application Data\Google\Chrome\Application\chrome.exe
    2952 C:\Documents and Settings\Mahisa Andara\Local Settings\Application Data\Google\Chrome\Application\chrome.exe
    2944 C:\Documents and Settings\Mahisa Andara\Local Settings\Application Data\Google\Chrome\Application\chrome.exe
    1808 C:\Documents and Settings\Mahisa Andara\Local Settings\Application Data\Google\Chrome\Application\chrome.exe
    752 C:\PROGRA~1\FREEDO~1\fdm.exe
    4080 C:\Program Files\Adobe\Reader 9.0\Reader\AcroRd32Info.exe
    2300 C:\Documents and Settings\Mahisa Andara\Desktop\MBRCheck.exe
    2228 C:\WINDOWS\system32\conime.exe
    \\.\C: --> \\.\PhysicalDrive0 at offset 0x00000000`00007e00 (NTFS)
    \\.\E: --> \\.\PhysicalDrive0 at offset 0x00000013`8836ac00 (NTFS)
    PhysicalDrive0 Model Number: WDCWD1600BEVS-00UST0, Rev: 01.01A01
    Size Device Name MBR Status
    149 GB \\.\PhysicalDrive0 Windows XP MBR code detected
    SHA1: DA38B874B7713D1B51CBC449F4EF809B0DEC644A
    Done!
    DDS Logs
    DDs
    DDS (Ver_10-11-10.01) - NTFSx86
    Run by Mahisa Andara at 19:59:28.57 on 11/22/2010 Mon
    Internet Explorer: 6.0.2900.2180 BrowserJavaVersion: 1.6.0_22
    Microsoft Windows XP Professional 5.1.2600.3.932.81.1033.18.989.388 [GMT 7:00]
    C:\WINDOWS\system32\svchost -k DcomLaunch
    svchost.exe
    C:\WINDOWS\System32\svchost.exe -k netsvcs
    svchost.exe
    svchost.exe
    svchost.exe
    C:\WINDOWS\system32\svchost.exe -k imgsvc
    C:\Program Files\HP\HP Software Update\HPWuSchd2.exe
    C:\WINDOWS\RTHDCPL.EXE
    C:\Program Files\HP\Digital Imaging\bin\hpqSTE08.exe
    C:\Documents and Settings\Mahisa Andara\Desktop\dds.pif
    BHO: Adobe PDF Link Helper: {18df081c-e8ad-4283-a596-fa578c2ebdc3} - c:\program files\common files\adobe\acrobat\activex\AcroIEHelperShim.dll
    BHO: ATLAS Toolbar: {3c6301ed-0f78-4af2-8150-d9c052361a8e} - c:\program files\atlas v14\ATLIECP.DLL
    BHO: Google Toolbar Notifier BHO: {af69de43-7d58-4638-b6fa-ce66b5ad205d} - c:\program files\google\googletoolbarnotifier\5.2.4204.1700\swg.dll
    BHO: FDMIECookiesBHO Class: {cc59e0f9-7e43-44fa-9faa-8377850bf205} - c:\program files\free download manager\iefdm2.dll
    BHO: Java(tm) Plug-In 2 SSV Helper: {dbc80044-a445-435b-bc74-9c25c1c588a9} - e:\program files\java\ire6\bin\jp2ssv.dll
    BHO: JQSIEStartDetectorImpl Class: {e7e6f031-17ce-4c07-bc86-eabfe594f69c} - e:\program files\java\ire6\lib\deploy\jqs\ie\jqs_plugin.dll
    TB: ATLAS Toolbar: {3c6301ed-0f78-4af2-8150-d9c052361a8e} - c:\program files\atlas v14\ATLIECP.DLL
    uRun: [ctfmon.exe] c:\windows\system32\ctfmon.exe
    uRun: [Google Update] "c:\documents and settings\mahisa andara\local settings\application data\google\update\GoogleUpdate.exe" /c
    uRun: [Power2GoExpress] NA
    uRun: [swg] c:\program files\google\googletoolbarnotifier\GoogleToolbarNotifier.exe
    uRun: [RMClock] "e:\program files\rmclock\RMClockLauncher.exe "
    uRun: [run] c:\windows\system\run\rundll32.exe
    mRun: [<NO NAME>]
    mRun: [Alcmtr] ALCMTR.EXE
    mRun: [BluetoothAuthenticationAgent] rundll32.exe bthprops.cpl,,BluetoothAuthenticationAgent
    mRun: [ccApp] "c:\program files\common files\symantec shared\ccApp.exe "
    mRun: [CLMLServer] "c:\program files\cyberlink\power2go\CLMLSvc.exe "
    mRun: [HP Software Update] c:\program files\hp\hp software update\HPWuSchd2.exe
    mRun: [IMJPMIG8.1] c:\windows\ime\imjp8_1\IMJPMIG.EXE /Spoil /RemAdvDef /Migration32
    mRun: [LanguageShortcut] "c:\program files\cyberlink\powerdvd\language\Language.exe "
    mRun: [MSPY2002] c:\windows\system32\ime\pintlgnt\ImScInst.exe /SYNC
    mRun: [P2Go_Menu] "c:\program files\cyberlink\power2go\muitransfer\muistartmenu.exe" "c:\program files\cyberlink\power2go" updatewithcreateonce "software\cyberlink\power2go\6.0 "
    mRun: [PHIME2002A] c:\windows\system32\ime\tintlgnt\TINTSETP.EXE /IMEName
    mRun: [PHIME2002ASync] c:\windows\system32\ime\tintlgnt\TINTSETP.EXE /SYNC
    mRun: [QuickTime Task] "e:\program files\quicktime\QTTask.exe" -atboottime
    mRun: [RemoteControl] "c:\program files\cyberlink\powerdvd\PDVDServ.exe "
    mRun: [RTHDCPL] RTHDCPL.EXE
    mRun: [SiSPower] Rundll32.exe SiSPower.dll,ModeAgent
    mRun: [SMSERIAL] c:\program files\motorola\smserial\sm56hlpr.exe
    mRun: [Sony Ericsson PC Suite] "c:\program files\sony ericsson\mobile2\application launcher\Application Launcher.exe" /startoptions
    mRun: [vptray] c:\progra~1\symant~1\VPTray.exe
    mRun: [SunJavaUpdateSched] "c:\program files\common files\java\java update\jusched.exe "
    mRun: [Adobe Reader Speed Launcher] "c:\program files\adobe\reader 9.0\reader\Reader_sl.exe "
    mRun: [Adobe ARM] "c:\program files\common files\adobe\arm\1.0\AdobeARM.exe "
    mRun: [HKLM] c:\windows\system\run\rundll32.exe
    uExplorerRun: [Essentials] c:\windows\system\run\rundll32.exe
    mExplorerRun: [Essentials] c:\windows\system\run\rundll32.exe
    StartupFolder: c:\docume~1\mahisa~1\startm~1\programs\startup\magicd~1.lnk - c:\program files\magicdisc\MagicDisc.exe
    StartupFolder: c:\docume~1\alluse~1\startm~1\programs\startup\hpdigi~1.lnk - c:\program files\hp\digital imaging\bin\hpqtra08.exe
    StartupFolder: c:\docume~1\alluse~1\startm~1\programs\startup\micros~1.lnk - c:\program files\microsoft office\office\OSA9.EXE
    StartupFolder: c:\docume~1\alluse~1\startm~1\programs\startup\utilit~1.lnk - c:\windows\system32\sistray.exe
    IE: &Translate with ATLAS - c:\program files\atlas v14\Atlscript.html
    IE: ATLAS Translation &Editor - c:\program files\atlas v14\AtlscriptEdit.html
    IE: Download all by FlashGet3 - c:\documents and settings\mahisa andara\application data\flashgetbho\GetAllUrl.htm
    IE: Download all with Free Download Manager - file://c:\program files\free download manager\dlall.htm
    IE: Download by FlashGet3 - c:\documents and settings\mahisa andara\application data\flashgetbho\GetUrl.htm
    IE: Download selected with Free Download Manager - file://c:\program files\free download manager\dlselected.htm
    IE: Download video with Free Download Manager - file://c:\program files\free download manager\dlfvideo.htm
    IE: Download with Free Download Manager - file://c:\program files\free download manager\dllink.htm
    IE: ハケモテソ・オ3マツヤリ - c:\documents and settings\mahisa andara\application data\flashgetbho\GetUrl.htm
    IE: ハケモテソ・オ3マツヤリネォイソチエスモ - c:\documents and settings\mahisa andara\application data\flashgetbho\GetAllUrl.htm
    IE: {B7707A72-4355-11D4-82BD-00000EBBEF8D} - c:\program files\atlas v14\Atlscript.html
    IE: {e2e2dd38-d088-4134-82b7-f2ba38496583} - %windir%\Network Diagnostic\xpnetdiag.exe
    IE: {FB5F1910-F110-11d2-BB9E-00C04F795683} - c:\program files\messenger\msmsgs.exe
    Trusted Zone: kuaiche.com\software
    DPF: {17492023-C23A-453E-A040-C7C580BBF700} - hxxp://download.microsoft.com/download/E/5/6/E5611B10-0D6D-4117-8430-A67417AA88CD/LegitCheckControl.cab
    DPF: {8AD9C840-044E-11D1-B3E9-00805F499D93} - hxxp://java.sun.com/update/1.6.0/jinstall-1_6_0_22-windows-i586.cab
    DPF: {CAFEEFAC-0016-0000-0022-ABCDEFFEDCBA} - hxxp://java.sun.com/update/1.6.0/jinstall-1_6_0_22-windows-i586.cab
    DPF: {CAFEEFAC-FFFF-FFFF-FFFF-ABCDEFFEDCBA} - hxxp://java.sun.com/update/1.6.0/jinstall-1_6_0_22-windows-i586.cab
    TCP: {DDB93616-F998-4897-A037-D6794BD457FA} = 203.130.196.5,203.130.208.18
    Notify: !SASWinLogon - c:\program files\superantispyware\SASWINLO.DLL
    Notify: NavLogon - c:\windows\system32\NavLogon.dll
    SSODL: WPDShServiceObj - {AAA288BA-9A4C-45B0-95D7-94D524869DB5} - c:\windows\system32\WPDShServiceObj.dll
    SEH: SABShellExecuteHook Class: {5ae067d3-9afb-48e0-853a-ebb7f4a000da} - c:\program files\superantispyware\SASSEH.DLL
    mASetup: {9CB5900A-8628-A49B-FEA5-DF23A5520525} - c:\windows\system32:Shdll.exe
    ================= FIREFOX ===================
    FF - ProfilePath - c:\docume~1\mahisa~1\applic~1\mozilla\firefox\profiles\5o9qsvby.default\
    FF - prefs.js: network.proxy.ftp - PROXIES.TELKOM.NET.ID
    FF - prefs.js: network.proxy.ftp_port - 8080
    FF - prefs.js: network.proxy.gopher - PROXIES.TELKOM.NET.ID
    FF - prefs.js: network.proxy.gopher_port - 8080
    FF - prefs.js: network.proxy.http - PROXIES.TELKOM.NET.ID
    FF - prefs.js: network.proxy.http_port - 8080
    FF - prefs.js: network.proxy.socks - PROXIES.TELKOM.NET.ID
    FF - prefs.js: network.proxy.socks_port - 8080
    FF - prefs.js: network.proxy.ssl - PROXIES.TELKOM.NET.ID
    FF - prefs.js: network.proxy.ssl_port - 8080
    FF - prefs.js: network.proxy.type - 0
    FF - component: c:\program files\free download manager\firefox\extension\components\vmsfdmff.dll
    FF - plugin: c:\documents and settings\mahisa andara\application data\mozilla\firefox\profiles\5o9qsvby.default\extensions\yyginstantplay@yoyogames.com\plugins\NPYYGInstantPlay.dll
    FF - plugin: c:\documents and settings\mahisa andara\local settings\application data\google\update\1.2.183.39\npGoogleOneClick8.dll
    FF - plugin: c:\program files\google\google earth\plugin\npgeplugin.dll
    FF - plugin: c:\program files\google\google updater\2.4.1698.5652\npCIDetect13.dll
    FF - plugin: c:\program files\google\update\1.2.183.13\npGoogleOneClick8.dll
    FF - plugin: c:\program files\google\update\1.2.183.17\npGoogleOneClick8.dll
    FF - plugin: c:\program files\google\update\1.2.183.23\npGoogleOneClick8.dll
    FF - plugin: c:\program files\google\update\1.2.183.29\npGoogleOneClick8.dll
    FF - plugin: c:\program files\google\update\1.2.183.39\npGoogleOneClick8.dll
    FF - plugin: c:\program files\google\update\1.2.183.7\npGoogleOneClick8.dll
    FF - plugin: c:\program files\opera\program\plugins\npfdm.dll
    FF - plugin: e:\program files\java\ire6\bin\new_plugin\npdeployJava1.dll
    FF - plugin: e:\program files\java\ire6\bin\new_plugin\npjp2.dll
    FF - plugin: e:\program files\quicktime\plugins\npqtplugin.dll
    FF - plugin: e:\program files\quicktime\plugins\npqtplugin2.dll
    FF - plugin: e:\program files\quicktime\plugins\npqtplugin3.dll
    FF - plugin: e:\program files\quicktime\plugins\npqtplugin4.dll
    FF - plugin: e:\program files\quicktime\plugins\npqtplugin5.dll
    FF - plugin: e:\program files\quicktime\plugins\npqtplugin6.dll
    FF - plugin: e:\program files\quicktime\plugins\npqtplugin7.dll
    FF - HiddenExtension: Microsoft .NET Framework Assistant: {20a82645-c095-46ed-80e3-08825760534b} - c:\windows\microsoft.net\framework\v3.5\windows presentation foundation\dotnetassistantextension\
    FF - HiddenExtension: Java Console: No Registry Reference - c:\program files\mozilla firefox\extensions\{CAFEEFAC-0016-0000-0020-ABCDEFFEDCBA}
    FF - HiddenExtension: Java Console: No Registry Reference - c:\program files\mozilla firefox\extensions\{CAFEEFAC-0016-0000-0021-ABCDEFFEDCBA}
    FF - HiddenExtension: Java Console: No Registry Reference - c:\program files\mozilla firefox\extensions\{CAFEEFAC-0016-0000-0022-ABCDEFFEDCBA}
    ---- FIREFOX POLICIES ----
    c:\program files\mozilla firefox\greprefs\all.js - pref( "network.IDN.whitelist.xn--mgbaam7a8h ", true);
    c:\program files\mozilla firefox\greprefs\all.js - pref( "network.IDN.whitelist.xn--fiqz9s ", true); // Traditional
    c:\program files\mozilla firefox\greprefs\all.js - pref( "network.IDN.whitelist.xn--fiqs8s ", true); // Simplified
    c:\program files\mozilla firefox\greprefs\all.js - pref( "network.IDN.whitelist.xn--j6w193g ", true);
    c:\program files\mozilla firefox\greprefs\all.js - pref( "network.IDN.whitelist.xn--mgberp4a5d4ar ", true);
    c:\program files\mozilla firefox\greprefs\all.js - pref( "network.IDN.whitelist.xn--mgberp4a5d4a87g ", true);
    c:\program files\mozilla firefox\greprefs\all.js - pref( "network.IDN.whitelist.xn--mgbqly7c0a67fbc ", true);
    c:\program files\mozilla firefox\greprefs\all.js - pref( "network.IDN.whitelist.xn--mgbqly7cvafr ", true);
    c:\program files\mozilla firefox\greprefs\all.js - pref( "network.IDN.whitelist.xn--kpry57d ", true); // Traditional
    c:\program files\mozilla firefox\greprefs\all.js - pref( "network.IDN.whitelist.xn--kprw13d ", true); // Simplified
    R1 SASDIFSV;SASDIFSV;c:\program files\superantispyware\sasdifsv.sys [2010-2-18 12872]
    R1 SASKUTIL;SASKUTIL;c:\program files\superantispyware\SASKUTIL.SYS [2010-5-11 67656]
    R1 SAVRT;SAVRT;c:\program files\symantec antivirus\savrt.sys [2004-2-9 301200]
    R2 SAVRTPEL;SAVRTPEL;c:\program files\symantec antivirus\Savrtpel.sys [2004-2-9 37008]
    R2 WMDrive;WMDrive;c:\windows\system32\drivers\WMDrive.sys [2009-9-18 32384]
    R3 NAVENG;NAVENG;c:\progra~1\common~1\symant~1\virusd~1\20091008.003\naveng.sys [2009-10-9 84912]
    R3 NAVEX15;NAVEX15;c:\progra~1\common~1\symant~1\virusd~1\20091008.003\navex15.sys [2009-10-9 1323568]
    R3 RTCore32;RTCore32;e:\program files\rmclock\RTCore32.sys [2010-11-10 4608]
    S2 clr_optimization_v4.0.30319_32;Microsoft .NET Framework NGEN v4.0.30319_X86;c:\windows\microsoft.net\framework\v4.0.30319\mscorsvw.exe [2010-3-18 130384]
    S2 gupdate;Google Update Service (gupdate);c:\program files\google\update\GoogleUpdate.exe [2009-9-14 133104]
    S3 hwusbfake;Huawei DataCard USB Fake;c:\windows\system32\drivers\ewusbfake.sys [2009-10-10 102656]
    S3 K320bus;Sony Ericsson K320 driver (WDM);c:\windows\system32\drivers\K320bus.sys [2009-7-11 61504]
    S3 K320mdfl;Sony Ericsson K320 USB WMC Modem Filter;c:\windows\system32\drivers\K320mdfl.sys [2009-7-11 9328]
    S3 K320mdm;Sony Ericsson K320 USB WMC Modem Driver;c:\windows\system32\drivers\K320mdm.sys [2009-7-11 97056]
    S3 K320mgmt;Sony Ericsson K320 USB WMC Device Management Drivers (WDM);c:\windows\system32\drivers\K320mgmt.sys [2009-7-11 88560]
    S3 K320obex;Sony Ericsson K320 USB WMC OBEX Interface;c:\windows\system32\drivers\K320obex.sys [2009-7-11 86368]
    S3 NPF;NetGroup Packet Filter Driver;c:\windows\system32\drivers\npf.sys [2009-10-21 50704]
    S3 qcusbser;Qualcomm USB Device for Legacy Serial Communication;c:\windows\system32\drivers\qcusbser.sys [2010-8-31 105984]
    S3 SavRoam;SAVRoam;c:\program files\symantec antivirus\SavRoam.exe [2004-3-12 169192]
    S3 td_cbus;Galaxycom USB Composite Device driver (WDM);c:\windows\system32\drivers\td_cbus.sys [2009-8-20 51040]
    S3 td_cmdfl;Galaxycom Handset Filter;c:\windows\system32\drivers\td_cmdfl.sys [2009-8-20 6032]
    S3 td_cmdm;Galaxycom Handset Drivers;c:\windows\system32\drivers\td_cmdm.sys [2009-8-20 82608]
    S3 td_cserd;Galaxycom Handset Diagnostic Serial Port (WDM);c:\windows\system32\drivers\td_cserd.sys [2009-8-20 64064]
    S3 WPFFontCache_v0400;Windows Presentation Foundation Font Cache 4.0.0.0;c:\windows\microsoft.net\framework\v4.0.30319\wpf\WPFFontCache_v0400.exe [2010-3-18 753504]
    S4 ccEvtMgr;Symantec Event Manager;c:\program files\common files\symantec shared\ccEvtMgr.exe [2004-2-29 255096]
    S4 ccPwdSvc;Symantec Password Validation;c:\program files\common files\symantec shared\ccPwdSvc.exe [2004-2-29 87160]
    S4 ccSetMgr;Symantec Settings Manager;c:\program files\common files\symantec shared\ccSetMgr.exe [2004-2-29 242808]
    S4 npggsvc;nProtect GameGuard Service;c:\windows\system32\gamemon.des -service --> c:\windows\system32\GameMon.des -service [?]
    S4 Symantec AntiVirus;Symantec AntiVirus;c:\program files\symantec antivirus\Rtvscan.exe [2004-3-12 1221864]
    2010-11-21 22:43:47 -------- d-----w- c:\docume~1\mahisa~1\applic~1\SUPERAntiSpyware.com
    2010-11-21 22:43:47 -------- d-----w- c:\docume~1\alluse~1\applic~1\SUPERAntiSpyware.com
    2010-11-21 22:43:40 -------- d-----w- c:\program files\SUPERAntiSpyware
    2010-11-16 11:44:53 269824 ----a-w- c:\windows\shdll.exe
    2010-11-15 11:04:54 -------- d-----w- c:\docume~1\mahisa~1\locals~1\applic~1\Oblivion
    2010-11-15 10:48:37 -------- d-----w- C:\summerwars
    2010-11-06 04:37:34 103864 ----a-w- c:\program files\mozilla firefox\plugins\nppdf32.dll
    2010-11-06 04:37:34 103864 ----a-w- c:\program files\internet explorer\plugins\nppdf32.dll
    2010-10-30 23:58:10 -------- d-----w- c:\docume~1\mahisa~1\locals~1\applic~1\Microsoft_Corporation
    2010-10-30 06:27:59 94208 ----a-w- c:\windows\DIIUnin.exe
    2010-10-30 06:27:59 2829 ----a-w- c:\windows\DIIUnin.pif
    2010-10-28 09:28:10 21840 ----atw- c:\windows\system32\SIntfNT.dll
    2010-10-28 09:28:10 17212 ----atw- c:\windows\system32\SIntf32.dll
    2010-10-28 09:28:10 12067 ----atw- c:\windows\system32\SIntf16.dll
    2010-10-25 08:07:07 1682 --sha-w- c:\windows\system32\KGyGaAvL.sys
    2010-09-14 21:50:37 472808 ----a-w- c:\windows\system32\deployJava1.dll
    2010-09-14 19:29:49 73728 ----a-w- c:\windows\system32\javacpl.cpl
    ============= FINISH: 20:00:11.76 ===============
    Attach
    UNLESS SPECIFICALLY INSTRUCTED, DO NOT POST THIS LOG.
    IF REQUESTED, ZIP IT UP & ATTACH IT
    Boot Device: \Device\HarddiskVolume1
    Install Date: 5/9/2009 4:34:36 PM
    System Uptime: 11/22/2010 4:57:49 PM (4 hours ago)
    Motherboard: SiS | | M730SR
    Processor: Intel(R) Core(TM)2 Duo CPU T7100 @ 1.80GHz | uPGA 479M | 1799/200mhz
    ==== Disk Partitions =========================
    C: is FIXED (NTFS) - 78 GiB total, 3.836 GiB free.
    D: is CDROM ()
    E: is FIXED (NTFS) - 71 GiB total, 7.514 GiB free.
    F: is CDROM ()
    ==== Disabled Device Manager Items =============
    Class GUID: {4D36E97E-E325-11CE-BFC1-08002BE10318}
    Description: PCI FLASH Memory
    Device ID: PCI\VEN_1524&DEV_0730&SUBSYS_07221558&REV_00\3&267A616A&0&48
    Manufacturer:
    Name: PCI FLASH Memory
    PNP Device ID: PCI\VEN_1524&DEV_0730&SUBSYS_07221558&REV_00\3&267A616A&0&48
    Service:
    Device ID: PCI\VEN_1524&DEV_0751&SUBSYS_07221558&REV_00\3&267A616A&0&4B
    Manufacturer:
    PNP Device ID: PCI\VEN_1524&DEV_0751&SUBSYS_07221558&REV_00\3&267A616A&0&4B
    Service:
    ==== System Restore Points ===================
    RP384: 8/25/2010 6:36:57 PM - System Checkpoint
    RP385: 8/27/2010 12:14:42 PM - System Checkpoint
    RP386: 8/28/2010 4:45:45 PM - System Checkpoint
    RP387: 8/29/2010 8:06:16 PM - System Checkpoint
    RP388: 8/30/2010 9:17:42 PM - System Checkpoint
    RP389: 8/31/2010 6:51:34 PM - Unsigned driver install
    RP390: 9/1/2010 8:17:18 PM - System Checkpoint
    RP391: 9/2/2010 8:21:28 PM - System Checkpoint
    RP392: 9/3/2010 8:55:35 PM - System Checkpoint
    RP393: 9/5/2010 12:51:44 AM - System Checkpoint
    RP394: 9/6/2010 8:29:35 AM - System Checkpoint
    RP395: 9/6/2010 1:53:28 PM - Removed Opera 10.60.
    RP396: 9/6/2010 1:53:43 PM - Installed Opera 10.61.
    RP397: 9/7/2010 3:35:31 PM - System Checkpoint
    RP398: 9/8/2010 11:06:35 PM - System Checkpoint
    RP399: 9/10/2010 6:36:12 PM - System Checkpoint
    RP400: 9/10/2010 11:05:48 AM - System Checkpoint
    RP401: 9/11/2010 12:38:21 PM - System Checkpoint
    RP402: 9/13/2010 7:09:40 AM - System Checkpoint
    RP403: 9/14/2010 12:22:17 PM - System Checkpoint
    RP404: 9/15/2010 2:27:43 PM - System Checkpoint
    RP405: 9/16/2010 6:18:25 PM - System Checkpoint
    RP406: 9/17/2010 8:15:51 PM - System Checkpoint
    RP407: 9/19/2010 5:02:22 AM - System Checkpoint
    RP408: 9/20/2010 5:16:24 AM - System Checkpoint
    RP409: 9/21/2010 6:31:59 AM - System Checkpoint
    RP410: 9/22/2010 11:03:52 AM - System Checkpoint
    RP411: 9/23/2010 11:56:37 AM - System Checkpoint
    RP412: 9/24/2010 12:05:39 PM - System Checkpoint
    RP413: 9/25/2010 12:59:23 PM - System Checkpoint
    RP414: 9/26/2010 3:20:19 PM - System Checkpoint
    RP415: 9/27/2010 4:37:11 PM - System Checkpoint
    RP416: 9/29/2010 5:34:13 AM - System Checkpoint
    RP417: 9/30/2010 10:27:42 AM - System Checkpoint
    RP418: 10/1/2010 8:38:17 PM - System Checkpoint
    RP419: 10/3/2010 6:31:58 AM - System Checkpoint
    RP420: 10/4/2010 7:59:49 AM - System Checkpoint
    RP421: 10/5/2010 2:39:28 PM - System Checkpoint
    RP422: 10/6/2010 6:53:28 PM - System Checkpoint
    RP423: 10/7/2010 9:49:17 PM - System Checkpoint
    RP424: 10/8/2010 10:40:55 PM - System Checkpoint
    RP425: 10/10/2010 8:15:30 PM - System Checkpoint
    RP426: 10/11/2010 9:49:19 PM - System Checkpoint
    RP427: 10/12/2010 10:16:42 PM - System Checkpoint
    RP428: 10/14/2010 4:42:32 AM - System Checkpoint
    RP429: 10/15/2010 9:25:59 AM - System Checkpoint
    RP430: 10/18/2010 8:39:56 AM - System Checkpoint
    RP431: 10/19/2010 3:36:45 PM - System Checkpoint
    RP432: 10/20/2010 5:09:59 PM - System Checkpoint
    RP433: 10/21/2010 5:21:23 PM - System Checkpoint
    RP434: 10/22/2010 5:26:13 PM - System Checkpoint
    RP435: 10/24/2010 6:34:15 PM - System Checkpoint
    RP436: 10/25/2010 6:41:11 PM - System Checkpoint
    RP437: 10/26/2010 8:15:15 PM - System Checkpoint
    RP438: 10/27/2010 10:19:55 PM - System Checkpoint
    RP439: 10/29/2010 5:59:45 AM - System Checkpoint
    RP440: 10/30/2010 7:37:13 PM - Installed Java(TM) 6 Update 22
    RP441: 10/31/2010 6:50:28 AM - Installed Windows XP KB942288-v3.
    RP442: 11/1/2010 5:05:20 PM - Removed Opera 10.61.
    RP443: 11/2/2010 5:10:15 PM - System Checkpoint
    RP444: 11/4/2010 5:46:56 AM - System Checkpoint
    RP445: 11/5/2010 9:08:33 PM - System Checkpoint
    RP446: 11/8/2010 9:22:51 AM - System Checkpoint
    RP447: 11/9/2010 9:33:04 AM - System Checkpoint
    RP448: 11/10/2010 1:35:26 PM - System Checkpoint
    RP449: 11/11/2010 3:20:22 PM - System Checkpoint
    RP450: 11/15/2010 5:41:10 AM - System Checkpoint
    RP451: 11/16/2010 7:05:59 AM - System Checkpoint
    RP452: 11/17/2010 4:01:21 PM - System Checkpoint
    RP453: 11/21/2010 9:08:35 PM - System Checkpoint
    ==== Installed Programs ======================
    40 Days and 40 Nights of Rain 1.0e
    Adobe Flash Player 10 Plugin
    Adobe Reader 9.4.1
    Adobe Shockwave Player 11.5
    Advance Wars Series Map Editor 1.0
    Age of Mythology
    Age of Mythology - The Titans Expansion
    AiO_Scan_CDA
    AiOSoftwareNPI
    Anything 4 Love (v1.10)
    Apple Application Support
    Apple Software Update
    Applian FLV Player
    Aquaria Demo
    ATLAS Translation Standard V14.0 Trial Version
    Audacity 1.2.6
    Bootfighter Windom XP sp-2.NET v1.030+
    BufferChm
    Cave Story Deluxe
    CCleaner
    Cheat Engine 5.5
    Combined Community Codec Pack 2008-09-21 16:18
    Command & Conquer The First Decade
    Compatibility Pack for the 2007 Office system
    Consolas Font Family
    CustomerResearchQFolder
    CyberLink DVD Suite
    CyberLink Power2Go
    Destinations
    Deus Ex - Game of the Year (remove only)
    DeviceManagementQFolder
    Diablo II
    DirectVobSub (remove only)
    Emil Chronicle Online
    eSupportQFolder
    F300
    F300_Help
    Fable - The Lost Chapters
    Fax_CDA
    File Splitter and Joiner (FFSJ v3.3)
    FINAL FANTASY VIII
    FlashOffliner 1.0
    Free Download Manager 3.0
    Galaxycom USB Modem
    Google Book Downloader
    Google Chrome
    Google Earth
    Google Update Helper
    Google Updater
    Half-Life
    Half-Life Source
    Half-Life SP Pack
    High Definition Audio Driver Package - KB888111
    Hotfix for Microsoft .NET Framework 3.5 SP1 (KB953595)
    Hotfix for Microsoft .NET Framework 3.5 SP1 (KB958484)
    Hotfix for Microsoft Visual Basic 2008 Express Edition with SP1 - ENU (KB945282)
    Hotfix for Microsoft Visual Basic 2008 Express Edition with SP1 - ENU (KB946040)
    Hotfix for Microsoft Visual Basic 2008 Express Edition with SP1 - ENU (KB946308)
    Hotfix for Microsoft Visual Basic 2008 Express Edition with SP1 - ENU (KB946344)
    Hotfix for Microsoft Visual Basic 2008 Express Edition with SP1 - ENU (KB947540)
    Hotfix for Microsoft Visual Basic 2008 Express Edition with SP1 - ENU (KB947789)
    Hotfix for Microsoft Visual Basic 2008 Express Edition with SP1 - ENU (KB948127)
    Hotfix for Microsoft Visual Basic 2008 Express Edition with SP1 - ENU (KB951708)
    Hotfix for Microsoft Visual C++ 2008 Express Edition with SP1 - ENU (KB945282)
    Hotfix for Microsoft Visual C++ 2008 Express Edition with SP1 - ENU (KB946040)
    Hotfix for Microsoft Visual C++ 2008 Express Edition with SP1 - ENU (KB946308)
    Hotfix for Microsoft Visual C++ 2008 Express Edition with SP1 - ENU (KB947540)
    Hotfix for Microsoft Visual C++ 2008 Express Edition with SP1 - ENU (KB947789)
    Hotfix for Microsoft Visual C++ 2008 Express Edition with SP1 - ENU (KB948127)
    Hotfix for Windows Media Format 11 SDK (KB929399)
    Hotfix for Windows Media Player 11 (KB939683)
    Hotfix for Windows XP (KB942288-v3)
    Hotfix for Windows XP (KB952287)
    Hotfix for Windows XP (KB954550-v5)
    Hotfix for Windows XP (KB961118)
    Hotfix for Windows XP (KB970653-v3)
    HP Customer Participation Program 7.0
    HP Imaging Device Functions 7.0
    HP Photosmart Essential
    HP Photosmart, Officejet and Deskjet 7.0.A
    HP Software Update
    HP Solution Center 7.0
    HPPhotoSmartExpress
    HPProductAssistant
    Idol Street
    ImgBurn
    Indosat 3.5G connect
    InstantShareDevicesMFC
    IsoBuster 2.8
    Java Auto Updater
    LiveUpdate 2.0 (Symantec Corporation)
    MagicDisc 2.7.106
    MarketResearch
    Microsoft .NET Framework 2.0 Service Pack 2
    Microsoft .NET Framework 3.0 Service Pack 2
    Microsoft .NET Framework 4 Client Profile
    Microsoft .NET Framework 4 Extended
    Microsoft Age of Empires II
    Microsoft Age of Empires II: The Conquerors Expansion
    Microsoft AppLocale
    Microsoft Compression Client Pack 1.0 for Windows XP
    Microsoft DirectX SDK (August 2009)
    Microsoft Office 2000 Professional
    Microsoft SQL Server 2008 Management Objects
    Microsoft SQL Server Compact 3.5 SP1 Design Tools English
    Microsoft SQL Server Compact 3.5 SP1 English
    Microsoft User-Mode Driver Framework Feature Pack 1.0
    Microsoft Visual Basic 6.0 Enterprise Edition
    Microsoft Visual C++ 2008 Redistributable - x86 9.0.30729
    Microsoft Web Publishing Wizard 1.53
    Microsoft Windows Application Compatibility Database
    Microsoft Windows SDK for Visual Studio 2008 Headers and Libraries
    Microsoft Windows SDK for Visual Studio 2008 SP1 Express Tools for .NET Framework - enu
    Microsoft Windows SDK for Visual Studio 2008 SP1 Express Tools for Win32
    Motorola SM56 Data Fax Modem
    Mozilla Firefox (3.6.12)
    MP3 Bitrate Changer 1.1
    MSN
    MSXML 4.0 SP2 (KB954430)
    MSXML4 Parser
    NewCopy_CDA
    NirSoft VideoCacheView
    NirSoft WebVideoCap
    Opera 10.63
    Orca
    PerformanceTest v7.0
    Plain Song Christmas Special
    planetarian English Patch
    PowerDVD
    ProductContextNPI
    QuickTime
    RAR Password Cracker 4.12
    Readme
    Realtek High Definition Audio Driver
    RGSS-RTP Standard
    Rohan Online Indonesia
    Rosenkreuzstilette ~Blades of the Rose Cross~
    RPG Maker 2000 1.07b
    RPGXP
    RTP for RM2K (Png, Wav, Midi, Fonts)
    Runtime Files Pack 3
    Sanny Builder 3.04
    SBPSolver
    Scan
    ScannerCopy
    Security Update for Windows Media Player (KB952069)
    Security Update for Windows Media Player (KB968816)
    Security Update for Windows Media Player (KB973540)
    Security Update for Windows Media Player 11 (KB954154)
    Security Update for Windows XP (KB923561)
    Security Update for Windows XP (KB923789)
    Security Update for Windows XP (KB938464-v2)
    Security Update for Windows XP (KB941569)
    Security Update for Windows XP (KB946648)
    Security Update for Windows XP (KB950762)
    Security Update for Windows XP (KB950974)
    Security Update for Windows XP (KB951066)
    Security Update for Windows XP (KB951376-v2)
    Security Update for Windows XP (KB951748)
    Security Update for Windows XP (KB952004)
    Security Update for Windows XP (KB952954)
    Security Update for Windows XP (KB954459)
    Security Update for Windows XP (KB954600)
    Security Update for Windows XP (KB955069)
    Security Update for Windows XP (KB956572)
    Security Update for Windows XP (KB956744)
    Security Update for Windows XP (KB956802)
    Security Update for Windows XP (KB956803)
    Security Update for Windows XP (KB956844)
    Security Update for Windows XP (KB957097)
    Security Update for Windows XP (KB958644)
    Security Update for Windows XP (KB958687)
    Security Update for Windows XP (KB959426)
    Security Update for Windows XP (KB960225)
    Security Update for Windows XP (KB960803)
    Security Update for Windows XP (KB960859)
    Security Update for Windows XP (KB961371)
    Security Update for Windows XP (KB961501)
    Security Update for Windows XP (KB968537)
    Security Update for Windows XP (KB970238)
    Security Update for Windows XP (KB971557)
    Security Update for Windows XP (KB971633)
    Security Update for Windows XP (KB971657)
    Security Update for Windows XP (KB972260)
    Security Update for Windows XP (KB973346)
    Security Update for Windows XP (KB973354)
    Security Update for Windows XP (KB973507)
    Security Update for Windows XP (KB973869)
    Sierra Utilities
    SiS VGA Utilities
    SiSAGP driver
    SolutionCenter
    SpeedFan (remove only)
    SQL Server System CLR Types
    Starcraft
    StarCraft X-tra Editor Version 2.5
    Status
    SUPERAntiSpyware
    SWF Opener
    Symantec AntiVirus
    The Poor Little Bird 1.0E
    Toolbox
    TortoiseSVN 1.6.5.16974 (32 bit)
    TrayApp
    Uniblue DriverScanner 2009
    Universal Extractor 1.6.1
    Update for Microsoft .NET Framework 3.5 SP1 (KB963707)
    Update for Windows XP (KB951978)
    Update for Windows XP (KB955839)
    Update for Windows XP (KB967715)
    Update for Windows XP (KB968389)
    Update for Windows XP (KB973815)
    Visual Basic 4 Runtime Files
    WebFldrs XP
    WebReg
    Windows Media Format 11 runtime
    Windows PowerShell(TM) 1.0
    Windows XP Service Pack 3
    WinMount V3.2.0902
    WinPcap 4.1.1
    WinRAR archiver
    Xuse 永遠のアセリア - この大地の果てで - (Remove Only)
    Yu-Gi-Oh! Power of Chaos KAIBA THE REVENGE
    Yu-Gi-Oh! Power of Chaos YUGI THE DESTINY 2.0
    ギャラクシーエンジェル
    東方地霊殿 ver 1.00a
    ==== Event Viewer Messages From Past Week ========
    11/22/2010 6:03:38 AM, error: Service Control Manager [7026] - The following boot-start or system-start driver(s) failed to load: AFD Fips intelppm IPSec MRxSmb NetBIOS NetBT RasAcd Rdbss SASDIFSV SASKUTIL SAVRT SYMTDI Tcpip
    11/22/2010 6:03:38 AM, error: Service Control Manager [7001] - The TCP/IP NetBIOS Helper service depends on the AFD service which failed to start because of the following error: A device attached to the system is not functioning.
    11/22/2010 6:03:38 AM, error: Service Control Manager [7001] - The IPSEC Services service depends on the IPSEC driver service which failed to start because of the following error: A device attached to the system is not functioning.
    11/22/2010 6:03:38 AM, error: Service Control Manager [7001] - The DNS Client service depends on the TCP/IP Protocol Driver service which failed to start because of the following error: A device attached to the system is not functioning.
    11/22/2010 6:03:38 AM, error: Service Control Manager [7001] - The DHCP Client service depends on the NetBios over Tcpip service which failed to start because of the following error: A device attached to the system is not functioning.
    11/22/2010 6:03:18 AM, error: DCOM [10005] - DCOM got error "%1084" attempting to start the service StiSvc with arguments " " in order to run the server: {A1F4E726-8CF1-11D1-BF92-0060081ED811}
    11/22/2010 6:03:09 AM, error: DCOM [10005] - DCOM got error "%1084" attempting to start the service EventSystem with arguments " " in order to run the server: {1BE1F766-5536-11D1-B726-00C04FB926AF}
    11/22/2010 6:03:08 AM, error: DCOM [10005] - DCOM got error "%1084" attempting to start the service netman with arguments " " in order to run the server: {BA126AE5-2166-11D1-B1D0-00805FC1270E}
    11/22/2010 4:59:23 PM, error: System Error [1003] - Error code 1000007f, parameter1 0000000d, parameter2 00000000, parameter3 00000000, parameter4 00000000.
    11/22/2010 4:58:31 PM, error: sr [1] - The System Restore filter encountered the unexpected error '0xC0000243' while processing the file 'SAVRT' on the volume 'HarddiskVolume1'. It has stopped monitoring the volume.
    11/22/2010 4:43:48 PM, error: sr [1] - The System Restore filter encountered the unexpected error '0xC0000001' while processing the file '' on the volume 'HarddiskVolume1'. It has stopped monitoring the volume.
    11/22/2010 1:17:05 PM, error: Service Control Manager [7034] - The Symantec AntiVirus Definition Watcher service terminated unexpectedly. It has done this 1 time(s).
    11/22/2010 1:17:05 PM, error: Service Control Manager [7034] - The Pml Driver HPZ12 service terminated unexpectedly. It has done this 1 time(s).
    11/22/2010 1:17:05 PM, error: Service Control Manager [7034] - The Java Quick Starter service terminated unexpectedly. It has done this 1 time(s).
    11/22/2010 1:17:05 PM, error: Service Control Manager [7034] - The Cyberlink RichVideo Service(CRVS) service terminated unexpectedly. It has done this 1 time(s).
    11/21/2010 8:40:33 PM, error: SideBySide [59] - Resolve Partial Assembly failed for Microsoft.VC80.MFCLOC. Reference error message: The referenced assembly is not installed on your system. .
    11/21/2010 8:40:33 PM, error: SideBySide [59] - Generate Activation Context failed for C:\WINDOWS\WinSxS\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.762_x-ww_3bf8fa05\MFC80.DLL. Reference error message: The operation completed successfully. .
    11/21/2010 8:40:33 PM, error: SideBySide [32] - Dependent Assembly Microsoft.VC80.MFCLOC could not be found and Last Error was The referenced assembly is not installed on your system.
    11/21/2010 7:26:58 PM, error: Service Control Manager [7032] - The Service Control Manager tried to take a corrective action (Restart the service) after the unexpected termination of the Windows Management Instrumentation service, but this action failed with the following error: An instance of the service is already running.
    11/21/2010 7:25:49 PM, error: Service Control Manager [7034] - The Windows Image Acquisition (WIA) service terminated unexpectedly. It has done this 1 time(s).
    11/21/2010 7:25:38 PM, error: Service Control Manager [7034] - The WebClient service terminated unexpectedly. It has done this 1 time(s).
    11/21/2010 7:23:13 PM, error: Dhcp [1002] - The IP address lease 192.168.1.2 for the Network Card with network address 0090F58B2D52 has been denied by the DHCP server 192.168.1.1 (The DHCP Server sent a DHCPNACK message).
    11/21/2010 11:37:46 PM, information: Windows File Protection [64002] - File replacement was attempted on the protected system file icwrmind.exe. This file was restored to the original version to maintain system stability. The file version of the system file is 6.0.2900.5512.
    11/21/2010 11:37:46 PM, information: Windows File Protection [64002] - File replacement was attempted on the protected system file c:\program files\internet explorer\connection wizard\icwtutor.exe. This file was restored to the original version to maintain system stability. The file version of the system file is 6.0.2600.0.
    11/21/2010 11:37:40 PM, information: Windows File Protection [64002] - File replacement was attempted on the protected system file icwconn2.exe. This file was restored to the original version to maintain system stability. The file version of the system file is 6.0.2900.5512.
    11/21/2010 11:37:38 PM, information: Windows File Protection [64002] - File replacement was attempted on the protected system file icwconn1.exe. This file was restored to the original version to maintain system stability. The file version of the system file is 6.0.2900.5512.
    11/21/2010 11:33:09 PM, information: Windows File Protection [64002] - File replacement was attempted on the protected system file c:\program files\internet explorer\iedw.exe. This file was restored to the original version to maintain system stability. The file version of the system file is 5.1.2600.5512.
    11/21/2010 11:32:49 PM, information: Windows File Protection [64002] - File replacement was attempted on the protected system file iedw.exe. This file was restored to the original version to maintain system stability. The file version of the system file is 5.1.2600.5512.
    11/21/2010 11:32:48 PM, information: Windows File Protection [64002] - File replacement was attempted on the protected system file c:\program files\internet explorer\iexplore.exe. This file was restored to the original version to maintain system stability. The file version of the system file is 6.0.2900.2180.
    11/21/2010 10:05:28 PM, error: DCOM [10005] - DCOM got error "%1058" attempting to start the service wuauserv with arguments " " in order to run the server: {E60687F7-01A1-40AA-86AC-DB1CBF673334}
    11/17/2010 1:05:31 AM, error: W32Time [17] - Time Provider NtpClient: An error occurred during DNS lookup of the manually configured peer 'time.windows.com,0x1'. NtpClient will try the DNS lookup again in 15 minutes. The error was: A socket operation was attempted to an unreachable host. (0x80072751)
    11/16/2010 11:48:44 PM, error: W32Time [17] - Time Provider NtpClient: An error occurred during DNS lookup of the manually configured peer 'time.windows.com,0x1'. NtpClient will try the DNS lookup again in 60 minutes. The error was: A socket operation was attempted to an unreachable host. (0x80072751)
    11/16/2010 11:18:44 PM, error: W32Time [17] - Time Provider NtpClient: An error occurred during DNS lookup of the manually configured peer 'time.windows.com,0x1'. NtpClient will try the DNS lookup again in 30 minutes. The error was: A socket operation was attempted to an unreachable host. (0x80072751)
    11/16/2010 10:32:24 PM, error: ACPIEC [1] - \Device\ACPIEC: The embedded controller (EC) hardware didn't respond within the timeout period. This may indicate an error in the EC hardware or firmware, or possibly a poorly designed BIOS which accesses the EC in an unsafe manner. The EC driver will retry the failed transaction if possible.
    11/15/2010 7:42:03 PM, error: System Error [1003] - Error code 40000080, parameter1 86a4d5e8, parameter2 8652b120, parameter3 80551388, parameter4 00000001.
    ==== End Of File ===========================
  2. 2010/11/22
    Welcome aboard :)
    Please, observe following rules:
    • Read all of my instructions very carefully. Your mistakes during cleaning process may have very serious consequences, like unbootable computer.
    • If you're stuck, or you're not sure about certain step, always ask before doing anything else.
    • Please refrain from running tools or applying updates other than those I suggest.
    • Never run more than one scan at a time.
    • Keep updating me regarding your computer behavior, good, or bad.
    • The cleaning process, once started, has to be completed. Even if your computer appears to act better, it may still be infected. Once the computer is totally clean, I'll certainly let you know.
    • If you leave the topic without explanation in the middle of a cleaning process, you may not be eligible to receive any more help in malware removal forum.
    • I close my topics if you have not replied in 5 days. If you need more time, simply let me know. If I closed your topic and you need it to be reopened, simply PM me.
    [color= "Blue"]**Note: In the event you already have Combofix, this is a new version that I need you to download. It is important that it is saved directly to your desktop**[/color]
    2. Close any open browsers.
      • Click on [color= "Red"]this link[/color] to see a list of programs that should be disabled. The list is not all inclusive. If yours is not listed and you don't know how to disable it, please ask.
      NOTE1. If Combofix asks you to install Recovery Console, please allow it.
      • Close any open browsers.
      • [color= "Red"]WARNING:[/color] Combofix will disconnect your machine from the Internet as soon as it starts
    6. Please post the "C:\ComboFix.txt"
    **Note 1: Do not mouseclick combofix's window while it's running. That may cause it to stall
    **Note 2 for AVG users: ComboFix will not run until AVG is uninstalled as a protective measure against the anti-virus. This is because AVG "falsely" detects ComboFix (or its embedded files) as a threat and may remove them resulting in the tool not working correctly which in turn can cause "unpredictable results ". Since AVG cannot be effectively disabled before running ComboFix, the author recommends you to uninstall AVG first.
    Use AVG Remover to uninstall it: http://www.avg.com/us-en/download-tools
    We can reinstall it when we're done with CF.
    **Note 3: If you receive an error "Illegal operation attempted on a registery key that has been marked for deletion ", restart computer to fix the issue.
    NOTE.
    If, for some reason, Combofix refuses to run, try one of the following:
    1. Run Combofix from Safe Mode.
    2. Delete Combofix file, download fresh one, but rename combofix.exe to your_name.exe BEFORE saving it to your desktop.
    Do NOT run it yet.
    Please download and run the below tool named Rkill (courtesy of BleepingComputer.com) which may help allow other programs to run.
    There are 4 different versions. If one of them won't run then download and try to run the other one.
    Vista and Win7 users need to right click Rkill and choose Run as Administrator
    You only need to get one of these to run, not all of them. You may get warnings from your antivirus about this tool, ignore them or shutdown your antivirus.
    Rkill.com
    Rkill.scr
    Rkill.pif
    Rkill.exe
    • Double-click on the Rkill desktop icon to run the tool.
    • If using Vista or Windows 7 right-click on it and choose Run As Administrator.
    • A black DOS box will briefly flash and then disappear. This is normal and indicates the tool ran successfully.
    • If not, delete the file, then download and use the one provided in Link 2.
    • If it does not work, repeat the process and attempt to use one of the remaining links until the tool runs.
    • Do not reboot until instructed.
    • If the tool does not run from any of the links provided, please let me know.
    Once you've gotten one of them to run, immediately run your_name.exe by double clicking on it.
    If normal mode still doesn't work, run BOTH tools from safe mode.
    In case #2, please post BOTH logs, rKill and Combofix.
    mahisa78
    Here's the log
    ComboFix 10-11-22.04 - Mahisa Andara 3/2010 Tue 10:11:23.1.2 - x86
    Microsoft Windows XP Professional 5.1.2600.3.932.81.1033.18.989.567 [GMT 7:00]
    Running from: c:\documents and settings\Mahisa Andara\My Documents\Downloads\ComboFix.exe
    AV: AntiVir Desktop *On-access scanning disabled* (Outdated) {AD166499-45F9-482A-A743-FDD3350758C7}
    ADS - system32: deleted 13785 bytes in 1 streams.
    c:\windows\AppPatch\Custom\{deb7008b-681e-4a4a-8aae-cc833e8216ce}.sdb
    ((((((((((((((((((((((((( Files Created from 2010-10-23 to 2010-11-23 )))))))))))))))))))))))))))))))
    2010-11-23 01:08 . 2010-11-23 01:08 -------- d-----w- c:\documents and settings\Mahisa Andara\Application Data\Avira
    2010-11-23 00:50 . 2010-08-02 09:10 126856 ----a-w- c:\windows\system32\drivers\avipbb.sys
    2010-11-23 00:50 . 2010-06-17 08:27 22360 ----a-w- c:\windows\system32\drivers\avgntmgr.sys
    2010-11-23 00:50 . 2010-11-23 01:29 61960 ----a-w- c:\windows\system32\drivers\avgntflt.sys
    2010-11-23 00:50 . 2010-06-17 08:27 45416 ----a-w- c:\windows\system32\drivers\avgntdd.sys
    2010-11-23 00:50 . 2010-11-23 00:50 -------- d-----w- c:\documents and settings\All Users\Application Data\Avira
    2010-11-21 22:43 . 2010-11-21 22:43 -------- d-----w- c:\documents and settings\Mahisa Andara\Application Data\SUPERAntiSpyware.com
    2010-11-21 22:43 . 2010-11-21 22:43 -------- d-----w- c:\documents and settings\All Users\Application Data\SUPERAntiSpyware.com
    2010-11-21 22:43 . 2010-11-21 23:03 -------- d-----w- c:\program files\SUPERAntiSpyware
    2010-11-16 11:44 . 2010-11-18 05:07 269824 ----a-w- c:\windows\shdll.exe
    2010-11-15 11:04 . 2010-11-15 11:04 -------- d-----w- c:\documents and settings\Mahisa Andara\Local Settings\Application Data\Oblivion
    2010-11-15 10:48 . 2010-11-15 10:56 -------- d-----w- C:\summerwars
    2010-11-06 04:37 . 2010-11-06 04:37 103864 ----a-w- c:\program files\Mozilla Firefox\plugins\nppdf32.dll
    2010-11-06 04:37 . 2010-11-06 04:37 103864 ----a-w- c:\program files\Internet Explorer\PLUGINS\nppdf32.dll
    2010-10-30 23:58 . 2010-10-30 23:58 -------- d-----w- c:\documents and settings\Mahisa Andara\Local Settings\Application Data\Microsoft_Corporation
    2010-10-30 06:27 . 2010-10-30 06:27 94208 ----a-w- c:\windows\DIIUnin.exe
    2010-10-30 06:27 . 2010-10-30 06:27 2829 ----a-w- c:\windows\DIIUnin.pif
    2010-10-28 09:28 . 2010-11-04 06:59 21840 ----atw- c:\windows\system32\SIntfNT.dll
    2010-10-28 09:28 . 2010-11-04 06:59 17212 ----atw- c:\windows\system32\SIntf32.dll
    2010-10-28 09:28 . 2010-11-04 06:59 12067 ----atw- c:\windows\system32\SIntf16.dll
    2010-09-14 21:50 . 2010-05-07 05:34 472808 ----a-w- c:\windows\system32\deployJava1.dll
    2010-09-14 19:29 . 2010-05-07 05:34 73728 ----a-w- c:\windows\system32\javacpl.cpl
    [HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\explorer\shelliconoverlayidentifiers\1TortoiseNormal]
    @= "{C5994560-53D9-4125-87C9-F193FC689CB2} "
    [HKEY_CLASSES_ROOT\CLSID\{C5994560-53D9-4125-87C9-F193FC689CB2}]
    2009-08-13 11:55 85768 ----a-w- c:\program files\Common Files\TortoiseOverlays\TortoiseOverlays.dll
    [HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\explorer\shelliconoverlayidentifiers\2TortoiseModified]
    @= "{C5994561-53D9-4125-87C9-F193FC689CB2} "
    [HKEY_CLASSES_ROOT\CLSID\{C5994561-53D9-4125-87C9-F193FC689CB2}]
    [HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\explorer\shelliconoverlayidentifiers\3TortoiseConflict]
    @= "{C5994562-53D9-4125-87C9-F193FC689CB2} "
    [HKEY_CLASSES_ROOT\CLSID\{C5994562-53D9-4125-87C9-F193FC689CB2}]
    [HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\explorer\shelliconoverlayidentifiers\4TortoiseLocked]
    @= "{C5994563-53D9-4125-87C9-F193FC689CB2} "
    [HKEY_CLASSES_ROOT\CLSID\{C5994563-53D9-4125-87C9-F193FC689CB2}]
    [HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\explorer\shelliconoverlayidentifiers\5TortoiseReadOnly]
    @= "{C5994564-53D9-4125-87C9-F193FC689CB2} "
    [HKEY_CLASSES_ROOT\CLSID\{C5994564-53D9-4125-87C9-F193FC689CB2}]
    [HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\explorer\shelliconoverlayidentifiers\6TortoiseDeleted]
    @= "{C5994565-53D9-4125-87C9-F193FC689CB2} "
    [HKEY_CLASSES_ROOT\CLSID\{C5994565-53D9-4125-87C9-F193FC689CB2}]
    [HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\explorer\shelliconoverlayidentifiers\7TortoiseAdded]
    @= "{C5994566-53D9-4125-87C9-F193FC689CB2} "
    [HKEY_CLASSES_ROOT\CLSID\{C5994566-53D9-4125-87C9-F193FC689CB2}]
    [HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\explorer\shelliconoverlayidentifiers\8TortoiseIgnored]
    @= "{C5994567-53D9-4125-87C9-F193FC689CB2} "
    [HKEY_CLASSES_ROOT\CLSID\{C5994567-53D9-4125-87C9-F193FC689CB2}]
    [HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\explorer\shelliconoverlayidentifiers\9TortoiseUnversioned]
    @= "{C5994568-53D9-4125-87C9-F193FC689CB2} "
    [HKEY_CLASSES_ROOT\CLSID\{C5994568-53D9-4125-87C9-F193FC689CB2}]
    "Power2GoExpress "= "NA" [X]
    "Google Update "= "c:\documents and settings\Mahisa Andara\Local Settings\Application Data\Google\Update\GoogleUpdate.exe" [2009-07-31 133104]
    "swg "= "c:\program files\Google\GoogleToolbarNotifier\GoogleToolbarNotifier.exe" [2009-09-14 39408]
    "RMClock "= "e:\program files\RMClock\RMClockLauncher.exe" [2008-02-29 61440]
    "BluetoothAuthenticationAgent "= "bthprops.cpl" [2008-04-14 110592]
    "CLMLServer "= "c:\program files\CyberLink\Power2Go\CLMLSvc.exe" [2008-01-15 103720]
    "HP Software Update "= "c:\program files\HP\HP Software Update\HPWuSchd2.exe" [2006-02-18 49152]
    "IMJPMIG8.1 "= "c:\windows\IME\imjp8_1\IMJPMIG.EXE" [2004-08-03 208952]
    "LanguageShortcut "= "c:\program files\CyberLink\PowerDVD\Language\Language.exe" [2006-12-05 54832]
    "MSPY2002 "= "c:\windows\system32\IME\PINTLGNT\ImScInst.exe" [2004-08-03 59392]
    "P2Go_Menu "= "c:\program files\CyberLink\Power2Go\MUITransfer\MUIStartMenu.exe" [2008-01-04 222504]
    "PHIME2002A "= "c:\windows\system32\IME\TINTLGNT\TINTSETP.EXE" [2004-08-03 455168]
    "PHIME2002ASync "= "c:\windows\system32\IME\TINTLGNT\TINTSETP.EXE" [2004-08-03 455168]
    "QuickTime Task "= "e:\program files\QuickTime\QTTask.exe" [2010-03-17 421888]
    "RemoteControl "= "c:\program files\CyberLink\PowerDVD\PDVDServ.exe" [2006-11-23 56928]
    "RTHDCPL "= "RTHDCPL.EXE" [2008-03-06 16858112]
    "SiSPower "= "SiSPower.dll" [2009-06-05 53248]
    "SMSERIAL "= "c:\program files\Motorola\SMSERIAL\sm56hlpr.exe" [2007-01-16 634880]
    "Sony Ericsson PC Suite "= "c:\program files\Sony Ericsson\Mobile2\Application Launcher\Application Launcher.exe" [2005-10-26 159744]
    "SunJavaUpdateSched "= "c:\program files\Common Files\Java\Java Update\jusched.exe" [2010-05-14 248552]
    "Adobe Reader Speed Launcher "= "c:\program files\Adobe\Reader 9.0\Reader\Reader_sl.exe" [2010-09-22 35760]
    "Adobe ARM "= "c:\program files\Common Files\Adobe\ARM\1.0\AdobeARM.exe" [2010-09-20 932288]
    "avgnt "= "e:\avira\AntiVir Desktop\avgnt.exe" [2010-08-02 281768]
    c:\documents and settings\Mahisa Andara\Start Menu\Programs\Startup\
    MagicDisc.lnk - c:\program files\MagicDisc\MagicDisc.exe [2009-8-13 576000]
    c:\documents and settings\All Users\Start Menu\Programs\Startup\
    HP Digital Imaging Monitor.lnk - c:\program files\HP\Digital Imaging\bin\hpqtra08.exe [2006-2-19 288472]
    Microsoft Office.lnk - c:\program files\Microsoft Office\Office\OSA9.EXE [1999-2-18 65588]
    Utility Tray.lnk - c:\windows\system32\sistray.exe [2009-9-26 262144]
    [hkey_local_machine\software\microsoft\windows\currentversion\explorer\ShellExecuteHooks]
    "{5AE067D3-9AFB-48E0-853A-EBB7F4A000DA} "= "c:\program files\SUPERAntiSpyware\SASSEH.DLL" [2008-05-13 77824]
    [HKEY_LOCAL_MACHINE\software\microsoft\windows nt\currentversion\winlogon\notify\!SASWinLogon]
    2009-09-03 22:21 548352 ----a-w- c:\program files\SUPERAntiSpyware\SASWINLO.DLL
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\services]
    "wuauserv "=2 (0x2)
    "wscsvc "=2 (0x2)
    "SNDSrvc "=3 (0x3)
    "npggsvc "=3 (0x3)
    "ccSetMgr "=2 (0x2)
    "ccPwdSvc "=3 (0x3)
    "ccEvtMgr "=2 (0x2)
    "Symantec AntiVirus "=2 (0x2)
    "BthServ "=2 (0x2)
    [HKEY_LOCAL_MACHINE\software\microsoft\security center]
    "AntiVirusOverride "=dword:00000001
    [HKLM\~\services\sharedaccess\parameters\firewallpolicy\standardprofile]
    "EnableFirewall "= 0 (0x0)
    "%windir%\\Network Diagnostic\\xpnetdiag.exe "=
    "c:\\WINDOWS\\system32\\dpnsvr.exe "=
    "c:\\Touhou PoFV\\th09e.exe "=
    "c:\\Program Files\\Microsoft Games\\Age of Empires II\\age2_x1\\age2_x1.exe "=
    "c:\\Program Files\\Rohan Online Indonesia\\rohanclient.exe "=
    "c:\\Program Files\\HP\\Digital Imaging\\bin\\hpqtra08.exe "=
    "c:\\Program Files\\HP\\Digital Imaging\\bin\\hpqste08.exe "=
    "c:\\Program Files\\HP\\Digital Imaging\\bin\\hpofxm08.exe "=
    "c:\\Program Files\\HP\\Digital Imaging\\bin\\hposfx08.exe "=
    "c:\\Program Files\\HP\\Digital Imaging\\bin\\hposid01.exe "=
    "c:\\Program Files\\HP\\Digital Imaging\\bin\\hpqscnvw.exe "=
    "c:\\Program Files\\HP\\Digital Imaging\\bin\\hpqkygrp.exe "=
    "c:\\Program Files\\HP\\Digital Imaging\\bin\\hpqCopy.exe "=
    "c:\\Program Files\\HP\\Digital Imaging\\bin\\hpfccopy.exe "=
    "c:\\Program Files\\HP\\Digital Imaging\\bin\\hpzwiz01.exe "=
    "c:\\Program Files\\HP\\Digital Imaging\\bin\\hpoews01.exe "=
    "c:\\Program Files\\HP\\Digital Imaging\\bin\\hpqnrs08.exe "=
    "c:\\Documents and Settings\\Mahisa Andara\\Application Data\\FlashgetSetup\\fgmini.exe "=
    "c:\\Program Files\\Opera\\opera.exe "=
    "e:\\Program Files\\magic the gathering\\Magic\\Manalink.exe "=
    "e:\\Program Files\\Half-Life SP Pack\\hl.exe "=
    "c:\\WINDOWS\\system32\\winver.exe "=
    [HKLM\~\services\sharedaccess\parameters\firewallpolicy\standardprofile\GloballyOpenPorts\List]
    "3389:TCP "= 3389:TCP:mad:xpsp2res.dll,-22009
    R1 SASDIFSV;SASDIFSV;c:\program files\SUPERAntiSpyware\sasdifsv.sys [2/18/2010 1:25 AM 12872]
    R1 SASKUTIL;SASKUTIL;c:\program files\SUPERAntiSpyware\SASKUTIL.SYS [5/11/2010 1:41 AM 67656]
    R2 AntiVirSchedulerService;Avira AntiVir Scheduler;e:\avira\AntiVir Desktop\sched.exe [11/23/2010 7:50 AM 135336]
    R2 WMDrive;WMDrive;c:\windows\system32\drivers\WMDrive.sys [9/18/2009 3:08 PM 32384]
    S2 clr_optimization_v4.0.30319_32;Microsoft .NET Framework NGEN v4.0.30319_X86;c:\windows\Microsoft.NET\Framework\v4.0.30319\mscorsvw.exe [3/18/2010 1:16 PM 130384]
    S2 gupdate;Google Update Service (gupdate);c:\program files\Google\Update\GoogleUpdate.exe [9/14/2009 11:43 PM 133104]
    S3 hwusbfake;Huawei DataCard USB Fake;c:\windows\system32\drivers\ewusbfake.sys [10/10/2009 12:06 PM 102656]
    S3 K320bus;Sony Ericsson K320 driver (WDM);c:\windows\system32\drivers\K320bus.sys [7/11/2009 9:33 PM 61504]
    S3 K320mdfl;Sony Ericsson K320 USB WMC Modem Filter;c:\windows\system32\drivers\K320mdfl.sys [7/11/2009 9:33 PM 9328]
    S3 K320mdm;Sony Ericsson K320 USB WMC Modem Driver;c:\windows\system32\drivers\K320mdm.sys [7/11/2009 9:33 PM 97056]
    S3 K320mgmt;Sony Ericsson K320 USB WMC Device Management Drivers (WDM);c:\windows\system32\drivers\K320mgmt.sys [7/11/2009 9:33 PM 88560]
    S3 K320obex;Sony Ericsson K320 USB WMC OBEX Interface;c:\windows\system32\drivers\K320obex.sys [7/11/2009 9:33 PM 86368]
    S3 NPF;NetGroup Packet Filter Driver;c:\windows\system32\drivers\npf.sys [10/21/2009 1:19 AM 50704]
    S3 qcusbser;Qualcomm USB Device for Legacy Serial Communication;c:\windows\system32\drivers\qcusbser.sys [8/31/2010 6:50 PM 105984]
    S3 td_cbus;Galaxycom USB Composite Device driver (WDM);c:\windows\system32\drivers\td_cbus.sys [8/20/2009 9:16 AM 51040]
    S3 td_cmdfl;Galaxycom Handset Filter;c:\windows\system32\drivers\td_cmdfl.sys [8/20/2009 9:16 AM 6032]
    S3 td_cmdm;Galaxycom Handset Drivers;c:\windows\system32\drivers\td_cmdm.sys [8/20/2009 9:16 AM 82608]
    S3 td_cserd;Galaxycom Handset Diagnostic Serial Port (WDM);c:\windows\system32\drivers\td_cserd.sys [8/20/2009 9:16 AM 64064]
    S3 WPFFontCache_v0400;Windows Presentation Foundation Font Cache 4.0.0.0;c:\windows\Microsoft.NET\Framework\v4.0.30319\WPF\WPFFontCache_v0400.exe [3/18/2010 1:16 PM 753504]
    S4 npggsvc;nProtect GameGuard Service;c:\windows\system32\GameMon.des -service --> c:\windows\system32\GameMon.des -service [?]
    *NewlyCreated* - SSMDRV
    *Deregistered* - RTCore32
    2010-11-15 c:\windows\Tasks\AppleSoftwareUpdate.job
    - c:\program files\Apple Software Update\SoftwareUpdate.exe [2008-07-30 05:34]
    2010-11-23 c:\windows\Tasks\Google Software Updater.job
    - c:\program files\Google\Common\Google Updater\GoogleUpdaterService.exe [2009-09-14 16:30]
    2010-11-23 c:\windows\Tasks\GoogleUpdateTaskMachineCore.job
    - c:\program files\Google\Update\GoogleUpdate.exe [2009-09-14 16:43]
    2010-11-23 c:\windows\Tasks\GoogleUpdateTaskMachineUA.job
    2010-11-22 c:\windows\Tasks\GoogleUpdateTaskUserS-1-5-21-789336058-606747145-839522115-1003Core.job
    - c:\documents and settings\Mahisa Andara\Local Settings\Application Data\Google\Update\GoogleUpdate.exe [2009-07-31 11:51]
    2010-11-23 c:\windows\Tasks\GoogleUpdateTaskUserS-1-5-21-789336058-606747145-839522115-1003UA.job
    IE: &Translate with ATLAS - c:\program files\ATLAS V14\Atlscript.html
    IE: ATLAS Translation &Editor - c:\program files\ATLAS V14\AtlscriptEdit.html
    IE: Download all by FlashGet3 - c:\documents and settings\Mahisa Andara\Application Data\FlashGetBHO\GetAllUrl.htm
    IE: Download by FlashGet3 - c:\documents and settings\Mahisa Andara\Application Data\FlashGetBHO\GetUrl.htm
    IE: ハケモテソ・オ3マツヤリ - c:\documents and settings\Mahisa Andara\Application Data\FlashGetBHO\GetUrl.htm
    IE: ハケモテソ・オ3マツヤリネォイソチエスモ - c:\documents and settings\Mahisa Andara\Application Data\FlashGetBHO\GetAllUrl.htm
    FF - ProfilePath - c:\documents and settings\Mahisa Andara\Application Data\Mozilla\Firefox\Profiles\5o9qsvby.default\
    FF - plugin: c:\documents and settings\Mahisa Andara\Application Data\Mozilla\Firefox\Profiles\5o9qsvby.default\extensions\yyginstantplay@yoyogames.com\plugins\NPYYGInstantPlay.dll
    FF - plugin: c:\documents and settings\Mahisa Andara\Local Settings\Application Data\Google\Update\1.2.183.39\npGoogleOneClick8.dll
    FF - plugin: c:\program files\Google\Google Earth\plugin\npgeplugin.dll
    FF - plugin: c:\program files\Google\Google Updater\2.4.1698.5652\npCIDetect13.dll
    FF - plugin: c:\program files\Google\Update\1.2.183.39\npGoogleOneClick8.dll
    FF - plugin: e:\program files\QuickTime\Plugins\npqtplugin.dll
    FF - plugin: e:\program files\QuickTime\Plugins\npqtplugin2.dll
    FF - plugin: e:\program files\QuickTime\Plugins\npqtplugin3.dll
    FF - plugin: e:\program files\QuickTime\Plugins\npqtplugin4.dll
    FF - plugin: e:\program files\QuickTime\Plugins\npqtplugin5.dll
    FF - plugin: e:\program files\QuickTime\Plugins\npqtplugin6.dll
    FF - plugin: e:\program files\QuickTime\Plugins\npqtplugin7.dll
    FF - HiddenExtension: Microsoft .NET Framework Assistant: {20a82645-c095-46ed-80e3-08825760534b} - c:\windows\Microsoft.NET\Framework\v3.5\Windows Presentation Foundation\DotNetAssistantExtension\
    c:\program files\Mozilla Firefox\greprefs\all.js - pref( "network.IDN.whitelist.xn--mgbaam7a8h ", true);
    c:\program files\Mozilla Firefox\greprefs\all.js - pref( "network.IDN.whitelist.xn--fiqz9s ", true); // Traditional
    c:\program files\Mozilla Firefox\greprefs\all.js - pref( "network.IDN.whitelist.xn--fiqs8s ", true); // Simplified
    c:\program files\Mozilla Firefox\greprefs\all.js - pref( "network.IDN.whitelist.xn--j6w193g ", true);
    c:\program files\Mozilla Firefox\greprefs\all.js - pref( "network.IDN.whitelist.xn--mgberp4a5d4ar ", true);
    c:\program files\Mozilla Firefox\greprefs\all.js - pref( "network.IDN.whitelist.xn--mgberp4a5d4a87g ", true);
    c:\program files\Mozilla Firefox\greprefs\all.js - pref( "network.IDN.whitelist.xn--mgbqly7c0a67fbc ", true);
    c:\program files\Mozilla Firefox\greprefs\all.js - pref( "network.IDN.whitelist.xn--mgbqly7cvafr ", true);
    c:\program files\Mozilla Firefox\greprefs\all.js - pref( "network.IDN.whitelist.xn--kpry57d ", true); // Traditional
    c:\program files\Mozilla Firefox\greprefs\all.js - pref( "network.IDN.whitelist.xn--kprw13d ", true); // Simplified
    c:\program files\Mozilla Firefox\defaults\pref\firefox.js - pref( "dom.ipc.plugins.enabled ", false);
    HKLM-Explorer_Run-Essentials - c:\windows\system\run\rundll32.exe
    ActiveSetup-{9CB5900A-8628-A49B-FEA5-DF23A5520525} - c:\windows\system32:Shdll.exe
    Rootkit scan 2010-11-23 10:15
    Windows 5.1.2600 Service Pack 3 NTFS
    scanning hidden processes ...
    scanning hidden files ...
    scan completed successfully
    hidden files: 0
    [HKEY_LOCAL_MACHINE\System\ControlSet001\Services\npggsvc]
    "ImagePath "= "c:\windows\system32\GameMon.des -service "
    [HKEY_USERS\S-1-5-21-789336058-606747145-839522115-1003\Software\Microsoft\Windows\CurrentVersion\Explorer\MenuOrder\Start Menu2\Programs\Xuse\8l`刃0「0サ0・「0 *
     *S0n0'Y0Wn0徃f0g0 *
    "Order "=hex:08,00,00,00,02,00,00,00,46,03,00,00,01,00,00,00,06,00,00,00,a0,00,
    00,00,00,00,00,00,92,00,00,00,41,75,67,4d,02,00,00,00,01,00,00,00,80,00,36,\
    [HKEY_USERS\S-1-5-21-789336058-606747145-839522115-1003\Software\Microsoft\Windows\CurrentVersion\Shell Extensions\Approved\{73F8686D-FDAF-F515-4E11-8ABCC6BB7C6D}*]
    @Allowed: (Read) (RestrictedCode)
    - - - - - - - > 'winlogon.exe'(692)
    Completion time: 2010-11-23 10:17:19
    ComboFix-quarantined-files.txt 2010-11-23 03:17
    Pre-Run: 4,722,204,672 bytes free
    Post-Run: 4,691,836,928 bytes free
    WindowsXP-KB310994-SP2-Pro-BootDisk-ENU.exe
    [boot loader]
    timeout=2
    default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS
    [operating systems]
    c:\cmdcons\BOOTSECT.DAT= "Microsoft Windows Recovery Console" /cmdcons
    UnsupportedDebug= "do not select this" /debug
    multi(0)disk(0)rdisk(0)partition(1)\WINDOWS= "Microsoft Windows XP Professional" /noexecute=optin /fastdetect
    - - End Of File - - 2236281DE292AE898C4DA8D5794EB61D
  5. 2010/11/22
    1. Please open Notepad
    • Click Start , then Run
    • Type notepad .exe in the Run Box.
    2. Now copy/paste the entire content of the codebox below into the Notepad window:
    File::
    Registry::
     "AntiVirusOverride "=-
     "EnableFirewall "=dword:00000001
    3. Save the above as CFScript.txt
    4. Close/disable all anti virus and anti malware programs again, so they do not interfere with the running of ComboFix.
    5. Then drag the CFScript.txt into ComboFix.exe as depicted in the animation below. This will start ComboFix again.
    6. After reboot, (in case it asks to reboot), please post the following reports/logs into your next reply:
    • Combofix.txt
  6. 2010/11/23
    mahisa78
    mahisa78 Inactive Thread Starter
    Here's the log
    ComboFix 10-11-22.05 - Mahisa Andara 3/2010 Tue 13:18:32.2.2 - x86
    Microsoft Windows XP Professional 5.1.2600.3.932.81.1033.18.989.559 [GMT 7:00]
    Running from: c:\documents and settings\Mahisa Andara\Desktop\ComboFix.exe
    Command switches used :: c:\documents and settings\Mahisa Andara\Desktop\CFScript.txt
    AV: AntiVir Desktop *On-access scanning disabled* (Updated) {AD166499-45F9-482A-A743-FDD3350758C7}
    FILE ::
    "c:\windows\shdll.exe "
    2010-11-23 05:55 . 2010-11-23 05:55 -------- d-----w- c:\windows\LastGood
    ((((((((((((((((((((((((((((( SnapShot@2010-11-23_03.15.32 )))))))))))))))))))))))))))))))))))))))))
    + 2010-11-23 05:50 . 2010-11-23 05:50 16384 c:\windows\Temp\Perflib_Perfdata_d4.dat
    + 2001-08-23 11:00 . 2010-11-23 05:54 83932 c:\windows\system32\perfc009.dat
    - 2001-08-23 11:00 . 2010-11-23 01:09 83932 c:\windows\system32\perfc009.dat
    + 2001-08-23 11:00 . 2010-11-23 05:54 493388 c:\windows\system32\perfh009.dat
    - 2001-08-23 11:00 . 2010-11-23 01:09 493388 c:\windows\system32\perfh009.dat
    "wuauserv "=2 (0x2)
    "wscsvc "=2 (0x2)
    "SNDSrvc "=3 (0x3)
    "npggsvc "=3 (0x3)
    "ccSetMgr "=2 (0x2)
    "ccPwdSvc "=3 (0x3)
    "ccEvtMgr "=2 (0x2)
    "BthServ "=2 (0x2)
    2010-11-23 c:\windows\Tasks\GoogleUpdateTaskUserS-1-5-21-789336058-606747145-839522115-1003Core.job
    Rootkit scan 2010-11-23 13:25
    hidden files: 0
    Completion time: 2010-11-23 13:27:13
    ComboFix-quarantined-files.txt 2010-11-23 06:27
    ComboFix2.txt 2010-11-23 03:17
    Pre-Run: 4,513,050,624 bytes free
    Post-Run: 4,499,341,312 bytes free
    - - End Of File - - 6D680E46236121874B4EA4EADB0DF79B
  7. 2010/11/23
    How is computer doing?
    Download OTL to your Desktop.
    • Double click on the icon to run it. Make sure all other windows are closed and to let it run uninterrupted.
    • Under the Custom Scan box paste this in:
    netsvcs
    drivers32
    %SYSTEMDRIVE%\*.*
    %systemroot%\Fonts\*.com
    %systemroot%\Fonts\*.dll
    %systemroot%\Fonts\*.ini
    %systemroot%\Fonts\*.ini2
    %systemroot%\Fonts\*.exe
    %systemroot%\system32\spool\prtprocs\w32x86\*.*
    %systemroot%\REPAIR\*.bak1
    %systemroot%\REPAIR\*.ini
    %systemroot%\*.scr
    %systemroot%\*._sy
    %APPDATA%\Adobe\Update\*.*
    %ALLUSERSPROFILE%\Favorites\*.*
    %APPDATA%\Microsoft\*.*
    %PROGRAMFILES%\*.*
    %APPDATA%\Update\*.*
    %systemroot%\*. /mp /s
    CREATERESTOREPOINT
    %systemroot%\System32\config\*.sav
    %PROGRAMFILES%\bak. /s
    %systemroot%\system32\bak. /s
    %ALLUSERSPROFILE%\Start Menu\*.lnk /x
    %systemroot%\system32\config\systemprofile\*.dat /x
    %systemroot%\*.config
    %systemroot%\system32\*.db
    %APPDATA%\Microsoft\Internet Explorer\Quick Launch\*.lnk /x
    %USERPROFILE%\Desktop\*.exe
    %PROGRAMFILES%\Common Files\*.*
    %systemroot%\*.src
    %systemroot%\install\*.*
    %systemroot%\system32\DLL\*.*
    %systemroot%\system32\HelpFiles\*.*
    %systemroot%\system32\rundll\*.*
    %systemroot%\winn32\*.*
    %systemroot%\Java\*.*
    %systemroot%\system32\test\*.*
    %systemroot%\system32\Rundll32\*.*
    %systemroot%\AppPatch\Custom\*.*
    %APPDATA%\Roaming\Microsoft\Windows\Recent\*.lnk /x
    %PROGRAMFILES%\PC-Doctor\Downloads\*.*
    %PROGRAMFILES%\Internet Explorer\*.tmp
    %PROGRAMFILES%\Internet Explorer\*.dat
    %USERPROFILE%\My Documents\*.exe
    %USERPROFILE%\*.exe
    %systemroot%\ADDINS\*.*
    %systemroot%\assembly\*.bak2
    %systemroot%\Config\*.*
    %systemroot%\REPAIR\*.bak2
    %systemroot%\SECURITY\Database\*.sdb /x
    %systemroot%\SYSTEM\*.bak2
    %systemroot%\Web\*.bak2
    %systemroot%\Driver Cache\*.*
    %PROGRAMFILES%\Mozilla Firefox\0*.exe
    %ProgramFiles%\Microsoft Common\*.*
    %ProgramFiles%\TinyProxy.
    %USERPROFILE%\Favorites\*.url /x
    %systemroot%\system32\*.bk
    %systemroot%\*.te
    %systemroot%\system32\system32\*.*
    %ALLUSERSPROFILE%\*.dat /x
    %systemroot%\system32\drivers\*.rmv
    dir /b "%systemroot%\system32\*.exe" | find /i " " /c
    dir /b "%systemroot%\*.exe" | find /i " " /c
    %PROGRAMFILES%\Microsoft\*.*
    %systemroot%\System32\Wbem\proquota.exe
    %PROGRAMFILES%\Mozilla Firefox\*.dat
    %USERPROFILE%\Cookies\*.txt /x
    %SystemRoot%\system32\fonts\*.*
    %systemroot%\system32\winlog\*.*
    %systemroot%\system32\Language\*.*
    %systemroot%\system32\Settings\*.*
    %systemroot%\system32\*.quo
    %SYSTEMROOT%\AppPatch\*.exe
    %SYSTEMROOT%\inf\*.exe
    %SYSTEMROOT%\Installer\*.exe
    %systemroot%\system32\config\*.bak2
    %systemroot%\system32\Computers\*.*
    %SystemRoot%\system32\Sound\*.*
    %SystemRoot%\system32\SpecialImg\*.*
    %SystemRoot%\system32\code\*.*
    %SystemRoot%\system32\draft\*.*
    %SystemRoot%\system32\MSSSys\*.*
    %ProgramFiles%\Javascript\*.*
    %systemroot%\pchealth\helpctr\System\*.exe /s
    %systemroot%\Web\*.exe
    %systemroot%\system32\msn\*.*
    %systemroot%\system32\*.tro
    %AppData%\Microsoft\Installer\msupdates\*.*
    %ProgramFiles%\Messenger\*.*
    %systemroot%\system32\systhem32\*.*
    %systemroot%\system\*.exe
    HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows\WindowsUpdate\AU
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\WindowsUpdate\Auto Update\Results\Install|LastSuccessTime /rs
    /md5start
    /md5stop
    • Click the Quick Scan button. Do not change any settings unless otherwise told to do so. The scan wont take long.
    • When the scan completes, it will open two notepad windows: OTL.txt and Extras.txt. These are saved in the same location as OTL.
    • Please copy (Edit->Select All, Edit->Copy) the contents of these files, one at a time, and post them back here.
  8. 2010/11/23
    mahisa78
    OTL Extras logfile created on: 11/24/2010 7:57:13 AM - Run 1
    OTL by OldTimer - Version 3.2.17.3 Folder = C:\Documents and Settings\Mahisa Andara\Desktop
    Windows XP Professional Edition Service Pack 3 (Version = 5.1.2600) - Type = NTWorkstation
    Internet Explorer (Version = 6.0.2900.2180)
    Locale: 00000409 | Country: United States | Language: ENU | Date Format: M/d/yyyy
    989.00 Mb Total Physical Memory | 469.00 Mb Available Physical Memory | 47.00% Memory free
    4.00 Gb Paging File | 3.00 Gb Available in Paging File | 89.00% Paging File free
    Paging file location(s): C:\pagefile.sys 0 0E:\pagefile.sys 0 0 [binary data]
    %SystemDrive% = C: | %SystemRoot% = C:\WINDOWS | %ProgramFiles% = C:\Program Files
    Drive C: | 78.13 Gb Total Space | 6.07 Gb Free Space | 7.77% Space Free | Partition Type: NTFS
    Drive E: | 70.92 Gb Total Space | 6.67 Gb Free Space | 9.40% Space Free | Partition Type: NTFS
    Computer Name: MAHISA | User Name: Mahisa Andara | Logged in as Administrator.
    Boot Mode: Normal | Scan Mode: Current user | Quick Scan
    Company Name Whitelist: On | Skip Microsoft Files: On | No Company Name Whitelist: On | File Age = 30 Days
    ========== Extra Registry (SafeList) ==========
    ========== File Associations ==========
    [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\<extension>]
    [HKEY_CURRENT_USER\SOFTWARE\Classes\<extension>]
    .html [@ = ChromeHTML] -- Reg Error: Key error. File not found
    ========== Shell Spawning ==========
    [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\<key>\shell\[command]\command]
    batfile [open] -- "%1" %*
    cmdfile [open] -- "%1" %*
    comfile [open] -- "%1" %*
    exefile [open] -- "%1" %*
    htmlfile [edit] -- "C:\Program Files\Microsoft Office\Office\msohtmed.exe" %1 (Microsoft Corporation)
    piffile [open] -- "%1" %*
    regfile [merge] -- Reg Error: Key error.
    scrfile [config] -- "%1 "
    scrfile [install] -- rundll32.exe desk.cpl,InstallScreenSaver %l (Microsoft Corporation)
    scrfile [open] -- "%1" /S
    txtfile [edit] -- Reg Error: Key error.
    Unknown [openas] -- %SystemRoot%\system32\rundll32.exe %SystemRoot%\system32\shell32.dll,OpenAs_RunDLL %1
    Directory [find] -- %SystemRoot%\Explorer.exe (Microsoft Corporation)
    Folder [open] -- %SystemRoot%\Explorer.exe /idlist,%I,%L (Microsoft Corporation)
    Folder [explore] -- %SystemRoot%\Explorer.exe /e,/idlist,%I,%L (Microsoft Corporation)
    Drive [find] -- %SystemRoot%\Explorer.exe (Microsoft Corporation)
    ========== Security Center Settings ==========
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center]
    "FirstRunDisabled" = 1
    "AntiVirusDisableNotify" = 0
    "FirewallDisableNotify" = 0
    "UpdatesDisableNotify" = 0
    "FirewallOverride" = 0
    "AntiVirusOverride" = 0
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\AhnlabAntiVirus]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\ComputerAssociatesAntiVirus]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\KasperskyAntiVirus]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\McAfeeAntiVirus]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\McAfeeFirewall]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\PandaAntiVirus]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\PandaFirewall]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\SophosAntiVirus]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\SymantecAntiVirus]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\SymantecFirewall]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\TinyFirewall]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\TrendAntiVirus]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\TrendFirewall]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\ZoneLabsFirewall]
    ========== System Restore Settings ==========
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\SystemRestore]
    "DisableSR" = 0
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Sr]
    "Start" = 0
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SrService]
    "Start" = 2
    ========== Firewall Settings ==========
    [HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\WindowsFirewall]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\WindowsFirewall\DomainProfile]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\WindowsFirewall\StandardProfile]
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SharedAccess\Parameters\FirewallPolicy\DomainProfile]
    "DoNotAllowExceptions" = 0
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SharedAccess\Parameters\FirewallPolicy\DomainProfile\GloballyOpenPorts\List]
    "139:TCP" = 139:TCP:*:Enabled:mad:xpsp2res.dll,-22004
    "445:TCP" = 445:TCP:*:Enabled:mad:xpsp2res.dll,-22005
    "137:UDP" = 137:UDP:*:Enabled:mad:xpsp2res.dll,-22001
    "138:UDP" = 138:UDP:*:Enabled:mad:xpsp2res.dll,-22002
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SharedAccess\Parameters\FirewallPolicy\StandardProfile]
    "EnableFirewall" = 1
    "DisableNotifications" = 0
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SharedAccess\Parameters\FirewallPolicy\StandardProfile\GloballyOpenPorts\List]
    "139:TCP" = 139:TCP:LocalSubNet:Enabled:mad:xpsp2res.dll,-22004
    "445:TCP" = 445:TCP:LocalSubNet:Enabled:mad:xpsp2res.dll,-22005
    "137:UDP" = 137:UDP:LocalSubNet:Enabled:mad:xpsp2res.dll,-22001
    "138:UDP" = 138:UDP:LocalSubNet:Enabled:mad:xpsp2res.dll,-22002
    "3389:TCP" = 3389:TCP:*:Enabled:mad:xpsp2res.dll,-22009
    "1900:UDP" = 1900:UDP:LocalSubNet:Disabled:mad:xpsp2res.dll,-22007
    "2869:TCP" = 2869:TCP:LocalSubNet:Disabled:mad:xpsp2res.dll,-22008
    ========== Authorized Applications List ==========
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SharedAccess\Parameters\FirewallPolicy\DomainProfile\AuthorizedApplications\List]
    "D:\WAG200G.exe" = D:\WAG200G.exe:*:Enabled:WAG200G.exe -- File not found
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SharedAccess\Parameters\FirewallPolicy\StandardProfile\AuthorizedApplications\List]
    "C:\WINDOWS\system32\dpnsvr.exe" = C:\WINDOWS\system32\dpnsvr.exe:*:Enabled:Microsoft DirectPlay8 Server -- (Microsoft Corporation)
    "C:\Touhou PoFV\th09e.exe" = C:\Touhou PoFV\th09e.exe:*:Enabled:th09e -- ()
    "C:\Program Files\Microsoft Games\Age of Empires II\age2_x1\age2_x1.exe" = C:\Program Files\Microsoft Games\Age of Empires II\age2_x1\age2_x1.exe:*:Enabled:Age of Empires II Expansion -- (Microsoft Corporation)
    "C:\Program Files\Rohan Online Indonesia\rohanclient.exe" = C:\Program Files\Rohan Online Indonesia\rohanclient.exe:*:Enabled:Rohan -- (YNK Games)
    "C:\Program Files\HP\Digital Imaging\bin\hpofxm08.exe" = C:\Program Files\HP\Digital Imaging\bin\hpofxm08.exe:*:Enabled:hpofxm08.exe -- (Hewlett-Packard Development Company, L.P.)
    "C:\Program Files\HP\Digital Imaging\bin\hposfx08.exe" = C:\Program Files\HP\Digital Imaging\bin\hposfx08.exe:*:Enabled:hposfx08.exe -- (Hewlett-Packard Development Company, L.P.)
    "C:\Program Files\HP\Digital Imaging\bin\hposid01.exe" = C:\Program Files\HP\Digital Imaging\bin\hposid01.exe:*:Enabled:hposid01.exe -- (Hewlett-Packard Development Company, L.P.)
    "C:\Program Files\HP\Digital Imaging\bin\hpqCopy.exe" = C:\Program Files\HP\Digital Imaging\bin\hpqCopy.exe:*:Enabled:hpqcopy.exe -- (Hewlett-Packard Development Company, L.P.)
    "C:\Program Files\HP\Digital Imaging\bin\hpfccopy.exe" = C:\Program Files\HP\Digital Imaging\bin\hpfccopy.exe:*:Enabled:hpfccopy.exe -- (Hewlett-Packard)
    "C:\Program Files\HP\Digital Imaging\bin\hpzwiz01.exe" = C:\Program Files\HP\Digital Imaging\bin\hpzwiz01.exe:*:Enabled:hpzwiz01.exe -- (Hewlett-Packard Development Company, L.P.)
    "C:\Program Files\HP\Digital Imaging\bin\hpoews01.exe" = C:\Program Files\HP\Digital Imaging\bin\hpoews01.exe:*:Enabled:hpoews01.exe -- (Hewlett-Packard Development Company, L.P.)
    "C:\Documents and Settings\Mahisa Andara\Application Data\FlashgetSetup\fgmini.exe" = C:\Documents and Settings\Mahisa Andara\Application Data\FlashgetSetup\fgmini.exe:*:Enabled:fg_ol_silent -- (Flashget)
    "C:\Program Files\Opera\opera.exe" = C:\Program Files\Opera\opera.exe:*:Enabled:Opera Internet Browser -- (Opera Software)
    "E:\Program Files\magic the gathering\Magic\Manalink.exe" = E:\Program Files\magic the gathering\Magic\Manalink.exe:*:Enabled:manalink -- (MicroProse Software, Inc.)
    "E:\Program Files\Half-Life SP Pack\hl.exe" = E:\Program Files\Half-Life SP Pack\hl.exe:*:Enabled:Half-Life Launcher -- (Valve)
    "C:\WINDOWS\system32\winver.exe" = C:\WINDOWS\system32\winver.exe:*:Enabled:winver -- (Microsoft Corporation)
    ========== HKEY_LOCAL_MACHINE Uninstall List ==========
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall]
    "{00010409-78E1-11D2-B60F-006097C998E7}" = Microsoft Office 2000 Professional
    "{01386D1F-ADE7-43B4-A4E9-312FC5BC726F}_is1" = SWF Opener
    "{01501EBA-EC35-4F9F-8889-3BE346E5DA13}" = MSXML4 Parser
    "{044F9133-B8D7-4d11-BF39-803FA20F5C8B}" = Microsoft Windows SDK for Visual Studio 2008 SP1 Express Tools for Win32
    "{05C56753-F144-44BC-BA67-83CC5DBF395C}" = F300
    "{068724F8-D8BE-4B43-8DDD-B9FE9E49FD76}" = Scansoft PDF Professional
    "{0A0CADCF-78DA-33C4-A350-CD51849B9702}" = Microsoft .NET Framework 4 Extended
    "{0C19D563-5F25-4621-BF10-01F741BD283F}" = Microsoft SQL Server Compact 3.5 SP1 Design Tools English
    "{1FBF6C24-C1FD-4101-A42B-0C564F9E8E79}" = CyberLink DVD Suite
    "{2376813B-2E5A-4641-B7B3-A0D5ADB55229}" = HPPhotoSmartExpress
    "{26A24AE4-039D-4CA4-87B4-2F83216020FF}" = Java(TM) 6 Update 22
    "{28BE306E-5DA6-4F9C-BDB0-DBA3C8C6FFFD}" = QuickTime
    "{33BBE45C-6296-488A-B7D5-37E692E71B3F}" = TortoiseSVN 1.6.5.16974 (32 bit)
    "{342D4AD7-EC4C-4EC8-AEA6-E70F5905A490}" = SQL Server System CLR Types
    "{350C97B0-3D7C-4EE8-BAA9-00BCB3D54227}" = WebFldrs XP
    "{394BE3D9-7F57-4638-A8D1-1D88671913B7}" = Microsoft AppLocale
    "{3C3901C5-3455-3E0A-A214-0B093A5070A6}" = Microsoft .NET Framework 4 Client Profile
    "{3C3D696B-0DB7-3C6D-A356-3DB8CE541918}" = Microsoft Visual C++ 2008 Redistributable - x86 9.0.30729
    "{40BF1E83-20EB-11D8-97C5-0009C5020658}" = CyberLink Power2Go
    "{4286E640-B5FB-11DF-AC4B-005056C00008}" = Google Earth
    "{45B8A76B-57EC-4242-B019-066400CD8428}" = BufferChm
    "{485C9280-B899-4D46-86F3-B3E459636EE5}" = Yu-Gi-Oh! Power of Chaos KAIBA THE REVENGE
    "{4A03706F-666A-4037-7777-5F2748764D10}" = Java Auto Updater
    "{4EA684E9-5C81-4033-A696-3019EC57AC3A}" = HPProductAssistant
    "{553255F3-78FD-40F1-A6F8-6882140265FE}" = Apple Application Support
    "{5A9FE525-8B8F-4701-A937-7F6745A4E9C7}" = RGSS-RTP Standard
    "{5BE1E709-30E4-3D6D-A708-96CE8D5E5E8D}" = Microsoft Windows SDK for Visual Studio 2008 SP1 Express Tools for .NET Framework - enu
    "{5F0FC860-ADE1-4B2D-B0A9-CB9FB17C46E8}" = Sony Ericsson PC Suite
    "{6652750B-AA69-49B7-9D09-C0A28B6FFC9F}" = ATLAS Translation Standard V14.0 Trial Version
    "{66910000-8B30-4973-A159-6371345AFFA5}" = WebReg
    "{66D6F3BD-CA23-41A4-9FA3-96B26B32528C}" = Command & Conquer The First Decade
    "{66E6CE0C-5A1E-430C-B40A-0C90FF1804A8}" = eSupportQFolder
    "{6811CAA0-BF12-11D4-9EA1-0050BAE317E1}" = PowerDVD
    "{68763C27-235D-4165-A961-FDEA228CE504}" = AiOSoftwareNPI
    "{6909F917-5499-482e-9AA1-FAD06A99F231}" = Toolbox
    "{6956856F-B6B3-4BE0-BA0B-8F495BE32033}" = Apple Software Update
    "{6994491D-D491-48F1-AE1F-E179C1FFFC2F}" = HP Photosmart Essential
    "{6AE22174-4FFA-4572-B692-31F0C386ED38}" = Consolas Font Family
    "{6BFDC0CD-ADF5-49F6-8A47-3177EF2AE6D2}" = Google Book Downloader
    "{6F5E2F4A-377D-4700-B0E3-8F7F7507EA15}" = CustomerResearchQFolder
    "{71AFF3E0-1B1D-426E-AF70-8880BA70EE8C}" = Galaxycom USB Modem
    "{7299052b-02a4-4627-81f2-1818da5d550d}" = Microsoft Visual C++ 2005 Redistributable
    "{736C803C-DD3B-4015-BC51-AFB9E67B9076}" = Readme
    "{76314E3E-BD04-47AF-9765-9FA798FC5B01}" = Nuance PDF Professional 5
    "{7E7B7865-6C80-4373-8BC1-C2EB9431F9DE}" = ProductContextNPI
    "{7F23ED88-D755-4A3A-AB04-E909C7C0330A}" = Yu-Gi-Oh! Power of Chaos YUGI THE DESTINY 2.0
    "{8331C3EA-0C91-43AA-A4D4-27221C631139}" = Status
    "{842FAF7C-50EF-4463-9B8F-6222E1384D7D}" = Microsoft Windows SDK for Visual Studio 2008 Headers and Libraries
    "{85F4CBCB-9BBC-4B50-A7D8-E1106771498D}" = Orca
    "{87CC8013-56D1-43E1-A0A5-AD406B4EBA95}" = Opera 10.63
    "{90120000-0020-0409-0000-0000000FF1CE}" = Compatibility Pack for the 2007 Office system
    "{996512CF-F35B-48DE-9291-557FA5316967}" = ScannerCopy
    "{9B34CAC6-738F-4A20-B428-A115C3E3474C}" = RPGXP
    "{A3051CD0-2F64-3813-A88D-B8DCCDE8F8C7}" = Microsoft .NET Framework 3.0 Service Pack 2
    "{A92DAB39-4E2C-4304-9AB6-BC44E68B55E2}" = Google Update Helper
    "{AB5D51AE-EBC3-438D-872C-705C7C2084B0}" = DeviceManagementQFolder
    "{AC76BA86-7AD7-1033-7B44-A94000000001}" = Adobe Reader 9.4.1
    "{BB85ED9C-AFC9-43BD-B8DC-258C3C7DF72E}" = HP Software Update
    "{BDBE2F3E-42DB-4d4a-8CB1-19BA765DBC6C}" = HP Photosmart, Officejet and Deskjet 7.0.A
    "{C09FB3CD-3D0C-3F2D-899A-6A1D67F2073F}" = Microsoft .NET Framework 2.0 Service Pack 2
    "{C3C9EB3D-24FA-4462-B784-0EC6AAFCD2DD}" = Fable - The Lost Chapters
    "{C427E746-4EC9-4E3C-AACB-C6BB1F714D7F}" = Uniblue DriverScanner 2009
    "{C7F54CF8-D6FB-4E0A-93A3-E68AE0D6C476}" = SolutionCenter
    "{C8753E28-2680-49BF-BD48-DD38FD086EFE}" = AiO_Scan_CDA
    "{C8A86EA6-DB77-4A33-830F-D5BCCC24457A}" = ギャラクシーエンジェル
    "{CDDCBBF1-2703-46BC-938B-BCC81A1EEAAA}" = SUPERAntiSpyware
    "{CE2CDD62-0124-36CA-84D3-9F4DCF5C5BD9}" = Microsoft .NET Framework 3.5 SP1
    "{D8087907-E255-3A41-A46D-D0F798709C71}" = Microsoft Visual C++ 2008 Express Edition with SP1 - ENU
    "{DA7F8DA4-FDC6-4491-88EE-C03798D373EF}" = Emil Chronicle Online
    "{DBC20735-34E6-4E97-A9E5-2066B66B243D}" = TrayApp
    "{DC226AC9-0314-496C-BE6A-B6A132628466}" = SiSAGP driver
    "{DD622B1D-A78E-3FE8-9C8C-246F5764B0D0}" = Microsoft Visual Basic 2008 Express Edition with SP1 - ENU
    "{deb7008b-681e-4a4a-8aae-cc833e8216ce}.sdb" = Microsoft Windows Application Compatibility Database
    "{E1B80DEE-A795-4258-8445-074C06AE3AB8}" = MarketResearch
    "{E59113EB-0285-4BFD-A37A-B79EAC6B8F4B}" = Microsoft SQL Server Compact 3.5 SP1 English
    "{E5966E4C-0A93-4F59-A981-BD3173D4799F}" = F300_Help
    "{F132AF7F-7BCA-4EDE-8A7C-958108FE7DBC}" = Realtek High Definition Audio Driver
    "{F157460F-720E-482f-8625-AD7843891E5F}" = InstantShareDevicesMFC
    "{F3760724-B29D-465B-BC53-E5D72095BCC4}" = Scan
    "{F5E87B12-3C27-452F-8E78-21D42164FD83}" = Microsoft SQL Server 2008 Management Objects
    "{F6076EF9-08E1-442F-B6A2-BFB61B295A14}" = Fax_CDA
    "{FB15E224-67C3-491F-9F5C-F257BC418412}" = Destinations
    "{FBB980B0-63F8-4B48-8D65-90F1D9F81D9F}" = NewCopy_CDA
    "40 Days and 40 Nights of Rain" = 40 Days and 40 Nights of Rain 1.0e
    "Adobe Flash Player Plugin" = Adobe Flash Player 10 Plugin
    "Adobe Shockwave Player" = Adobe Shockwave Player 11.5
    "Advance Wars Series Map Editor" = Advance Wars Series Map Editor 1.0
    "Age of Empires 2.0" = Microsoft Age of Empires II
    "Age of Empires II: The Conquerors Expansion 1.0" = Microsoft Age of Empires II: The Conquerors Expansion
    "Age of Mythology 1.0" = Age of Mythology
    "Age of Mythology Expansion Pack 1.0" = Age of Mythology - The Titans Expansion
    "Anything 4 Love (v1.10)" = Anything 4 Love (v1.10)
    "Applian FLV Player2.0.24" = Applian FLV Player
    "AquariaDemo" = Aquaria Demo
    "Audacity_is1" = Audacity 1.2.6
    "Avira AntiVir Desktop" = Avira AntiVir Personal - Free Antivirus
    "Bootfighter Windom XP sp-2.NET_is1" = Bootfighter Windom XP sp-2.NET v1.030+
    "Cave Story Deluxe" = Cave Story Deluxe
    "CCleaner" = CCleaner
    "Cheat Engine 5.5_is1" = Cheat Engine 5.5
    "Combined Community Codec Pack_is1" = Combined Community Codec Pack 2008-09-21 16:18
    "Deus Ex - Game of the Year" = Deus Ex - Game of the Year (remove only)
    "Diablo II" = Diablo II
    "DirectVobSub" = DirectVobSub (remove only)
    "File Splitter and Joiner_is1" = File Splitter and Joiner (FFSJ v3.3)
    "FINAL FANTASY VIII" = FINAL FANTASY VIII
    "FlashOffliner" = FlashOffliner 1.0
    "Free Download Manager_is1" = Free Download Manager 3.0
    "Google Updater" = Google Updater
    "Half-Life" = Half-Life
    "Half-Life Source" = Half-Life Source
    "Half-Life SP Pack" = Half-Life SP Pack
    "HP Imaging Device Functions" = HP Imaging Device Functions 7.0
    "HP Solution Center & Imaging Support Tools" = HP Solution Center 7.0
    "HPExtendedCapabilities" = HP Customer Participation Program 7.0
    "Idol StreetBest Friends" = Idol Street
    "ImgBurn" = ImgBurn
    "Indosat 3.5G connect" = Indosat 3.5G connect
    "InstallShield_{40BF1E83-20EB-11D8-97C5-0009C5020658}" = CyberLink Power2Go
    "InstallShield_{C3C9EB3D-24FA-4462-B784-0EC6AAFCD2DD}" = Fable - The Lost Chapters
    "IsoBuster_is1" = IsoBuster 2.8
    "LiveUpdate" = LiveUpdate 2.0 (Symantec Corporation)
    "MagicDisc 2.7.106" = MagicDisc 2.7.106
    "Malwarebytes' Anti-Malware_is1" = Malwarebytes' Anti-Malware
    "Microsoft .NET Framework 3.5 SP1" = Microsoft .NET Framework 3.5 SP1
    "Microsoft .NET Framework 4 Client Profile" = Microsoft .NET Framework 4 Client Profile
    "Microsoft .NET Framework 4 Extended" = Microsoft .NET Framework 4 Extended
    "Microsoft DirectX SDK (August 2009)" = Microsoft DirectX SDK (August 2009)
    "Microsoft Visual Basic 2008 Express Edition with SP1 - ENU" = Microsoft Visual Basic 2008 Express Edition with SP1 - ENU
    "Microsoft Visual C++ 2008 Express Edition with SP1 - ENU" = Microsoft Visual C++ 2008 Express Edition with SP1 - ENU
    "Mozilla Firefox (3.6.12)" = Mozilla Firefox (3.6.12)
    "MP3 Bitrate Changer_is1" = MP3 Bitrate Changer 1.1
    "MSCompPackV1" = Microsoft Compression Client Pack 1.0 for Windows XP
    "MSNINST" = MSN
    "NirSoft VideoCacheView" = NirSoft VideoCacheView
    "NirSoft WebVideoCap" = NirSoft WebVideoCap
    "PerformanceTest 7_is1" = PerformanceTest v7.0
    "Plain Song" = Plain Song Christmas Special
    "planetarian" = planetarian English Patch
    "RAR Password Cracker" = RAR Password Cracker 4.12
    "Rohan Online Indonesia" = Rohan Online Indonesia
    "Rosenkreuzstilette ~Blades of the Rose Cross~" = Rosenkreuzstilette ~Blades of the Rose Cross~
    "RPG Maker 2000 1.07b" = RPG Maker 2000 1.07b
    "RTP for RM2K (Png, Wav, Midi, Fonts)" = RTP for RM2K (Png, Wav, Midi, Fonts)
    "Sanny Builder 3_is1" = Sanny Builder 3.04
    "SBPSolver" = SBPSolver
    "Sierra Utilities" = Sierra Utilities
    "SiS VGA Driver" = SiS VGA Utilities
    "SMSERIAL" = Motorola SM56 Data Fax Modem
    "SpeedFan" = SpeedFan (remove only)
    "ST4UNST #1" = Visual Basic 4 Runtime Files
    "ST4UNST #2" = Runtime Files Pack 3
    "Starcraft" = Starcraft
    "StarCraft X-tra Editor (Professional Edition)_is1" = StarCraft X-tra Editor Version 2.5
    "The Poor Little Bird" = The Poor Little Bird 1.0E
    "Uniblue DriverScanner 2009" = Uniblue DriverScanner 2009
    "Universal Extractor_is1" = Universal Extractor 1.6.1
    "Visual Basic 6.0 Enterprise Edition" = Microsoft Visual Basic 6.0 Enterprise Edition
    "WebPost" = Microsoft Web Publishing Wizard 1.53
    "Windows Media Format Runtime" = Windows Media Format 11 runtime
    "Windows Media Player" = Windows Media Player 11
    "Windows XP Service Pack" = Windows XP Service Pack 3
    "WinMount3_is1" = WinMount V3.2.0902
    "WinPcapInst" = WinPcap 4.1.1
    "WinRAR archiver" = WinRAR archiver
    "WMFDist11" = Windows Media Format 11 runtime
    "wmp11" = Windows Media Player 11
    "Wudf01000" = Microsoft User-Mode Driver Framework Feature Pack 1.0
    "Xuse 永遠のアセリア - この大地の果てで -" = Xuse 永遠のアセリア - この大地の果てで - (Remove Only)
    "東方地霊殿_is1" = 東方地霊殿 ver 1.00a
    ========== HKEY_CURRENT_USER Uninstall List ==========
    [HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall]
    "Google Chrome" = Google Chrome
    ========== Last 10 Event Log Errors ==========
    [ Application Events ]
    Error - 11/23/2010 8:40:40 PM | Computer Name = MAHISA | Source = Userenv | ID = 1041
    Description = Windows cannot query DllName registry entry for {CF7639F3-ABA2-41DB-97F2-81E2C5DBFC5D}
    and it will not be loaded. This is most likely caused by a faulty registration.
    Error - 11/23/2010 8:43:29 PM | Computer Name = MAHISA | Source = .NET Runtime Optimization Service | ID = 1103
    Description = .NET Runtime Optimization Service (clr_optimization_v2.0.50727_32)
    - Tried to start a service that wasn't the latest version of CLR Optimization service.
    Will shutdown
    Error - 11/23/2010 8:47:49 PM | Computer Name = MAHISA | Source = Userenv | ID = 1041
    Description = Windows cannot query DllName registry entry for {7B849a69-220F-451E-B3FE-2CB811AF94AE}
    Error - 11/23/2010 8:47:50 PM | Computer Name = MAHISA | Source = Userenv | ID = 1041
    Error - 11/23/2010 8:52:20 PM | Computer Name = MAHISA | Source = Userenv | ID = 1041
    Error - 11/23/2010 8:52:30 PM | Computer Name = MAHISA | Source = Userenv | ID = 1041
    Error reading Event Logs: The Event Service is not operating properly or the Event Logs are corrupt!
    < End of report >
  9. 2010/11/23
    mahisa78
    OTL logfile created on: 11/24/2010 7:57:13 AM - Run 1
    PRC - [2010/11/24 07:44:42 | 000,575,488 | ---- | M] (OldTimer Tools) -- C:\Documents and Settings\Mahisa Andara\Desktop\OTL.exe
    PRC - [2010/09/15 04:50:54 | 000,153,376 | ---- | M] (Sun Microsystems, Inc.) -- E:\Program Files\java\ire6\bin\jqs.exe
    PRC - [2010/08/02 16:10:00 | 000,135,336 | ---- | M] (Avira GmbH) -- E:\Avira\AntiVir Desktop\sched.exe
    PRC - [2010/08/02 16:09:55 | 000,281,768 | ---- | M] (Avira GmbH) -- E:\Avira\AntiVir Desktop\avgnt.exe
    PRC - [2010/08/02 16:09:55 | 000,267,944 | ---- | M] (Avira GmbH) -- E:\Avira\AntiVir Desktop\avguard.exe
    PRC - [2010/03/18 13:16:28 | 000,130,384 | ---- | M] (Microsoft Corporation) -- C:\WINDOWS\Microsoft.NET\Framework\v4.0.30319\mscorsvw.exe
    PRC - [2010/01/14 22:11:00 | 000,076,968 | ---- | M] (Avira GmbH) -- E:\Avira\AntiVir Desktop\avshadow.exe
    PRC - [2009/08/20 12:44:38 | 000,615,688 | ---- | M] (http://tortoisesvn.net) -- C:\Program Files\TortoiseSVN\bin\TSVNCache.exe
    PRC - [2009/06/05 10:57:22 | 000,262,144 | ---- | M] (Silicon Integrated Systems Corporation) -- C:\WINDOWS\system32\sistray.exe
    PRC - [2009/02/23 19:43:12 | 000,576,000 | ---- | M] (MagicISO, Inc.) -- C:\Program Files\MagicDisc\MagicDisc.exe
    PRC - [2008/04/14 07:12:19 | 001,033,728 | ---- | M] (Microsoft Corporation) -- C:\WINDOWS\explorer.exe
    PRC - [2008/02/29 18:58:43 | 001,750,016 | ---- | M] (NGO Science Center "RightMark ") -- E:\Program Files\RMClock\RMClock.exe
    PRC - [2008/02/27 02:21:54 | 000,795,936 | ---- | M] (Nuance Communications, Inc.) -- E:\Program Files\Nuance\PDF Professional 5\PdfPro5Hook.exe
    PRC - [2008/02/27 02:21:48 | 000,144,672 | ---- | M] (Nuance Communications, Inc.) -- E:\Program Files\Nuance\PDF Professional 5\PDFProFiltSrv.exe
    PRC - [2008/02/20 10:48:06 | 000,901,120 | ---- | M] (Zeon International Investment Corp. ) -- E:\Program Files\Nuance\PDF Professional 5\bin\PDFDirect.exe
    PRC - [2008/01/15 17:20:50 | 000,103,720 | ---- | M] (CyberLink) -- C:\Program Files\CyberLink\Power2Go\CLMLSvc.exe
    PRC - [2007/01/16 22:34:18 | 000,634,880 | R--- | M] (Motorola Inc.) -- C:\Program Files\Motorola\SMSERIAL\sm56hlpr.exe
    PRC - [2006/08/15 08:45:46 | 000,856,064 | R--- | M] (Sony Ericsson Mobile Communications AB) -- C:\Program Files\Sony Ericsson\Mobile2\Mobile Phone Monitor\epmworker.exe
    PRC - [2006/03/09 02:00:28 | 000,212,992 | ---- | M] (Popwire AB) -- C:\Program Files\Common Files\Teleca Shared\CapabilityManager.exe
    PRC - [2005/10/26 17:17:24 | 000,159,744 | R--- | M] (Sony Ericsson Mobile Communications AB) -- C:\Program Files\Sony Ericsson\Mobile2\Application Launcher\Application Launcher.exe
    PRC - [2005/08/10 08:54:34 | 000,385,024 | R--- | M] (Teleca Software Solutions) -- C:\Program Files\Common Files\Teleca Shared\Generic.exe
    PRC - [2005/02/16 16:15:20 | 000,081,920 | ---- | M] (InstallShield Software Corporation) -- C:\Program Files\Common Files\InstallShield\UpdateService\issch.exe
    MOD - [2010/11/24 07:44:42 | 000,575,488 | ---- | M] (OldTimer Tools) -- C:\Documents and Settings\Mahisa Andara\Desktop\OTL.exe
    SRV - File not found [Disabled | Stopped] -- C:\WINDOWS\System32\hidserv.dll -- (HidServ)
    SRV - [2010/09/15 04:50:54 | 000,153,376 | ---- | M] (Sun Microsystems, Inc.) [Auto | Running] -- E:\Program Files\java\ire6\bin\jqs.exe -- (JavaQuickStarterService)
    SRV - [2010/08/02 16:10:00 | 000,135,336 | ---- | M] (Avira GmbH) [Auto | Running] -- E:\Avira\AntiVir Desktop\sched.exe -- (AntiVirSchedulerService)
    SRV - [2010/08/02 16:09:55 | 000,267,944 | ---- | M] (Avira GmbH) [Auto | Running] -- E:\Avira\AntiVir Desktop\avguard.exe -- (AntiVirService)
    SRV - [2010/03/18 16:47:22 | 000,035,160 | ---- | M] (Microsoft Corporation) [On_Demand | Stopped] -- C:\WINDOWS\Microsoft.NET\Framework\v4.0.30319\aspnet_state.exe -- (aspnet_state)
    SRV - [2010/03/18 13:16:28 | 000,753,504 | ---- | M] (Microsoft Corporation) [On_Demand | Stopped] -- C:\WINDOWS\Microsoft.NET\Framework\v4.0.30319\WPF\WPFFontCache_v0400.exe -- (WPFFontCache_v0400)
    SRV - [2010/03/18 13:16:28 | 000,130,384 | ---- | M] (Microsoft Corporation) [Auto | Running] -- C:\WINDOWS\Microsoft.NET\Framework\v4.0.30319\mscorsvw.exe -- (clr_optimization_v4.0.30319_32)
    SRV - [2010/03/18 13:16:28 | 000,124,240 | ---- | M] (Microsoft Corporation) [Disabled | Stopped] -- C:\WINDOWS\Microsoft.NET\Framework\v4.0.30319\SMSvcHost.exe -- (NetTcpPortSharing)
    SRV - [2009/10/21 01:19:48 | 000,117,264 | ---- | M] (CACE Technologies, Inc.) [On_Demand | Stopped] -- C:\Program Files\WinPcap\rpcapd.exe -- (rpcapd) Remote Packet Capture Protocol v.0 (experimental)
    SRV - [2009/08/24 04:50:00 | 003,330,164 | ---- | M] (INCA Internet Co., Ltd.) [Disabled | Stopped] -- C:\WINDOWS\System32\GameMon.des -- (npggsvc)
    SRV - [2009/01/07 18:21:00 | 000,026,144 | ---- | M] (Microsoft Corporation) [Auto | Stopped] -- C:\WINDOWS\system32\spupdsvc.exe -- (spupdsvc)
    SRV - [2008/02/27 02:21:48 | 000,144,672 | ---- | M] (Nuance Communications, Inc.) [Auto | Running] -- E:\Program Files\Nuance\PDF Professional 5\PDFProFiltSrv.exe -- (PDFProFiltSrv)
    SRV - [2007/08/09 14:27:52 | 000,073,728 | ---- | M] (HP) [Auto | Stopped] -- C:\WINDOWS\system32\HPZipm12.exe -- (Pml Driver HPZ12)
    DRV - File not found [Kernel | On_Demand | Stopped] -- C:\DOCUME~1\MAHISA~1\LOCALS~1\Temp\catchme.sys -- (catchme)
    DRV - [2010/11/23 08:29:51 | 000,061,960 | ---- | M] (Avira GmbH) [File_System | Auto | Running] -- C:\WINDOWS\system32\drivers\avgntflt.sys -- (avgntflt)
    DRV - [2010/08/02 16:10:08 | 000,126,856 | ---- | M] (Avira GmbH) [Kernel | System | Running] -- C:\WINDOWS\system32\drivers\avipbb.sys -- (avipbb)
    DRV - [2010/06/17 15:27:22 | 000,028,520 | ---- | M] (Avira GmbH) [Kernel | System | Running] -- C:\WINDOWS\system32\drivers\ssmdrv.sys -- (ssmdrv)
    DRV - [2010/06/17 15:27:12 | 000,011,608 | ---- | M] (Avira GmbH) [Kernel | System | Running] -- E:\Avira\AntiVir Desktop\avgio.sys -- (avgio)
    DRV - [2010/05/11 01:41:30 | 000,067,656 | ---- | M] (SUPERAdBlocker.com and SUPERAntiSpyware.com) [Kernel | System | Running] -- C:\Program Files\SUPERAntiSpyware\SASKUTIL.SYS -- (SASKUTIL)
    DRV - [2010/02/18 01:25:48 | 000,012,872 | ---- | M] (SUPERAdBlocker.com and SUPERAntiSpyware.com) [Kernel | System | Running] -- C:\Program Files\SUPERAntiSpyware\sasdifsv.sys -- (SASDIFSV)
    DRV - [2009/10/21 01:19:44 | 000,050,704 | ---- | M] (CACE Technologies, Inc.) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\npf.sys -- (NPF)
    DRV - [2009/09/18 15:08:32 | 000,032,384 | ---- | M] (WinMount International Inc) [Kernel | Auto | Running] -- C:\WINDOWS\system32\drivers\WMDrive.sys -- (WMDrive)
    DRV - [2009/08/15 00:06:52 | 000,105,984 | ---- | M] (QUALCOMM Incorporated) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\qcusbser.sys -- (qcusbser)
    DRV - [2009/06/05 11:24:00 | 000,019,200 | ---- | M] (Silicon Integrated Systems Corporation) [Kernel | System | Running] -- C:\WINDOWS\system32\drivers\srvkp.sys -- (SiSkp)
    DRV - [2009/06/05 11:02:00 | 000,323,584 | ---- | M] (Silicon Integrated Systems Corporation) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\sisgrp.sys -- (SiS315)
    DRV - [2009/02/24 18:42:14 | 000,116,736 | ---- | M] (MagicISO, Inc.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\mcdbus.sys -- (mcdbus)
    DRV - [2008/12/30 11:55:20 | 000,102,656 | ---- | M] (Huawei Technologies Co., Ltd.) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\ewusbfake.sys -- (hwusbfake)
    DRV - [2008/12/13 11:26:38 | 000,102,400 | ---- | M] (Huawei Technologies Co., Ltd.) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\ewusbmdm.sys -- (hwdatacard)
    DRV - [2008/04/14 01:56:06 | 000,088,320 | ---- | M] (Microsoft Corporation) [Kernel | Auto | Running] -- C:\WINDOWS\system32\drivers\nwlnkipx.sys -- (NwlnkIpx)
    DRV - [2008/04/13 23:36:05 | 000,144,384 | ---- | M] (Windows (R) Server 2003 DDK provider) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\hdaudbus.sys -- (HDAudBus)
    DRV - [2008/03/11 18:54:14 | 004,687,872 | R--- | M] (Realtek Semiconductor Corp.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\RtkHDAud.sys -- (IntcAzAudAddService) Service for Realtek HD Audio (WDM)
    DRV - [2008/03/02 20:00:00 | 000,043,392 | R--- | M] (Silicon Integrated Systems Corp.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\SiSGbeXP.sys -- (SiSGbeXP)
    DRV - [2007/01/16 22:38:52 | 000,983,936 | R--- | M] (Motorola Inc.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\smserial.sys -- (smserial)
    DRV - [2006/09/24 20:28:46 | 000,005,248 | ---- | M] (Windows (R) 2000 DDK provider) [Kernel | Boot | Running] -- C:\WINDOWS\system32\speedfan.sys -- (speedfan)
    DRV - [2006/08/18 11:10:24 | 000,061,504 | R--- | M] (MCCI) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\K320bus.sys -- (K320bus) Sony Ericsson K320 driver (WDM)
    DRV - [2006/08/18 11:10:22 | 000,097,056 | R--- | M] (MCCI) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\K320mdm.sys -- (K320mdm)
    DRV - [2006/08/18 11:10:22 | 000,009,328 | R--- | M] (MCCI) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\K320mdfl.sys -- (K320mdfl)
    DRV - [2006/08/18 11:10:20 | 000,088,560 | R--- | M] (MCCI) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\K320mgmt.sys -- (K320mgmt) Sony Ericsson K320 USB WMC Device Management Drivers (WDM)
    DRV - [2006/08/18 11:10:18 | 000,086,368 | R--- | M] (MCCI) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\K320obex.sys -- (K320obex)
    DRV - [2005/05/25 09:39:06 | 000,004,608 | ---- | M] () [Kernel | On_Demand | Running] -- E:\Program Files\RMClock\RTCore32.sys -- (RTCore32)
    DRV - [2003/10/16 11:41:24 | 000,064,064 | ---- | M] (MCCI) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\td_cserd.sys -- (td_cserd) Galaxycom Handset Diagnostic Serial Port (WDM)
    DRV - [2003/10/16 11:40:34 | 000,082,608 | ---- | M] (MCCI) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\td_cmdm.sys -- (td_cmdm)
    DRV - [2003/10/16 11:40:32 | 000,006,032 | ---- | M] (MCCI) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\td_cmdfl.sys -- (td_cmdfl)
    DRV - [2003/10/16 11:39:28 | 000,051,040 | ---- | M] (MCCI) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\td_cbus.sys -- (td_cbus) Galaxycom USB Composite Device driver (WDM)
    DRV - [2001/08/23 18:00:00 | 000,063,232 | ---- | M] (Microsoft Corporation) [Kernel | Auto | Running] -- C:\WINDOWS\system32\drivers\nwlnknb.sys -- (NwlnkNb)
    DRV - [2001/08/23 18:00:00 | 000,055,936 | ---- | M] (Microsoft Corporation) [Kernel | Auto | Running] -- C:\WINDOWS\system32\drivers\nwlnkspx.sys -- (NwlnkSpx)
    DRV - [2001/08/23 18:00:00 | 000,012,160 | ---- | M] (Microsoft Corporation) [Kernel | System | Running] -- C:\WINDOWS\system32\drivers\fsvga.sys -- (FsVga)
    DRV - [1996/04/04 02:33:26 | 000,005,248 | ---- | M] () [Kernel | Boot | Running] -- C:\WINDOWS\system32\giveio.sys -- (giveio)
    IE - HKLM\SOFTWARE\Microsoft\Internet Explorer\Main,Local Page = %SystemRoot%\system32\blank.htm
    IE - HKCU\Software\Microsoft\Windows\CurrentVersion\Internet Settings: "ProxyEnable" = 0
    ========== FireFox ==========
    FF - prefs.js..extensions.enabledItems: {19503e42-ca3c-4c27-b1e2-9cdb2170ee34}:1.2.4
    FF - prefs.js..extensions.enabledItems: yyginstantplay@yoyogames.com:1.1.0.20
    FF - prefs.js..extensions.enabledItems: fdm_ffext@freedownloadmanager.org:1.3.4
    FF - prefs.js..extensions.enabledItems: {CAFEEFAC-0016-0000-0020-ABCDEFFEDCBA}:6.0.20
    FF - prefs.js..extensions.enabledItems: {CAFEEFAC-0016-0000-0021-ABCDEFFEDCBA}:6.0.21
    FF - prefs.js..extensions.enabledItems: jqs@sun.com:1.0
    FF - prefs.js..extensions.enabledItems: {CAFEEFAC-0016-0000-0022-ABCDEFFEDCBA}:6.0.22
    FF - prefs.js..network.proxy.backup.ftp: " "
    FF - prefs.js..network.proxy.backup.ftp_port: 0
    FF - prefs.js..network.proxy.backup.gopher: " "
    FF - prefs.js..network.proxy.backup.gopher_port: 0
    FF - prefs.js..network.proxy.backup.socks: " "
    FF - prefs.js..network.proxy.backup.socks_port: 0
    FF - prefs.js..network.proxy.backup.ssl: " "
    FF - prefs.js..network.proxy.backup.ssl_port: 0
    FF - prefs.js..network.proxy.ftp: "PROXIES.TELKOM.NET.ID "
    FF - prefs.js..network.proxy.ftp_port: 8080
    FF - prefs.js..network.proxy.gopher: "PROXIES.TELKOM.NET.ID "
    FF - prefs.js..network.proxy.gopher_port: 8080
    FF - prefs.js..network.proxy.http: "PROXIES.TELKOM.NET.ID "
    FF - prefs.js..network.proxy.http_port: 8080
    FF - prefs.js..network.proxy.share_proxy_settings: true
    FF - prefs.js..network.proxy.socks: "PROXIES.TELKOM.NET.ID "
    FF - prefs.js..network.proxy.socks_port: 8080
    FF - prefs.js..network.proxy.ssl: "PROXIES.TELKOM.NET.ID "
    FF - prefs.js..network.proxy.ssl_port: 8080
    FF - prefs.js..network.proxy.type: 0
    FF - HKLM\software\mozilla\Firefox\Extensions\\jqs@sun.com: E:\Program Files\java\ire6\lib\deploy\jqs\ff [2010/05/07 12:34:06 | 000,000,000 | ---D | M]
    FF - HKLM\software\mozilla\Mozilla Firefox 3.6.12\extensions\\Components: C:\Program Files\Mozilla Firefox\components [2010/11/12 05:13:20 | 000,000,000 | ---D | M]
    FF - HKLM\software\mozilla\Mozilla Firefox 3.6.12\extensions\\Plugins: C:\Program Files\Mozilla Firefox\plugins [2010/11/21 19:37:57 | 000,000,000 | ---D | M]
    [2009/08/24 21:20:02 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Mahisa Andara\Application Data\Mozilla\Extensions
    [2010/11/23 17:50:06 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Mahisa Andara\Application Data\Mozilla\Firefox\Profiles\5o9qsvby.default\extensions
    [2010/11/08 06:14:38 | 000,000,000 | ---D | M] (FlashGot) -- C:\Documents and Settings\Mahisa Andara\Application Data\Mozilla\Firefox\Profiles\5o9qsvby.default\extensions\{19503e42-ca3c-4c27-b1e2-9cdb2170ee34}
    [2010/04/29 20:55:34 | 000,000,000 | ---D | M] (Microsoft .NET Framework Assistant) -- C:\Documents and Settings\Mahisa Andara\Application Data\Mozilla\Firefox\Profiles\5o9qsvby.default\extensions\{20a82645-c095-46ed-80e3-08825760534b}
    [2009/08/27 15:33:54 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Mahisa Andara\Application Data\Mozilla\Firefox\Profiles\5o9qsvby.default\extensions\yyginstantplay@yoyogames.com
    [2010/11/14 19:25:37 | 000,000,000 | ---D | M] -- C:\Program Files\Mozilla Firefox\extensions
    [2010/05/07 12:34:18 | 000,000,000 | ---D | M] (Java Console) -- C:\Program Files\Mozilla Firefox\extensions\{CAFEEFAC-0016-0000-0020-ABCDEFFEDCBA}
    [2010/08/04 20:00:01 | 000,000,000 | ---D | M] (Java Console) -- C:\Program Files\Mozilla Firefox\extensions\{CAFEEFAC-0016-0000-0021-ABCDEFFEDCBA}
    [2010/10/30 19:37:57 | 000,000,000 | ---D | M] (Java Console) -- C:\Program Files\Mozilla Firefox\extensions\{CAFEEFAC-0016-0000-0022-ABCDEFFEDCBA}
    [2010/09/15 04:50:38 | 000,472,808 | ---- | M] (Sun Microsystems, Inc.) -- C:\Program Files\Mozilla Firefox\plugins\npdeployJava1.dll
    [2010/11/12 05:13:14 | 000,001,160 | ---- | M] () -- C:\Program Files\Mozilla Firefox\searchplugins\wikipedia-id.xml
    [2010/11/12 05:13:14 | 000,000,956 | ---- | M] () -- C:\Program Files\Mozilla Firefox\searchplugins\yahoo-id.xml
    O1 HOSTS File: ([2010/11/23 13:25:10 | 000,000,027 | ---- | M]) - C:\WINDOWS\system32\drivers\etc\hosts
    O2 - BHO: (ATLAS Toolbar) - {3C6301ED-0F78-4AF2-8150-D9C052361A8E} - C:\Program Files\ATLAS V14\ATLIECP.DLL (FUJITSU LIMITED)
    O2 - BHO: (Google Toolbar Notifier BHO) - {AF69DE43-7D58-4638-B6FA-CE66B5AD205D} - C:\Program Files\Google\GoogleToolbarNotifier\5.2.4204.1700\swg.dll (Google Inc.)
    O2 - BHO: (FDMIECookiesBHO Class) - {CC59E0F9-7E43-44FA-9FAA-8377850BF205} - C:\Program Files\Free Download Manager\iefdm2.dll ()
    O2 - BHO: (ZeonIEEventHelper Class) - {DA986D7D-CCAF-47B2-84FE-BFA1549BEBF9} - E:\Program Files\Nuance\PDF Professional 5\bin\ZeonIEFavClient.dll (Zeon Corporation)
    O2 - BHO: (Java(tm) Plug-In 2 SSV Helper) - {DBC80044-A445-435b-BC74-9C25C1C588A9} - E:\Program Files\java\ire6\bin\jp2ssv.dll (Sun Microsystems, Inc.)
    O2 - BHO: (JQSIEStartDetectorImpl Class) - {E7E6F031-17CE-4C07-BC86-EABFE594F69C} - E:\Program Files\java\ire6\lib\deploy\jqs\ie\jqs_plugin.dll (Sun Microsystems, Inc.)
    O3 - HKLM\..\Toolbar: (ATLAS Toolbar) - {3C6301ED-0F78-4AF2-8150-D9C052361A8E} - C:\Program Files\ATLAS V14\ATLIECP.DLL (FUJITSU LIMITED)
    O3 - HKLM\..\Toolbar: (Nuance PDF) - {E3286BF1-E654-42FF-B4A6-5E111731DF6B} - E:\Program Files\Nuance\PDF Professional 5\bin\ZeonIEFavClient.dll (Zeon Corporation)
    O4 - HKLM..\Run: [avgnt] E:\Avira\AntiVir Desktop\avgnt.exe (Avira GmbH)
    O4 - HKLM..\Run: [BluetoothAuthenticationAgent] C:\WINDOWS\System32\bthprops.cpl (Microsoft Corporation)
    O4 - HKLM..\Run: [CLMLServer] C:\Program Files\CyberLink\Power2Go\CLMLSvc.exe (CyberLink)
    O4 - HKLM..\Run: [IMJPMIG8.1] C:\WINDOWS\IME\imjp8_1\IMJPMIG.EXE (Microsoft Corporation)
    O4 - HKLM..\Run: [ISUSPM Startup] C:\Program Files\Common Files\InstallShield\UpdateService\ISUSPM.exe (InstallShield Software Corporation)
    O4 - HKLM..\Run: [ISUSScheduler] C:\Program Files\Common Files\InstallShield\UpdateService\issch.exe (InstallShield Software Corporation)
    O4 - HKLM..\Run: [LanguageShortcut] C:\Program Files\CyberLink\PowerDVD\Language\Language.exe ()
    O4 - HKLM..\Run: [MSPY2002] C:\WINDOWS\System32\IME\PINTLGNT\ImScInst.exe ()
    O4 - HKLM..\Run: [Nuance PDF Professional 5-reminder] E:\Program Files\Nuance\PDF Professional 5\Ereg\Ereg.exe (Nuance Communications, Inc.)
    O4 - HKLM..\Run: [P2Go_Menu] C:\Program Files\CyberLink\Power2Go\MUITransfer\MUIStartMenu.exe (CyberLink Corp.)
    O4 - HKLM..\Run: [PDF5 Registry Controller] E:\Program Files\Nuance\PDF Professional 5\RegistryController.exe (Nuance Communications, Inc.)
    O4 - HKLM..\Run: [PDFHook] E:\Program Files\Nuance\PDF Professional 5\PdfPro5Hook.exe (Nuance Communications, Inc.)
    O4 - HKLM..\Run: [PHIME2002A] C:\WINDOWS\System32\IME\TINTLGNT\TINTSETP.EXE (Microsoft Corporation)
    O4 - HKLM..\Run: [PHIME2002ASync] C:\WINDOWS\System32\IME\TINTLGNT\TINTSETP.EXE (Microsoft Corporation)
    O4 - HKLM..\Run: [SiSPower] C:\WINDOWS\System32\SiSPower.dll (Silicon Integrated Systems Corporation)
    O4 - HKLM..\Run: [SMSERIAL] C:\Program Files\Motorola\SMSERIAL\sm56hlpr.exe (Motorola Inc.)
    O4 - HKLM..\Run: [Sony Ericsson PC Suite] C:\Program Files\Sony Ericsson\Mobile2\Application Launcher\Application Launcher.exe (Sony Ericsson Mobile Communications AB)
    O4 - HKLM..\Run: [SSBkgdUpdate] C:\Program Files\Common Files\Scansoft Shared\SSBkgdUpdate\SSBkgdupdate.exe (Nuance Communications, Inc.)
    O4 - HKCU..\Run: [Power2GoExpress] File not found
    O4 - HKCU..\Run: [RMClock] E:\Program Files\RMClock\RMClockLauncher.exe (NGO Science Center "RightMark ")
    O4 - HKCU..\Run: [swg] C:\Program Files\Google\GoogleToolbarNotifier\GoogleToolbarNotifier.exe (Google Inc.)
    O4 - Startup: C:\Documents and Settings\All Users\Start Menu\Programs\Startup\Microsoft Office.lnk = C:\Program Files\Microsoft Office\Office\OSA9.EXE (Microsoft Corporation)
    O4 - Startup: C:\Documents and Settings\All Users\Start Menu\Programs\Startup\Utility Tray.lnk = C:\WINDOWS\system32\sistray.exe (Silicon Integrated Systems Corporation)
    O4 - Startup: C:\Documents and Settings\Mahisa Andara\Start Menu\Programs\Startup\MagicDisc.lnk = C:\Program Files\MagicDisc\MagicDisc.exe (MagicISO, Inc.)
    O6 - HKLM\Software\Policies\Microsoft\Internet Explorer\Restrictions present
    O7 - HKCU\Software\Policies\Microsoft\Internet Explorer\Control Panel present
    O7 - HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: NoDriveTypeAutoRun = 323
    O7 - HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: NoDriveAutoRun = 67108863
    O7 - HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: NoDrives = 0
    O8 - Extra context menu item: &Translate with ATLAS - C:\Program Files\ATLAS V14\atlscript.html ()
    O8 - Extra context menu item: Append the content of the link to existing PDF file - E:\Program Files\Nuance\PDF Professional 5\bin\ZeonIEFavClient.dll (Zeon Corporation)
    O8 - Extra context menu item: Append the content of the selected links to existing PDF file - E:\Program Files\Nuance\PDF Professional 5\bin\ZeonIEFavClient.dll (Zeon Corporation)
    O8 - Extra context menu item: Append to existing PDF file - E:\Program Files\Nuance\PDF Professional 5\bin\ZeonIEFavClient.dll (Zeon Corporation)
    O8 - Extra context menu item: ATLAS Translation &Editor - C:\Program Files\ATLAS V14\AtlscriptEdit.html ()
    O8 - Extra context menu item: Create PDF file - E:\Program Files\Nuance\PDF Professional 5\bin\ZeonIEFavClient.dll (Zeon Corporation)
    O8 - Extra context menu item: Create PDF file from the content of the link - E:\Program Files\Nuance\PDF Professional 5\bin\ZeonIEFavClient.dll (Zeon Corporation)
    O8 - Extra context menu item: Create PDF files from the selected links - E:\Program Files\Nuance\PDF Professional 5\bin\ZeonIEFavClient.dll (Zeon Corporation)
    O8 - Extra context menu item: Download all by FlashGet3 - C:\Documents and Settings\Mahisa Andara\Application Data\FlashGetBHO\GetAllUrl.htm ()
    O8 - Extra context menu item: Download all with Free Download Manager - C:\Program Files\Free Download Manager\dlall.htm ()
    O8 - Extra context menu item: Download by FlashGet3 - C:\Documents and Settings\Mahisa Andara\Application Data\FlashGetBHO\GetUrl.htm ()
    O8 - Extra context menu item: Download selected with Free Download Manager - C:\Program Files\Free Download Manager\dlselected.htm ()
    O8 - Extra context menu item: Download video with Free Download Manager - C:\Program Files\Free Download Manager\dlfvideo.htm ()
    O8 - Extra context menu item: Download with Free Download Manager - C:\Program Files\Free Download Manager\dllink.htm ()
    O8 - Extra context menu item: Open with Nuance PDF Converter 5.0 - E:\Program Files\Nuance\PDF Professional 5\cnvres_eng.dll ()
    O8 - Extra context menu item: ハケモテソ・オ3マツヤリ - C:\Documents and Settings\Mahisa Andara\Application Data\FlashGetBHO\GetUrl.htm ()
    O8 - Extra context menu item: ハケモテソ・オ3マツヤリネォイソチエスモ - C:\Documents and Settings\Mahisa Andara\Application Data\FlashGetBHO\GetAllUrl.htm ()
    O9 - Extra Button: ATLAS Translation - {B7707A72-4355-11D4-82BD-00000EBBEF8D} - C:\Program Files\ATLAS V14\atlscript.html ()
    O10 - NameSpace_Catalog5\Catalog_Entries\000000000004 [] - C:\WINDOWS\system32\nwprovau.dll (Microsoft Corporation)
    O15 - HKCU\..Trusted Domains: kuaiche.com ([software] http in Trusted sites)
    O16 - DPF: {17492023-C23A-453E-A040-C7C580BBF700} http://download.microsoft.com/downl...-4117-8430-A67417AA88CD/LegitCheckControl.cab (Windows Genuine Advantage Validation Tool)
    O16 - DPF: {8AD9C840-044E-11D1-B3E9-00805F499D93} http://java.sun.com/update/1.6.0/jinstall-1_6_0_22-windows-i586.cab (Java Plug-in 1.6.0_22)
    O16 - DPF: {CAFEEFAC-0016-0000-0022-ABCDEFFEDCBA} http://java.sun.com/update/1.6.0/jinstall-1_6_0_22-windows-i586.cab (Java Plug-in 1.6.0_22)
    O16 - DPF: {CAFEEFAC-FFFF-FFFF-FFFF-ABCDEFFEDCBA} http://java.sun.com/update/1.6.0/jinstall-1_6_0_22-windows-i586.cab (Java Plug-in 1.6.0_22)
    O17 - HKLM\System\CCS\Services\Tcpip\Parameters: DhcpNameServer = 192.168.1.1
    O20 - HKLM Winlogon: Shell - (Explorer.exe) - C:\WINDOWS\explorer.exe (Microsoft Corporation)
    O20 - Winlogon\Notify\!SASWinLogon: DllName - C:\Program Files\SUPERAntiSpyware\SASWINLO.DLL - C:\Program Files\SUPERAntiSpyware\SASWINLO.DLL (SUPERAntiSpyware.com)
    O24 - Desktop WallPaper: C:\Documents and Settings\Mahisa Andara\Local Settings\Application Data\Microsoft\Wallpaper1.bmp
    O24 - Desktop BackupWallPaper: C:\Documents and Settings\Mahisa Andara\Local Settings\Application Data\Microsoft\Wallpaper1.bmp
    O27 - HKLM IFEO\taskmgr.exe: Debugger - "E:\PROCESSEXPLORER\PROCEXP.EXE" (Sysinternals - www.sysinternals.com)
    O28 - HKLM ShellExecuteHooks: {5AE067D3-9AFB-48E0-853A-EBB7F4A000DA} - C:\Program Files\SUPERAntiSpyware\SASSEH.DLL (SuperAdBlocker.com)
    O32 - HKLM CDRom: AutoRun - 1
    O32 - AutoRun File - [2009/05/09 16:32:01 | 000,000,000 | ---- | M] () - C:\AUTOEXEC.BAT -- [ NTFS ]
    O37 - HKLM\...com [@ = ComFile] -- "%1" %*
    NetSvcs: 6to4 - File not found
    NetSvcs: HidServ - C:\WINDOWS\System32\hidserv.dll File not found
    NetSvcs: Ias - File not found
    NetSvcs: Iprip - File not found
    NetSvcs: NWCWorkstation - File not found
    NetSvcs: Nwsapagent - File not found
    NetSvcs: WmdmPmSp - File not found
    Drivers32: msacm.iac2 - C:\WINDOWS\system32\iac25_32.ax (Intel Corporation)
    Drivers32: msacm.l3acm - C:\WINDOWS\system32\l3codeca.acm (Fraunhofer Institut Integrierte Schaltungen IIS)
    Drivers32: msacm.l3codecp - C:\WINDOWS\System32\l3codecp.acm (Fraunhofer Institut Integrierte Schaltungen IIS)
    Drivers32: msacm.sl_anet - C:\WINDOWS\System32\sl_anet.acm (Sipro Lab Telecom Inc.)
    Drivers32: msacm.trspch - C:\WINDOWS\System32\tssoft32.acm (DSP GROUP, INC.)
    Drivers32: MSVideo8 - C:\WINDOWS\System32\vfwwdm32.dll (Microsoft Corporation)
    Drivers32: vidc.cvid - C:\WINDOWS\System32\iccvid.dll (Radius Inc.)
    Drivers32: vidc.ffds - C:\Program Files\Combined Community Codec Pack\Filters\FFDShow\ff_vfw.dll ()
    Drivers32: vidc.iv31 - C:\WINDOWS\System32\ir32_32.dll ()
    Drivers32: vidc.iv32 - C:\WINDOWS\System32\ir32_32.dll ()
    Drivers32: vidc.iv41 - C:\WINDOWS\System32\ir41_32.ax (Intel Corporation)
    Drivers32: vidc.iv50 - C:\WINDOWS\System32\ir50_32.dll (Intel Corporation)
    CREATERESTOREPOINT
    Restore point Set: OTL Restore Point (56590081070202880)
    ========== Files/Folders - Created Within 30 Days ==========
    [2010/11/24 07:56:00 | 000,000,000 | ---D | C] -- C:\WINDOWS\LastGood
    [2010/11/24 07:44:19 | 000,575,488 | ---- | C] (OldTimer Tools) -- C:\Documents and Settings\Mahisa Andara\Desktop\OTL.exe
    [2010/11/24 05:19:37 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Mahisa Andara\Local Settings\Application Data\Scansoft
    [2010/11/23 18:25:18 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Mahisa Andara\Application Data\ScanSoft
    [2010/11/23 18:24:04 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Mahisa Andara\Application Data\Zeon
    [2010/11/23 18:21:14 | 000,000,000 | ---D | C] -- C:\Documents and Settings\All Users\Application Data\InstallShield
    [2010/11/23 18:21:04 | 000,000,000 | -H-D | C] -- C:\WINDOWS\System32\GroupPolicy
    [2010/11/23 18:20:59 | 000,000,000 | ---D | C] -- C:\Documents and Settings\All Users\Application Data\Nuance
    [2010/11/23 18:20:58 | 000,000,000 | ---D | C] -- C:\Documents and Settings\All Users\Application Data\ScanSoft
    [2010/11/23 18:20:26 | 000,000,000 | ---D | C] -- C:\Program Files\Common Files\ScanSoft Shared
    [2010/11/23 18:20:25 | 000,000,000 | ---D | C] -- C:\Documents and Settings\All Users\Application Data\zeon
    [2010/11/23 17:50:05 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Mahisa Andara\Application Data\Free Download Manager
    [2010/11/23 17:49:58 | 000,000,000 | ---D | C] -- C:\Documents and Settings\All Users\Application Data\FreeDownloadManager.ORG
    [2010/11/23 17:49:54 | 000,000,000 | ---D | C] -- C:\Program Files\Free Download Manager
    [2010/11/23 10:09:24 | 000,000,000 | RHSD | C] -- C:\cmdcons
    [2010/11/23 10:06:28 | 000,212,480 | ---- | C] (SteelWerX) -- C:\WINDOWS\SWXCACLS.exe
    [2010/11/23 10:06:28 | 000,161,792 | ---- | C] (SteelWerX) -- C:\WINDOWS\SWREG.exe
    [2010/11/23 10:06:28 | 000,136,704 | ---- | C] (SteelWerX) -- C:\WINDOWS\SWSC.exe
    [2010/11/23 10:06:28 | 000,031,232 | ---- | C] (NirSoft) -- C:\WINDOWS\NIRCMD.exe
    [2010/11/23 10:06:19 | 000,000,000 | ---D | C] -- C:\WINDOWS\ERDNT
    [2010/11/23 10:06:03 | 000,000,000 | ---D | C] -- C:\Qoobox
    [2010/11/23 08:08:04 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Mahisa Andara\Application Data\Avira
    [2010/11/23 07:50:51 | 000,028,520 | ---- | C] (Avira GmbH) -- C:\WINDOWS\System32\drivers\ssmdrv.sys
    [2010/11/23 07:50:47 | 000,126,856 | ---- | C] (Avira GmbH) -- C:\WINDOWS\System32\drivers\avipbb.sys
    [2010/11/23 07:50:47 | 000,022,360 | ---- | C] (Avira GmbH) -- C:\WINDOWS\System32\drivers\avgntmgr.sys
    [2010/11/23 07:50:46 | 000,061,960 | ---- | C] (Avira GmbH) -- C:\WINDOWS\System32\drivers\avgntflt.sys
    [2010/11/23 07:50:46 | 000,045,416 | ---- | C] (Avira GmbH) -- C:\WINDOWS\System32\drivers\avgntdd.sys
    [2010/11/23 07:50:45 | 000,000,000 | ---D | C] -- C:\Documents and Settings\All Users\Application Data\Avira
    [2010/11/22 05:43:47 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Mahisa Andara\Application Data\SUPERAntiSpyware.com
    [2010/11/22 05:43:47 | 000,000,000 | ---D | C] -- C:\Documents and Settings\All Users\Application Data\SUPERAntiSpyware.com
    [2010/11/22 05:43:40 | 000,000,000 | ---D | C] -- C:\Program Files\SUPERAntiSpyware
    [2010/11/15 18:04:54 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Mahisa Andara\Local Settings\Application Data\Oblivion
    [2010/11/15 17:48:37 | 000,000,000 | ---D | C] -- C:\summerwars
    [2010/11/02 17:49:20 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Mahisa Andara\My Documents\inter
    [2010/10/31 21:40:06 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Mahisa Andara\My Documents\Minggu 4
    [2010/10/31 06:58:10 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Mahisa Andara\Local Settings\Application Data\Microsoft_Corporation
    [2010/10/30 13:27:59 | 000,094,208 | ---- | C] (Blizzard Entertainment) -- C:\WINDOWS\DIIUnin.exe
    [1 C:\Documents and Settings\Mahisa Andara\My Documents\*.tmp files -> C:\Documents and Settings\Mahisa Andara\My Documents\*.tmp -> ]
    ========== Files - Modified Within 30 Days ==========
    [2010/11/24 07:56:42 | 000,493,388 | ---- | M] () -- C:\WINDOWS\System32\perfh009.dat
    [2010/11/24 07:56:42 | 000,083,932 | ---- | M] () -- C:\WINDOWS\System32\perfc009.dat
    [2010/11/24 07:52:32 | 000,000,868 | ---- | M] () -- C:\WINDOWS\tasks\Google Software Updater.job
    [2010/11/24 07:52:31 | 000,000,896 | ---- | M] () -- C:\WINDOWS\tasks\GoogleUpdateTaskMachineCore.job
    [2010/11/24 07:52:10 | 000,002,048 | --S- | M] () -- C:\WINDOWS\bootstat.dat
    [2010/11/24 07:46:05 | 000,001,393 | ---- | M] () -- C:\WINDOWS\imsins.BAK
    [2010/11/24 07:46:02 | 000,000,900 | ---- | M] () -- C:\WINDOWS\tasks\GoogleUpdateTaskMachineUA.job
    [2010/11/24 07:40:23 | 000,160,344 | ---- | M] () -- C:\WINDOWS\System32\FNTCACHE.DAT
    [2010/11/24 07:34:34 | 000,512,000 | ---- | M] () -- C:\Documents and Settings\Mahisa Andara\My Documents\Avalon Code Walkthrough v1.doc
    [2010/11/24 07:02:01 | 000,001,010 | ---- | M] () -- C:\WINDOWS\tasks\GoogleUpdateTaskUserS-1-5-21-789336058-606747145-839522115-1003UA.job
    [2010/11/23 19:55:00 | 000,075,264 | ---- | M] () -- C:\Documents and Settings\Mahisa Andara\My Documents\Paper SAPI.doc
    [2010/11/23 18:25:14 | 001,496,552 | ---- | M] () -- C:\Documents and Settings\Mahisa Andara\My Documents\SE-79-PJ-2010.doc
    [2010/11/23 18:21:12 | 000,000,358 | RHS- | M] () -- C:\Documents and Settings\All Users\ntuser.pol
    [2010/11/23 17:50:03 | 000,000,682 | ---- | M] () -- C:\Documents and Settings\Mahisa Andara\Application Data\Microsoft\Internet Explorer\Quick Launch\Free Download Manager.lnk
    [2010/11/23 17:50:02 | 000,000,664 | ---- | M] () -- C:\Documents and Settings\Mahisa Andara\Desktop\Free Download Manager.lnk
    [2010/11/23 15:23:45 | 001,355,817 | ---- | M] () -- C:\Documents and Settings\Mahisa Andara\My Documents\SE-79-PJ-2010.pdf
    [2010/11/23 13:25:10 | 000,000,027 | ---- | M] () -- C:\WINDOWS\System32\drivers\etc\hosts
    [2010/11/23 13:16:15 | 003,914,095 | R--- | M] () -- C:\Documents and Settings\Mahisa Andara\Desktop\ComboFix.exe
    [2010/11/23 13:02:00 | 000,000,958 | ---- | M] () -- C:\WINDOWS\tasks\GoogleUpdateTaskUserS-1-5-21-789336058-606747145-839522115-1003Core.job
    [2010/11/23 10:09:28 | 000,000,327 | RHS- | M] () -- C:\boot.ini
    [2010/11/23 08:29:51 | 000,061,960 | ---- | M] (Avira GmbH) -- C:\WINDOWS\System32\drivers\avgntflt.sys
    [2010/11/23 07:51:08 | 000,000,653 | ---- | M] () -- C:\Documents and Settings\All Users\Desktop\Avira AntiVir Control Center.lnk
    [2010/11/23 05:27:01 | 003,072,054 | ---- | M] () -- C:\Documents and Settings\Mahisa Andara\My Documents\virus.bmp
    [2010/11/22 20:19:18 | 000,145,920 | ---- | M] () -- C:\Documents and Settings\Mahisa Andara\My Documents\I think I have a virus in my laptop.doc
    [2010/11/22 19:58:58 | 000,630,272 | ---- | M] () -- C:\Documents and Settings\Mahisa Andara\Desktop\dds.pif
    [2010/11/22 19:52:09 | 000,080,384 | ---- | M] () -- C:\Documents and Settings\Mahisa Andara\Desktop\MBRCheck.exe
    [2010/11/22 05:43:43 | 000,001,678 | ---- | M] () -- C:\Documents and Settings\All Users\Desktop\SUPERAntiSpyware Free Edition.lnk
    [2010/11/21 23:20:42 | 000,000,815 | ---- | M] () -- C:\Documents and Settings\Mahisa Andara\Application Data\Microsoft\Internet Explorer\Quick Launch\Launch Internet Explorer Browser.lnk
    [2010/11/21 21:58:08 | 000,000,211 | ---- | M] () -- C:\Boot.bak
    [2010/11/21 19:37:58 | 000,001,729 | ---- | M] () -- C:\Documents and Settings\All Users\Desktop\Adobe Reader 9.lnk
    [2010/11/21 19:23:13 | 000,002,206 | ---- | M] () -- C:\WINDOWS\System32\wpa.dbl
    [2010/11/18 12:15:51 | 000,023,552 | ---- | M] () -- C:\Documents and Settings\Mahisa Andara\My Documents\Tugas B.Ing Mahisa Andara 20.doc
    [2010/11/15 19:47:14 | 000,002,356 | ---- | M] () -- C:\Documents and Settings\Mahisa Andara\Desktop\Google Chrome.lnk
    [2010/11/15 07:42:00 | 000,000,284 | ---- | M] () -- C:\WINDOWS\tasks\AppleSoftwareUpdate.job
    [2010/11/14 20:29:44 | 000,014,848 | ---- | M] () -- C:\Documents and Settings\Mahisa Andara\Local Settings\Application Data\DCBC2A71-70D8-4DAN-EHR8-E0D61DEA3FDF.ini
    [2010/11/12 16:17:53 | 002,216,960 | ---- | M] () -- C:\Documents and Settings\Mahisa Andara\My Documents\Rune Factory 2.doc
    [2010/11/10 20:16:32 | 000,000,630 | ---- | M] () -- C:\Documents and Settings\Mahisa Andara\Desktop\RightMark CPU Clock Utility.lnk
    [2010/11/10 19:41:08 | 000,000,045 | ---- | M] () -- C:\WINDOWS\System32\initdebug.nfo
    [2010/11/10 07:02:55 | 000,000,469 | ---- | M] () -- C:\Documents and Settings\Mahisa Andara\Desktop\Shortcut to NO$WTT.exe.lnk
    [2010/11/08 01:20:24 | 000,089,088 | ---- | M] () -- C:\WINDOWS\MBR.exe
    [2010/11/06 08:11:36 | 001,249,792 | ---- | M] () -- C:\Documents and Settings\Mahisa Andara\My Documents\Paper Mario.doc
    [2010/11/05 21:16:14 | 011,205,733 | ---- | M] () -- C:\Documents and Settings\Mahisa Andara\My Documents\Nogizaka_Haruka_no_Himitsu_Purezza.zip
    [2010/11/04 13:59:17 | 000,021,840 | ---- | M] () -- C:\WINDOWS\System32\SIntfNT.dll
    [2010/11/04 13:59:17 | 000,017,212 | ---- | M] () -- C:\WINDOWS\System32\SIntf32.dll
    [2010/11/04 13:59:17 | 000,012,067 | ---- | M] () -- C:\WINDOWS\System32\SIntf16.dll
    [2010/11/01 17:05:45 | 000,000,610 | ---- | M] () -- C:\Documents and Settings\Mahisa Andara\Application Data\Microsoft\Internet Explorer\Quick Launch\Opera.lnk
    [2010/11/01 17:05:45 | 000,000,592 | ---- | M] () -- C:\Documents and Settings\All Users\Desktop\Opera.lnk
    [2010/10/30 14:29:06 | 000,014,168 | ---- | M] () -- C:\WINDOWS\DIIUnin.dat
    [2010/10/30 13:27:59 | 000,094,208 | ---- | M] (Blizzard Entertainment) -- C:\WINDOWS\DIIUnin.exe
    [2010/10/30 13:27:59 | 000,002,829 | ---- | M] () -- C:\WINDOWS\DIIUnin.pif
    [2010/10/28 11:02:24 | 000,092,774 | ---- | M] () -- C:\Documents and Settings\Mahisa Andara\My Documents\SAPI 2J kel 1 sesi 3.pptx
    [2010/10/28 11:01:52 | 000,069,071 | ---- | M] () -- C:\Documents and Settings\Mahisa Andara\My Documents\SAPI 2J kel 1 sesi 2.pptx
    [2010/10/26 22:08:49 | 000,214,016 | ---- | M] () -- C:\Documents and Settings\Mahisa Andara\My Documents\Paper Mario Badges.doc
    [2010/10/26 21:21:52 | 000,045,177 | ---- | M] () -- C:\Documents and Settings\Mahisa Andara\My Documents\kanwil.png
    [2010/10/25 19:59:12 | 001,176,576 | ---- | M] () -- C:\Documents and Settings\Mahisa Andara\My Documents\Suikoden 4.doc
    [2010/10/25 15:15:30 | 000,020,480 | ---- | M] () -- C:\Documents and Settings\Mahisa Andara\My Documents\Dapat Dibandingkan.doc
    [2010/10/25 15:07:07 | 000,001,682 | -HS- | M] () -- C:\WINDOWS\System32\KGyGaAvL.sys
    [2010/10/25 14:20:28 | 000,027,648 | ---- | M] () -- C:\Documents and Settings\Mahisa Andara\My Documents\RELEVANCE.doc
    [2010/10/25 14:20:04 | 000,029,696 | ---- | M] () -- C:\Documents and Settings\Mahisa Andara\My Documents\inter_understandability.doc
    [2010/10/25 14:19:42 | 000,026,624 | ---- | M] () -- C:\Documents and Settings\Mahisa Andara\My Documents\financial report reliability.doc
    [2010/11/23 18:25:14 | 001,496,552 | ---- | C] () -- C:\Documents and Settings\Mahisa Andara\My Documents\SE-79-PJ-2010.doc
    [2010/11/23 18:21:06 | 000,000,358 | RHS- | C] () -- C:\Documents and Settings\All Users\ntuser.pol
    [2010/11/23 17:50:02 | 000,000,682 | ---- | C] () -- C:\Documents and Settings\Mahisa Andara\Application Data\Microsoft\Internet Explorer\Quick Launch\Free Download Manager.lnk
    [2010/11/23 17:50:02 | 000,000,664 | ---- | C] () -- C:\Documents and Settings\Mahisa Andara\Desktop\Free Download Manager.lnk
    [2010/11/23 15:23:45 | 001,355,817 | ---- | C] () -- C:\Documents and Settings\Mahisa Andara\My Documents\SE-79-PJ-2010.pdf
    [2010/11/23 14:18:04 | 000,075,264 | ---- | C] () -- C:\Documents and Settings\Mahisa Andara\My Documents\Paper SAPI.doc
    [2010/11/23 10:09:28 | 000,000,211 | ---- | C] () -- C:\Boot.bak
    [2010/11/23 10:09:26 | 000,260,272 | RHS- | C] () -- C:\cmldr
    [2010/11/23 10:06:28 | 000,256,512 | ---- | C] () -- C:\WINDOWS\PEV.exe
    [2010/11/23 10:06:28 | 000,098,816 | ---- | C] () -- C:\WINDOWS\sed.exe
    [2010/11/23 10:06:28 | 000,089,088 | ---- | C] () -- C:\WINDOWS\MBR.exe
    [2010/11/23 10:06:28 | 000,080,412 | ---- | C] () -- C:\WINDOWS\grep.exe
    [2010/11/23 10:06:28 | 000,068,096 | ---- | C] () -- C:\WINDOWS\zip.exe
    [2010/11/23 09:57:33 | 003,914,095 | R--- | C] () -- C:\Documents and Settings\Mahisa Andara\Desktop\ComboFix.exe
    [2010/11/23 07:51:08 | 000,000,653 | ---- | C] () -- C:\Documents and Settings\All Users\Desktop\Avira AntiVir Control Center.lnk
    [2010/11/23 05:27:01 | 003,072,054 | ---- | C] () -- C:\Documents and Settings\Mahisa Andara\My Documents\virus.bmp
    [2010/11/22 20:13:16 | 000,145,920 | ---- | C] () -- C:\Documents and Settings\Mahisa Andara\My Documents\I think I have a virus in my laptop.doc
    [2010/11/22 19:58:31 | 000,630,272 | ---- | C] () -- C:\Documents and Settings\Mahisa Andara\Desktop\dds.pif
    [2010/11/22 19:51:59 | 000,080,384 | ---- | C] () -- C:\Documents and Settings\Mahisa Andara\Desktop\MBRCheck.exe
    [2010/11/22 05:43:43 | 000,001,678 | ---- | C] () -- C:\Documents and Settings\All Users\Desktop\SUPERAntiSpyware Free Edition.lnk
    [2010/11/16 19:11:31 | 000,023,552 | ---- | C] () -- C:\Documents and Settings\Mahisa Andara\My Documents\Tugas B.Ing Mahisa Andara 20.doc
    [2010/11/15 19:47:14 | 000,002,356 | ---- | C] () -- C:\Documents and Settings\Mahisa Andara\Desktop\Google Chrome.lnk
    [2010/11/10 20:16:32 | 000,000,630 | ---- | C] () -- C:\Documents and Settings\Mahisa Andara\Desktop\RightMark CPU Clock Utility.lnk
    [2010/11/10 19:41:06 | 000,000,045 | ---- | C] () -- C:\WINDOWS\System32\initdebug.nfo
    [2010/11/10 07:02:55 | 000,000,469 | ---- | C] () -- C:\Documents and Settings\Mahisa Andara\Desktop\Shortcut to NO$WTT.exe.lnk
    [2010/11/05 21:16:49 | 011,205,733 | ---- | C] () -- C:\Documents and Settings\Mahisa Andara\My Documents\Nogizaka_Haruka_no_Himitsu_Purezza.zip
    [2010/11/02 17:49:39 | 000,036,993 | ---- | C] () -- C:\Documents and Settings\Mahisa Andara\My Documents\97129_9006_Okage_Shad.max
    [2010/11/02 17:49:22 | 000,029,696 | ---- | C] () -- C:\Documents and Settings\Mahisa Andara\My Documents\inter_understandability.doc
    [2010/11/02 17:49:22 | 000,027,648 | ---- | C] () -- C:\Documents and Settings\Mahisa Andara\My Documents\RELEVANCE.doc
    [2010/11/02 17:49:22 | 000,026,624 | ---- | C] () -- C:\Documents and Settings\Mahisa Andara\My Documents\financial report reliability.doc
    [2010/11/02 17:49:20 | 000,056,832 | ---- | C] () -- C:\Documents and Settings\Mahisa Andara\My Documents\5 Direktorat Perpajakan Mahisa Andara.ppt
    [2010/10/30 13:28:01 | 000,014,168 | ---- | C] () -- C:\WINDOWS\DIIUnin.dat
    [2010/10/30 13:27:59 | 000,002,829 | ---- | C] () -- C:\WINDOWS\DIIUnin.pif
    [2010/10/28 16:28:10 | 000,021,840 | ---- | C] () -- C:\WINDOWS\System32\SIntfNT.dll
    [2010/10/28 16:28:10 | 000,017,212 | ---- | C] () -- C:\WINDOWS\System32\SIntf32.dll
    [2010/10/28 16:28:10 | 000,012,067 | ---- | C] () -- C:\WINDOWS\System32\SIntf16.dll
    [2010/10/28 11:00:16 | 000,092,774 | ---- | C] () -- C:\Documents and Settings\Mahisa Andara\My Documents\SAPI 2J kel 1 sesi 3.pptx
    [2010/10/28 11:00:16 | 000,069,071 | ---- | C] () -- C:\Documents and Settings\Mahisa Andara\My Documents\SAPI 2J kel 1 sesi 2.pptx
    [2010/10/26 22:09:34 | 000,045,177 | ---- | C] () -- C:\Documents and Settings\Mahisa Andara\My Documents\kanwil.png
    [2010/10/26 22:08:49 | 000,214,016 | ---- | C] () -- C:\Documents and Settings\Mahisa Andara\My Documents\Paper Mario Badges.doc
    [2010/10/26 22:08:13 | 001,249,792 | ---- | C] () -- C:\Documents and Settings\Mahisa Andara\My Documents\Paper Mario.doc
    [2010/10/25 14:50:06 | 000,020,480 | ---- | C] () -- C:\Documents and Settings\Mahisa Andara\My Documents\Dapat Dibandingkan.doc
    [2010/07/24 20:47:44 | 000,832,512 | ---- | C] () -- C:\WINDOWS\System32\MobacXPro.dll
    [2010/05/14 19:51:48 | 000,473,600 | ---- | C] () -- C:\WINDOWS\System32\Harmony.dll
    [2010/05/14 19:51:48 | 000,237,568 | ---- | C] () -- C:\WINDOWS\System32\Unlha32.dll
    [2010/04/03 19:16:08 | 000,000,025 | ---- | C] () -- C:\WINDOWS\libem.INI
    [2010/04/02 23:58:10 | 000,043,520 | ---- | C] () -- C:\WINDOWS\System32\CmdLineExt03.dll
    [2010/03/18 22:57:21 | 000,000,149 | ---- | C] () -- C:\WINDOWS\SCXEdit.ini
    [2010/03/17 20:32:34 | 000,000,456 | ---- | C] () -- C:\WINDOWS\SIERRA.INI
    [2009/10/21 01:19:30 | 000,053,299 | ---- | C] () -- C:\WINDOWS\System32\pthreadVC.dll
    [2009/10/10 20:51:39 | 000,000,000 | ---- | C] () -- C:\WINDOWS\VPC32.INI
    [2009/10/09 21:00:45 | 000,077,824 | R--- | C] () -- C:\WINDOWS\System32\HPZIDS01.dll
    [2009/10/09 20:55:46 | 000,000,741 | ---- | C] () -- C:\Documents and Settings\All Users\Application Data\hpzinstall.log
    [2009/09/26 12:20:22 | 000,093,718 | ---- | C] () -- C:\WINDOWS\VGAsetup.ini
    [2009/09/24 18:29:49 | 000,000,056 | RHS- | C] () -- C:\WINDOWS\System32\207488A42B.sys
    [2009/09/22 16:57:50 | 000,363,520 | ---- | C] () -- C:\WINDOWS\System32\psisdecd.dll
    [2009/09/19 19:23:41 | 000,129,781 | ---- | C] () -- C:\WINDOWS\System32\VGAunistlog.ini
    [2009/08/14 00:26:17 | 000,014,848 | ---- | C] () -- C:\Documents and Settings\Mahisa Andara\Local Settings\Application Data\DCBC2A71-70D8-4DAN-EHR8-E0D61DEA3FDF.ini
    [2009/08/11 14:36:18 | 001,970,176 | ---- | C] () -- C:\WINDOWS\System32\d3dx9.dll
    [2009/07/11 22:07:36 | 000,000,000 | ---- | C] () -- C:\WINDOWS\mngui.INI
    [2009/06/08 12:13:03 | 000,001,682 | -HS- | C] () -- C:\WINDOWS\System32\KGyGaAvL.sys
    [2009/05/12 20:00:44 | 000,000,886 | ---- | C] () -- C:\WINDOWS\ODBC.INI
    [2009/05/10 00:18:37 | 000,004,161 | ---- | C] () -- C:\WINDOWS\ODBCINST.INI
    [2009/04/06 16:28:39 | 000,056,832 | ---- | C] () -- C:\WINDOWS\System32\iyvu9_32.dll
    [2005/08/30 00:00:00 | 000,781,312 | ---- | C] () -- C:\WINDOWS\System32\RGSS102J.dll
    [2005/08/30 00:00:00 | 000,778,752 | ---- | C] () -- C:\WINDOWS\System32\RGSS102E.dll
    [2005/08/30 00:00:00 | 000,771,584 | ---- | C] () -- C:\WINDOWS\System32\RGSS100J.dll
    [2001/07/07 03:00:00 | 000,003,399 | ---- | C] () -- C:\WINDOWS\System32\hptcpmon.ini
    [1999/01/23 01:46:58 | 000,065,536 | ---- | C] () -- C:\WINDOWS\System32\MSRTEDIT.DLL
    [1998/06/10 00:00:00 | 000,015,120 | ---- | C] () -- C:\WINDOWS\System32\REPUTIL.DLL
    [1996/04/04 02:33:26 | 000,005,248 | ---- | C] () -- C:\WINDOWS\System32\giveio.sys
    [2009/08/30 13:39:09 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\2DBoy
    [2009/09/02 22:05:13 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\DriverScanner
    [2010/11/23 17:49:58 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\FreeDownloadManager.ORG
    [2010/11/23 18:21:23 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\Nuance
    [2010/07/27 17:58:35 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\PassMark
    [2010/07/24 20:47:43 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\Pianosoft
    [2010/11/23 18:24:15 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\ScanSoft
    [2009/07/11 21:32:10 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\Teleca
    [2009/09/18 15:09:41 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\WinMount
    [2009/08/27 15:41:47 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\YoYoGames
    [2010/11/23 18:20:25 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\zeon
    [2009/09/02 21:47:25 | 000,000,000 | -H-D | M] -- C:\Documents and Settings\All Users\Application Data\{66E2F539-12B6-4870-A500-7689CDE75C5E}
    [2010/07/22 23:02:20 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Mahisa Andara\Application Data\adma
    [2010/09/13 20:47:04 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Mahisa Andara\Application Data\Beat Hazard
    [2010/04/09 13:39:54 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Mahisa Andara\Application Data\BITS
    [2010/09/25 21:40:12 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Mahisa Andara\Application Data\Conor O'Kane
    [2010/07/07 13:13:52 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Mahisa Andara\Application Data\ElevatedDiagnostics
    [2010/03/23 15:12:32 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Mahisa Andara\Application Data\FFSJ
    [2010/04/03 19:15:59 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Mahisa Andara\Application Data\FlashGet
    [2010/04/03 19:15:53 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Mahisa Andara\Application Data\FlashGetBHO
    [2010/04/09 14:06:35 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Mahisa Andara\Application Data\FlashgetSetup
    [2010/11/24 07:46:22 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Mahisa Andara\Application Data\Free Download Manager
    [2009/12/27 08:46:37 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Mahisa Andara\Application Data\Fujitsu
    [2010/05/18 20:03:51 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Mahisa Andara\Application Data\Image Zone Express
    [2009/09/16 00:16:36 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Mahisa Andara\Application Data\ImgBurn
    [2010/07/26 18:44:09 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Mahisa Andara\Application Data\Opera
    [2010/11/23 18:25:18 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Mahisa Andara\Application Data\ScanSoft
    [2009/09/18 19:25:44 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Mahisa Andara\Application Data\Subversion
    [2009/07/11 21:42:52 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Mahisa Andara\Application Data\Teleca
    [2009/09/02 21:47:22 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Mahisa Andara\Application Data\Uniblue
    [2009/09/18 15:09:55 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Mahisa Andara\Application Data\WinMount
    [2010/11/23 18:24:04 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Mahisa Andara\Application Data\Zeon
    I had to cut it off right here because of post limitations.
  10. 2010/11/23
    mahisa78
    mahisa78 Inactive Thread Starter
    ========== Custom Scans ==========
    < %SYSTEMDRIVE%\*.* >
    [2009/05/09 16:32:01 | 000,000,000 | ---- | M] () -- C:\AUTOEXEC.BAT
    [2004/08/03 23:00:00 | 000,260,272 | RHS- | M] () -- C:\cmldr
    [2010/11/23 13:27:14 | 000,019,522 | ---- | M] () -- C:\ComboFix.txt
    [2009/05/09 16:32:01 | 000,000,000 | ---- | M] () -- C:\CONFIG.SYS
    [2009/05/09 16:32:01 | 000,000,000 | RHS- | M] () -- C:\IO.SYS
    [2010/11/22 16:32:05 | 000,000,109 | ---- | M] () -- C:\mbam-error.txt
    [2009/05/09 16:32:01 | 000,000,000 | RHS- | M] () -- C:\MSDOS.SYS
    [2004/08/04 03:38:34 | 000,047,564 | RHS- | M] () -- C:\NTDETECT.COM
    [2009/08/03 06:58:21 | 000,250,048 | RHS- | M] () -- C:\ntldr
    [2010/11/24 07:52:07 | 1555,718,144 | -HS- | M] () -- C:\pagefile.sys
    < %systemroot%\Fonts\*.com >
    [2006/04/18 15:39:28 | 000,026,040 | ---- | M] () -- C:\WINDOWS\Fonts\GlobalMonospace.CompositeFont
    [2006/06/29 14:53:56 | 000,026,489 | ---- | M] () -- C:\WINDOWS\Fonts\GlobalSansSerif.CompositeFont
    [2006/04/18 15:39:28 | 000,029,779 | ---- | M] () -- C:\WINDOWS\Fonts\GlobalSerif.CompositeFont
    [2006/06/29 14:58:52 | 000,030,808 | ---- | M] () -- C:\WINDOWS\Fonts\GlobalUserInterface.CompositeFont
    < %systemroot%\Fonts\*.dll >
    < %systemroot%\Fonts\*.ini >
    [2009/05/09 16:31:38 | 000,000,067 | -HS- | M] () -- C:\WINDOWS\Fonts\desktop.ini
    < %systemroot%\Fonts\*.ini2 >
    < %systemroot%\Fonts\*.exe >
    < %systemroot%\system32\spool\prtprocs\w32x86\*.* >
    [2008/07/06 19:06:10 | 000,089,088 | ---- | M] (Microsoft Corporation) -- C:\WINDOWS\system32\spool\prtprocs\w32x86\filterpipelineprintproc.dll
    [2006/04/10 14:02:32 | 000,074,240 | ---- | M] (Hewlett-Packard Corporation) -- C:\WINDOWS\system32\spool\prtprocs\w32x86\hpzpp054.dll
    [2008/07/06 17:50:03 | 000,597,504 | ---- | M] (Microsoft Corporation) -- C:\WINDOWS\system32\spool\prtprocs\w32x86\printfilterpipelinesvc.exe
    < %systemroot%\REPAIR\*.bak1 >
    < %systemroot%\REPAIR\*.ini >
    < %systemroot%\system32\*.jpg >
    < %systemroot%\*.jpg >
    < %systemroot%\*.png >
    < %systemroot%\*.scr >
    < %systemroot%\*._sy >
    < %APPDATA%\Adobe\Update\*.* >
    < %ALLUSERSPROFILE%\Favorites\*.* >
    < %APPDATA%\Microsoft\*.* >
    [2009/08/19 15:05:26 | 000,001,674 | -H-- | M] () -- C:\Documents and Settings\Mahisa Andara\Application Data\Microsoft\LastFlashConfig.WFC
    < %PROGRAMFILES%\*.* >
    < %APPDATA%\Update\*.* >
    < %systemroot%\*. /mp /s >
    < %systemroot%\System32\config\*.sav >
    [2009/05/10 00:16:34 | 000,094,208 | ---- | M] () -- C:\WINDOWS\system32\config\default.sav
    [2009/05/10 00:16:34 | 000,659,456 | ---- | M] () -- C:\WINDOWS\system32\config\software.sav
    [2009/05/10 00:16:34 | 000,880,640 | ---- | M] () -- C:\WINDOWS\system32\config\system.sav
    < %PROGRAMFILES%\bak. /s >
    < %systemroot%\system32\bak. /s >
    < %ALLUSERSPROFILE%\Start Menu\*.lnk /x >
    [2010/06/15 18:30:46 | 000,000,272 | -HS- | M] () -- C:\Documents and Settings\All Users\Start Menu\desktop.ini
    < %systemroot%\system32\config\systemprofile\*.dat /x >
    < %systemroot%\*.config >
    < %systemroot%\system32\*.db >
    < %APPDATA%\Microsoft\Internet Explorer\Quick Launch\*.lnk /x >
    [2009/05/09 16:37:51 | 000,000,119 | -HS- | M] () -- C:\Documents and Settings\Mahisa Andara\Application Data\Microsoft\Internet Explorer\Quick Launch\desktop.ini
    [2009/05/09 16:37:50 | 000,000,079 | ---- | M] () -- C:\Documents and Settings\Mahisa Andara\Application Data\Microsoft\Internet Explorer\Quick Launch\Show Desktop.scf
    < %USERPROFILE%\Desktop\*.exe >
    < %PROGRAMFILES%\Common Files\*.* >
    < %systemroot%\*.src >
    < %systemroot%\install\*.* >
    < %systemroot%\system32\DLL\*.* >
    < %systemroot%\system32\HelpFiles\*.* >
    < %systemroot%\system32\rundll\*.* >
    < %systemroot%\winn32\*.* >
    < %systemroot%\Java\*.* >
    < %systemroot%\system32\test\*.* >
    < %systemroot%\system32\Rundll32\*.* >
    < %systemroot%\AppPatch\Custom\*.* >
    < %APPDATA%\Roaming\Microsoft\Windows\Recent\*.lnk /x >
    < %PROGRAMFILES%\PC-Doctor\Downloads\*.* >
    < %PROGRAMFILES%\Internet Explorer\*.tmp >
    < %PROGRAMFILES%\Internet Explorer\*.dat >
    < %USERPROFILE%\My Documents\*.exe >
    < %USERPROFILE%\*.exe >
    < %systemroot%\ADDINS\*.* >
    < %systemroot%\assembly\*.bak2 >
    < %systemroot%\Config\*.* >
    < %systemroot%\REPAIR\*.bak2 >
    < %systemroot%\SECURITY\Database\*.sdb /x >
    < %systemroot%\SYSTEM\*.bak2 >
    < %systemroot%\Web\*.bak2 >
    < %systemroot%\Driver Cache\*.* >
    < %PROGRAMFILES%\Mozilla Firefox\0*.exe >
    < %ProgramFiles%\Microsoft Common\*.* >
    < %ProgramFiles%\TinyProxy. >
    < %USERPROFILE%\Favorites\*.url /x >
    [2009/05/09 16:37:50 | 000,000,122 | -HS- | M] () -- C:\Documents and Settings\Mahisa Andara\Favorites\Desktop.ini
    < %systemroot%\system32\*.bk >
    < %systemroot%\*.te >
    < %systemroot%\system32\system32\*.* >
    < %ALLUSERSPROFILE%\*.dat /x >
    < %systemroot%\system32\drivers\*.rmv >
    < dir /b "%systemroot%\system32\*.exe" | find /i " " /c >
    < dir /b "%systemroot%\*.exe" | find /i " " /c >
    < %PROGRAMFILES%\Microsoft\*.* >
    < %systemroot%\System32\Wbem\proquota.exe >
    < %PROGRAMFILES%\Mozilla Firefox\*.dat >
    < %USERPROFILE%\Cookies\*.txt /x >
    [2010/11/24 07:53:24 | 000,180,224 | ---- | M] () -- C:\Documents and Settings\Mahisa Andara\Cookies\index.dat
    < %SystemRoot%\system32\fonts\*.* >
    < %systemroot%\system32\winlog\*.* >
    < %systemroot%\system32\Language\*.* >
    < %systemroot%\system32\Settings\*.* >
    < %systemroot%\system32\*.quo >
    < %SYSTEMROOT%\AppPatch\*.exe >
    [2003/06/13 17:23:06 | 000,050,176 | ---- | M] (Microsoft Corporation) -- C:\WINDOWS\AppPatch\AppLoc.exe
    [1 C:\WINDOWS\AppPatch\*.tmp files -> C:\WINDOWS\AppPatch\*.tmp -> ]
    < %SYSTEMROOT%\inf\*.exe >
    [2007/06/26 22:10:26 | 000,317,440 | ---- | M] (Microsoft Corporation) -- C:\WINDOWS\inf\unregmp2.exe
    < %SYSTEMROOT%\Installer\*.exe >
    < %systemroot%\system32\config\*.bak2 >
    < %systemroot%\system32\Computers\*.* >
    < %SystemRoot%\system32\Sound\*.* >
    < %SystemRoot%\system32\SpecialImg\*.* >
    < %SystemRoot%\system32\code\*.* >
    < %SystemRoot%\system32\draft\*.* >
    < %SystemRoot%\system32\MSSSys\*.* >
    < %ProgramFiles%\Javascript\*.* >
    < %systemroot%\pchealth\helpctr\System\*.exe /s >
    < %systemroot%\Web\*.exe >
    < %systemroot%\system32\msn\*.* >
    < %systemroot%\system32\*.tro >
    < %AppData%\Microsoft\Installer\msupdates\*.* >
    < %ProgramFiles%\Messenger\*.* >
    [2008/04/14 07:11:51 | 000,033,792 | ---- | M] (Microsoft Corporation) -- C:\Program Files\Messenger\custsat.dll
    [2004/08/04 01:06:34 | 000,004,821 | ---- | M] () -- C:\Program Files\Messenger\logowin.gif
    [2004/08/04 01:06:34 | 000,007,047 | ---- | M] () -- C:\Program Files\Messenger\lvback.gif
    [2008/05/02 21:01:49 | 000,083,968 | ---- | M] (Microsoft Corporation) -- C:\Program Files\Messenger\msgsc.dll
    [2008/04/14 00:30:28 | 000,180,224 | ---- | M] (Microsoft Corporation) -- C:\Program Files\Messenger\msgslang.dll
    [2008/04/14 07:12:28 | 001,695,232 | ---- | M] (Microsoft Corporation) -- C:\Program Files\Messenger\msmsgs.exe
    [2007/04/03 01:07:23 | 000,002,882 | ---- | M] () -- C:\Program Files\Messenger\newalert.wav
    [2007/04/03 01:07:23 | 000,006,156 | ---- | M] () -- C:\Program Files\Messenger\newemail.wav
    [2007/04/03 01:07:24 | 000,006,160 | ---- | M] () -- C:\Program Files\Messenger\online.wav
    [2004/08/04 01:06:36 | 000,004,454 | ---- | M] () -- C:\Program Files\Messenger\type.wav
    [2004/08/04 01:06:36 | 000,115,981 | ---- | M] () -- C:\Program Files\Messenger\xpmsgr.chm
    < %systemroot%\system32\systhem32\*.* >
    < %systemroot%\system\*.exe >
    < HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows\WindowsUpdate\AU >
    < HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\WindowsUpdate\ Auto Update\Results\Install|LastSuccessTime /rs >
    < End of report >
    My computer has gone back to normal :D:D:D:D
  11. 2010/11/23
    Good news :)
    You're running low on C drive free space.
    You should start moving some stuff out.
    Run OTL
      :OTL
      :Services
      :Reg
      :Files
      :Commands
      [purity]
      [emptytemp]
      [emptyflash]
      [Reboot]
    Last scans...
    1. Download Security Check from HERE, and save it to your Desktop.
    • Double-click SecurityCheck.exe
    • Follow the onscreen instructions inside of the black box.
    • A Notepad document should open automatically called checkup.txt; please post the contents of that document.
      NOTE SecurityCheck may produce some false warning(s), so leave the results reading to me.
    2. Download Temp File Cleaner (TFC)
    • Double click on TFC.exe to run the program.
    • Click on Start button to begin cleaning process.
    • TFC will close all running programs, and it may ask you to restart computer.
    3. Please run a free online scan with the ESET Online Scanner
    • Disable your antivirus program
    • Tick the box next to YES, I accept the Terms of Use
    • Click Start
    • IMPORTANT! UN-check Remove found threats
    • Accept any security warnings from your browser.
    • Check Scan archives
    • Click Start
    • ESET will then download updates for itself, install itself, and begin scanning your computer. Please be patient as this can take some time.
    • When the scan completes, push List of found threats
    • Click on Export to text file , and save the file to your desktop using a unique name, such as ESETScan. Include the contents of this report in your next reply.
    • NOTE. If Eset won't find any threats, it won't produce any log.
  12. 2010/11/24
    mahisa78
    OTL Log
    All processes killed
    ========== OTL ==========
    Registry value HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run\\Power2GoExpress deleted successfully.
    C:\Documents and Settings\Mahisa Andara\My Documents\~WRL0004.tmp deleted successfully.
    C:\WINDOWS\system32\207488A42B.sys moved successfully.
    C:\Documents and Settings\Mahisa Andara\Application Data\Uniblue\DriverScanner\Download folder moved successfully.
    C:\Documents and Settings\Mahisa Andara\Application Data\Uniblue\DriverScanner\Backups folder moved successfully.
    C:\Documents and Settings\Mahisa Andara\Application Data\Uniblue\DriverScanner folder moved successfully.
    C:\Documents and Settings\Mahisa Andara\Application Data\Uniblue folder moved successfully.
    ========== FILES ==========
    [EMPTYTEMP]
    User: Admin
    User: Admin_2
    ->Java cache emptied: 0 bytes
    ->FireFox cache emptied: 0 bytes
    User: All Users
    User: Default User
    User: Guest
    User: LocalService
    ->Temporary Internet Files folder emptied: 32902 bytes
    User: Mahisa Andara
    ->Temp folder emptied: 40791018 bytes
    ->Temporary Internet Files folder emptied: 56225 bytes
    ->FireFox cache emptied: 10057784 bytes
    ->Google Chrome cache emptied: 224804506 bytes
    ->Opera cache emptied: 0 bytes
    ->Flash cache emptied: 3051 bytes
    User: NetworkService
    Windows Temp folder emptied: 36823 bytes
    %systemroot%\system32\config\systemprofile\Local Settings\Temp folder emptied: 26838254 bytes
    RecycleBin emptied: 0 bytes
    Total Files Cleaned = 289.00 mb
    [EMPTYFLASH]
    User: Admin
    User: Admin_2
    User: All Users
    User: Default User
    User: Guest
    User: LocalService
    User: Mahisa Andara
    OTL by OldTimer - Version 3.2.17.3 log created on 11242010_171128
    Security Check Log
    Results of screen317's Security Check version 0.99.5
    Windows XP Service Pack 3
    Internet Explorer 8
    Antivirus/Firewall Check:
    Windows Firewall Enabled!
    Avira AntiVir Personal - Free Antivirus
    Antivirus up to date!
    Anti-malware/Other Utilities Check:
    Malwarebytes' Anti-Malware
    CCleaner
    Java(TM) 6 Update 22
    Out of date Java installed!
    Adobe Flash Player 10.1.102.64
    Adobe Reader 9.4.1
    Mozilla Firefox (3.6.12) Firefox Out of Date!
    Process Check:
    objlist.exe by Laurent
    Avira Antivir avgnt.exe
    Avira Antivir avguard.exe
    DNS Vulnerability Check:
    POOR! (Vulnerable to DNS cache poisoning!!-- Consider OPENDNS)
    ``````````End of Log````````````
    About the ESET, the program doesn't seem to work. It keeps disconnecting when it is downloading the components that it needs. I don't know if it's my internet but I can browse just fine.
  13. 2010/11/24
    Instead of Eset...
    Please run a BitDefender Online Scan
    • Disable your antivirus program.
    • Click Start Scanner button.
    • Click Start scan button
    • Allow browser plug-in to be installed when prompted.
    • Click I Agree to agree to the EULA.
    • Please refrain from using the computer until the scan is finished.
    • When the scan is finished, click on View log.
    • Notepad will open with scan results.
    • Save the report to your desktop and post its content in your next reply.
  14. 2010/11/24
    mahisa78
    Nevermind, I got ESET to work.
    C:\agth\agth.dll a variant of Win32/AGTH.A application
    C:\Aquaria\Aquaria.exe probably a variant of Win32/Spy.Agent.MBMNASI trojan
    C:\Documents and Settings\Mahisa Andara\Application Data\SUPERAntiSpyware.com\SUPERAntiSpyware\Quarantine\Quarantine - 11-22-2010 - 12-33-37\{32707120-6028-4000-B9FC-C6FD2F559336} a variant of Win32/Nebuler.BD trojan
    C:\Documents and Settings\Mahisa Andara\Application Data\SUPERAntiSpyware.com\SUPERAntiSpyware\Quarantine\Quarantine - 11-22-2010 - 12-33-37\{3E0E7E41-960B-4A48-82E4-1772240FB03D} a variant of Win32/Nebuler.BD trojan
    C:\Documents and Settings\Mahisa Andara\Application Data\SUPERAntiSpyware.com\SUPERAntiSpyware\Quarantine\Quarantine - 11-22-2010 - 12-33-37\{6E1140C7-B787-41A7-A679-661FE10C8468} a variant of Win32/Nebuler.BD trojan
    C:\Documents and Settings\Mahisa Andara\Application Data\SUPERAntiSpyware.com\SUPERAntiSpyware\Quarantine\Quarantine - 11-22-2010 - 12-33-37\{A294C42C-A612-4EF0-A58B-FE7C1F1877E4} a variant of Win32/Nebuler.BD trojan
    C:\Documents and Settings\Mahisa Andara\Application Data\SUPERAntiSpyware.com\SUPERAntiSpyware\Quarantine\Quarantine - 11-22-2010 - 12-33-37\{C98BAE5A-9734-45F9-A80B-56BDAF9B11A4} a variant of Win32/Nebuler.BD trojan
    C:\Nintendo64\Plugin\gltest.exe probably a variant of Win32/Agent.HUICCEF trojan
    C:\Qoobox\Quarantine\C\WINDOWS\shdll.exe.vir a variant of Win32/Injector.DQS trojan
    C:\WBFS\wbfs_inteligent_gui_v6.exe Win32/Packed.Autoit.E.Gen application
    E:\Downloads\software\avira_antivir_personal_en(1).exe a variant of Win32/Kryptik.ASG trojan
    E:\Downloads\software\avira_antivir_personal_en.exe a variant of Win32/Kryptik.ASG trojan
  15. 2010/11/24
    Run OTL
      :OTL
      :Services
      :Reg
      :Files
      C:\agth\agth.dll
      :Commands
      [purity]
      [emptytemp]
      [emptyflash]
      [Reboot]
    Your computer is clean :)
    1. We need to reset system restore to prevent your computer from being accidentally reinfected by using some old restore point(s). We'll create fresh, clean restore point, using following OTL script:
    Run OTL
    • Under the Custom Scans/Fixes box at the bottom, paste in the following:
    :OTL
    :Commands
    [purity]
    [emptytemp]
    [EMPTYFLASH]
    [CLEARALLRESTOREPOINTS]
    [Reboot]
    • Post resulting log.
    2. Now, we'll remove all tools, we used during our cleaning process
    Clean up with OTL:
    • Double-click OTL.exe to start the program.
    • Close all other programs apart from OTL as this step will require a reboot
    • On the OTL main screen, press the CLEANUP button
    • Say Yes to the prompt and then allow the program to reboot your computer.
    3. Make sure, Windows Updates are current.
    4. If any Trojan was listed among your infection(s), make sure, you change all of your on-line important passwords (bank account(s), secured web sites, etc.) immediately!
    7. Run Temporary File Cleaner (TFC) weekly.
    10. Run defrag at your convenience.
    11. Read How did I get infected?, With steps so it does not happen again!: http://www.bleepingcomputer.com/forums/topic2520.html
    12. Please, let me know, how your computer is doing.
  16. 2010/11/25
    mahisa78
    Here's the logs
    C:\agth\agth.dll moved successfully.
    C:\Aquaria\Aquaria.exe moved successfully.
    C:\Documents and Settings\Mahisa Andara\Application Data\SUPERAntiSpyware.com\SUPERAntiSpyware\Quarantine\Quarantine - 11-22-2010 - 12-33-37\{32707120-6028-4000-B9FC-C6FD2F559336} moved successfully.
    C:\Documents and Settings\Mahisa Andara\Application Data\SUPERAntiSpyware.com\SUPERAntiSpyware\Quarantine\Quarantine - 11-22-2010 - 12-33-37\{3E0E7E41-960B-4A48-82E4-1772240FB03D} moved successfully.
    C:\Documents and Settings\Mahisa Andara\Application Data\SUPERAntiSpyware.com\SUPERAntiSpyware\Quarantine\Quarantine - 11-22-2010 - 12-33-37\{6E1140C7-B787-41A7-A679-661FE10C8468} moved successfully.
    C:\Documents and Settings\Mahisa Andara\Application Data\SUPERAntiSpyware.com\SUPERAntiSpyware\Quarantine\Quarantine - 11-22-2010 - 12-33-37\{A294C42C-A612-4EF0-A58B-FE7C1F1877E4} moved successfully.
    C:\Documents and Settings\Mahisa Andara\Application Data\SUPERAntiSpyware.com\SUPERAntiSpyware\Quarantine\Quarantine - 11-22-2010 - 12-33-37\{C98BAE5A-9734-45F9-A80B-56BDAF9B11A4} moved successfully.
    C:\Nintendo64\Plugin\gltest.exe moved successfully.
    C:\WBFS\wbfs_inteligent_gui_v6.exe moved successfully.
    E:\Downloads\software\avira_antivir_personal_en(1).exe moved successfully.
    E:\Downloads\software\avira_antivir_personal_en.exe moved successfully.
    [EMPTYTEMP]
    User: Admin
    User: Admin_2
    User: All Users
    User: Default User
    User: Guest
    User: LocalService
    User: Mahisa Andara
    ->Temp folder emptied: 653780 bytes
    ->Temporary Internet Files folder emptied: 698219 bytes
    ->Google Chrome cache emptied: 187028119 bytes
    ->Flash cache emptied: 1573 bytes
    Windows Temp folder emptied: 0 bytes
    Total Files Cleaned = 180.00 mb
    [EMPTYFLASH]
    User: Admin
    User: Admin_2
    User: All Users
    User: Default User
    User: Guest
    User: LocalService
    User: Mahisa Andara
    OTL by OldTimer - Version 3.2.17.3 log created on 11252010_154929
    [EMPTYTEMP]
    User: Admin
    ->Temp folder emptied: 34411547 bytes
    ->Temporary Internet Files folder emptied: 16840297 bytes
    ->Java cache emptied: 2803750 bytes
    ->FireFox cache emptied: 93358856 bytes
    ->Google Chrome cache emptied: 74768176 bytes
    ->Flash cache emptied: 41984 bytes
    User: Admin_2
    User: All Users
    User: Default User
    User: Guest
    User: LocalService
    ->Temporary Internet Files folder emptied: 32768 bytes
    User: Mahisa Andara
    ->Google Chrome cache emptied: 7274432 bytes
    ->Flash cache emptied: 951 bytes
    Total Files Cleaned = 219.00 mb
    [EMPTYFLASH]
    User: Admin
    User: Admin_2
    User: All Users
    User: Default User
    User: Guest
    User: LocalService
    User: Mahisa Andara
    Restore points cleared and new OTL Restore Point set!
    OTL by OldTimer - Version 3.2.17.3 log created on 11252010_160056
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\{739A455D-8BD1-428B-A596-31EAA03FE94A}\GoogleCrashHandler.exe not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\{739A455D-8BD1-428B-A596-31EAA03FE94A}\GoogleUpdate.exe not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\{739A455D-8BD1-428B-A596-31EAA03FE94A}\GoogleUpdateHelper.msi not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\{739A455D-8BD1-428B-A596-31EAA03FE94A}\goopdate.dll not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\{739A455D-8BD1-428B-A596-31EAA03FE94A}\GoopdateBho.dll not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\{739A455D-8BD1-428B-A596-31EAA03FE94A}\goopdateres_ar.dll not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\{739A455D-8BD1-428B-A596-31EAA03FE94A}\goopdateres_bg.dll not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\{739A455D-8BD1-428B-A596-31EAA03FE94A}\goopdateres_bn.dll not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\{739A455D-8BD1-428B-A596-31EAA03FE94A}\goopdateres_ca.dll not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\{739A455D-8BD1-428B-A596-31EAA03FE94A}\goopdateres_cs.dll not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\{739A455D-8BD1-428B-A596-31EAA03FE94A}\goopdateres_da.dll not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\{739A455D-8BD1-428B-A596-31EAA03FE94A}\goopdateres_de.dll not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\{739A455D-8BD1-428B-A596-31EAA03FE94A}\goopdateres_el.dll not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\{739A455D-8BD1-428B-A596-31EAA03FE94A}\goopdateres_en-GB.dll not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\{739A455D-8BD1-428B-A596-31EAA03FE94A}\goopdateres_en.dll not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\{739A455D-8BD1-428B-A596-31EAA03FE94A}\goopdateres_es-419.dll not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\{739A455D-8BD1-428B-A596-31EAA03FE94A}\goopdateres_es.dll not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\{739A455D-8BD1-428B-A596-31EAA03FE94A}\goopdateres_et.dll not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\{739A455D-8BD1-428B-A596-31EAA03FE94A}\goopdateres_fa.dll not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\{739A455D-8BD1-428B-A596-31EAA03FE94A}\goopdateres_fi.dll not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\{739A455D-8BD1-428B-A596-31EAA03FE94A}\goopdateres_fil.dll not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\{739A455D-8BD1-428B-A596-31EAA03FE94A}\goopdateres_fr.dll not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\{739A455D-8BD1-428B-A596-31EAA03FE94A}\goopdateres_gu.dll not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\{739A455D-8BD1-428B-A596-31EAA03FE94A}\goopdateres_hi.dll not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\{739A455D-8BD1-428B-A596-31EAA03FE94A}\goopdateres_hr.dll not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\{739A455D-8BD1-428B-A596-31EAA03FE94A}\goopdateres_hu.dll not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\{739A455D-8BD1-428B-A596-31EAA03FE94A}\goopdateres_id.dll not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\{739A455D-8BD1-428B-A596-31EAA03FE94A}\goopdateres_is.dll not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\{739A455D-8BD1-428B-A596-31EAA03FE94A}\goopdateres_it.dll not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\{739A455D-8BD1-428B-A596-31EAA03FE94A}\goopdateres_iw.dll not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\{739A455D-8BD1-428B-A596-31EAA03FE94A}\goopdateres_ja.dll not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\{739A455D-8BD1-428B-A596-31EAA03FE94A}\goopdateres_kn.dll not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\{739A455D-8BD1-428B-A596-31EAA03FE94A}\goopdateres_ko.dll not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\{739A455D-8BD1-428B-A596-31EAA03FE94A}\goopdateres_lt.dll not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\{739A455D-8BD1-428B-A596-31EAA03FE94A}\goopdateres_lv.dll not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\{739A455D-8BD1-428B-A596-31EAA03FE94A}\goopdateres_ml.dll not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\{739A455D-8BD1-428B-A596-31EAA03FE94A}\goopdateres_mr.dll not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\{739A455D-8BD1-428B-A596-31EAA03FE94A}\goopdateres_ms.dll not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\{739A455D-8BD1-428B-A596-31EAA03FE94A}\goopdateres_nl.dll not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\{739A455D-8BD1-428B-A596-31EAA03FE94A}\goopdateres_no.dll not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\{739A455D-8BD1-428B-A596-31EAA03FE94A}\goopdateres_or.dll not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\{739A455D-8BD1-428B-A596-31EAA03FE94A}\goopdateres_pl.dll not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\{739A455D-8BD1-428B-A596-31EAA03FE94A}\goopdateres_pt-BR.dll not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\{739A455D-8BD1-428B-A596-31EAA03FE94A}\goopdateres_pt-PT.dll not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\{739A455D-8BD1-428B-A596-31EAA03FE94A}\goopdateres_ro.dll not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\{739A455D-8BD1-428B-A596-31EAA03FE94A}\goopdateres_ru.dll not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\{739A455D-8BD1-428B-A596-31EAA03FE94A}\goopdateres_sk.dll not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\{739A455D-8BD1-428B-A596-31EAA03FE94A}\goopdateres_sl.dll not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\{739A455D-8BD1-428B-A596-31EAA03FE94A}\goopdateres_sr.dll not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\{739A455D-8BD1-428B-A596-31EAA03FE94A}\goopdateres_sv.dll not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\{739A455D-8BD1-428B-A596-31EAA03FE94A}\goopdateres_ta.dll not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\{739A455D-8BD1-428B-A596-31EAA03FE94A}\goopdateres_te.dll not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\{739A455D-8BD1-428B-A596-31EAA03FE94A}\goopdateres_th.dll not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\{739A455D-8BD1-428B-A596-31EAA03FE94A}\goopdateres_tr.dll not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\{739A455D-8BD1-428B-A596-31EAA03FE94A}\goopdateres_uk.dll not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\{739A455D-8BD1-428B-A596-31EAA03FE94A}\goopdateres_ur.dll not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\{739A455D-8BD1-428B-A596-31EAA03FE94A}\goopdateres_vi.dll not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\{739A455D-8BD1-428B-A596-31EAA03FE94A}\goopdateres_zh-CN.dll not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\{739A455D-8BD1-428B-A596-31EAA03FE94A}\goopdateres_zh-TW.dll not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\{739A455D-8BD1-428B-A596-31EAA03FE94A}\npGoogleOneClick8.dll not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\UTPSDLL\GdiPlus.dll not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\UTPSDLL\mfc40u.dll not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\UTPSDLL\mfc71.dll not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\UTPSDLL\MFC71u.dll not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\UTPSDLL\msvcp60.dll not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\UTPSDLL\msvcp71.dll not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\UTPSDLL\msvcr71.dll not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\plugtmp-1\plugin-buzz_json.php not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\plugtmp-1\plugin-crossdomain-1.xml not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\plugtmp-1\plugin-crossdomain.xml not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\plugtmp-1\plugin-gateway-1.php not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\plugtmp-1\plugin-gateway.php not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\plugtmp-1\plugin-q1606194189_40.jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\plugtmp-1\plugin-restserver-1.php not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\plugtmp-1\plugin-restserver-2.php not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\plugtmp-1\plugin-restserver.php not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\plugtmp-1\plugin-server_status_rand.php not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\plugtmp-1\plugin-user not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\plugtmp-1\plugin-user-1 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\plugtmp-1\plugin-zgift_info.php not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\plugtmp-1\plugin-zuser_feed.php not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\chrome_10664\chrome.exe not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\07 Sendiri.mp3 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\19526.dmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\1gf13A.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\32D955.dmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\4y77A.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\8ba83.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\Admin.bmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\AdobeARM.log not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\Arabic.bin not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\AUCHECK_CORE.txt not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\AUCHECK_PARSER.txt not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\ceu79.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\chrome_installer.log not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\Czech.bin not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\Danish.bin not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\DataCard_Setup.exe not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\DIO99.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\DIO9A.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\DIO9C.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\DIO9D.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\DIOE4.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\DIOE6.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\DIOE7.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\DIOE9.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\DIOEA.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\DIOEC.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\DIOED.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\Dutch.bin not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\E220AutoRunLog.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\English.bin not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\Finnish.bin not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\French.bin not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\geColladaModelCacheLock not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\geIconCacheLock not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\German.bin not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\Greek.bin not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\Hebrew.bin not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\hpodvd09.log not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\hppEA.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\hppEB.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\hppEE.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\Hungarian.bin not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\i577C.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\isconfig.dat not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\Italian.bin not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\Japanese.bin not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\jar_cache1792062217955563174.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\jusched.log not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\Korean.bin not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\m8280.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR10.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR100.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR101.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR11.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR12.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR13.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR14.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR15.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR16.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR17.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR18.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR183.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR184.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR19.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR1A.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR1B.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR1C.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR1D.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR1E.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR1F.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR2.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR20.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR21.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR22.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR23.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR24.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR25.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR26.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR27.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR28.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR29.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR2A.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR2B.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR2C.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR2D.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR2E.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR2F.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR3.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR30.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR31.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR32.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR33.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR34.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR35.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR36.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR37.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR38.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR39.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR3A.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR3B.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR3C.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR3D.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR3E.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR3F.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR4.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR40.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR41.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR42.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR43.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR44.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR45.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR46.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR47.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR48.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR49.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR4A.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR4B.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR4C.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR4D.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR4E.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR4F.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR5.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR50.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR51.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR52.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR53.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR54.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR55.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR56.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR57.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR58.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR586.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR587.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR59.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR592.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR593.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR5A.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR5B.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR5C.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR5D.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR5E.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR5F.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR6.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR60.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR61.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR62.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR63.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR64.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR65.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR66.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR67.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR68.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR69.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR6A.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR6B.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR6C.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR6D.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR6E.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR6F.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR7.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR70.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR71.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR72.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR73.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR74.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR75.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR76.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR77.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR78.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR79.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR7A.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR7B.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR7C.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR7D.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR7E.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR7F.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR8.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR80.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR81.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR82.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR83.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR84.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR85.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR86.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR87.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR88.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR89.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR8A.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR8B.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR8C.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR8D.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR8E.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR8F.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR9.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR90.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR91.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR92.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR93.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR94.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR95.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR96.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR97.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR98.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR99.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR9A.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR9B.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR9C.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR9D.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR9E.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAR9F.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MARA.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MARA0.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MARA1.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MARA2.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MARA3.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MARA4.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MARA5.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MARA6.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MARA7.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MARA8.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MARA9.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MARAA.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MARAB.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MARAC.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MARAD.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MARAE.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MARAF.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MARB.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MARB0.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MARB1.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MARB2.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MARB3.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MARB4.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MARB5.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MARB6.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MARB7.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MARB8.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MARB9.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MARBA.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MARBB.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MARBC.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MARBD.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MARBE.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MARBF.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MARC.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MARC0.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MARC1.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MARC2.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MARC3.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MARC4.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MARC5.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MARC6.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MARC7.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MARC8.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MARC9.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MARCA.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MARCB.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MARCC.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MARCD.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MARCE.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MARCF.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MARD.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MARD0.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MARD1.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MARD2.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MARD3.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MARD4.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MARD5.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MARD6.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MARD7.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MARD8.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MARD9.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MARDA.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MARDB.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MARDC.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MARDD.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MARDE.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MARDF.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MARE.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MARE0.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MARE1.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MARE2.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MARE3.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MARE4.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MARE5.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MARE6.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MARE7.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MARE8.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MARE9.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAREA.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAREB.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAREC.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MARED.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAREE.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MAREF.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MARF.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MARF0.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MARF1.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MARF2.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MARF3.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MARF4.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MARF5.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MARF6.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MARF7.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MARF8.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MARF9.tmp not found!
    Need to cut this
  17. 2010/11/25
    mahisa78
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MARFA.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MARFB.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MARFC.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MARFD.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MARFE.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\MARFF.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\Norwegian.bin not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\np86.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\np87.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\np88.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\np89.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\np8A.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\np8B.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\np8C.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\np8D.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\np8E.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\np8F.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\np90.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\nqb7D.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\NSSstub.txt not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\Outlook Startup.BAK not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\Outlook Startup.Log not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\Polish.bin not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\Portuguese(Brazil).bin not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\Portuguese.bin not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\qtplugin.log not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\ResetDevice.exe not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\Russian.bin not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\SimChin.bin not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\Spanish.bin not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STS100.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STS102.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STS104.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STS11.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STS13.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STS15.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STS17.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STS186.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STS19.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STS1B.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STS1D.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STS1F.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STS21.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STS23.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STS25.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STS27.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STS2A.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STS2C.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STS2E.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STS30.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STS32.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STS34.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STS36.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STS38.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STS3A.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STS3C.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STS3F.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STS40.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STS42.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STS44.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STS46.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STS48.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STS4A.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STS4C.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STS4E.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STS5.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STS50.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STS52.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STS54.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STS57.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STS58.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STS58A.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STS596.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STS5A.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STS5C.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STS5E.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STS60.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STS61.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STS63.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STS65.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STS67.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STS69.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STS6B.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STS6D.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STS6F.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STS7.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STS71.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STS73.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STS75.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STS77.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STS79.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STS7B.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STS7D.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STS7F.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STS81.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STS83.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STS85.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STS87.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STS89.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STS8B.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STS8D.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STS8F.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STS9.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STS91.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STS93.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STS95.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STS99.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STS9C.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STS9E.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STS9F.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STSA1.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STSA2.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STSA5.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STSA6.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STSA8.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STSAB.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STSAC.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STSAF.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STSB.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STSB1.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STSB2.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STSB4.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STSB6.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STSB8.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STSBA.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STSBC.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STSBE.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STSC0.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STSC2.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STSC4.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STSC6.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STSC8.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STSCA.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STSCC.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STSCE.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STSD.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STSD0.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STSD2.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STSD4.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STSD6.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STSD8.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STSDA.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STSDC.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STSDE.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STSE0.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STSE2.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STSE4.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STSE9.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STSEB.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STSEC.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STSEE.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STSF.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STSF0.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STSF2.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STSF3.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STSF5.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STSF6.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STSF9.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STSFB.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STSFC.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\STSFE.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\SWEDISH.bin not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\SysConfig.dat not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\Thai.bin not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\TradChin.bin not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\Turkish.bin not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\TWAIN.LOG not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\Twain001.Mtx not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\Twunk001.MTX not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\Twunk002.MTX not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\UuU.uUu not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\vierra - perih.mp3 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\XxX.xXx not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\y7782.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\z9q137.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\zzj7B.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\~DF253F.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\~DF25BD.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\~DF2D8E.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\~DF3033.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\~DF3CC9.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\~DF4984.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\~DF5B68.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\~DF688F.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\~DF74A4.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\~DF8253.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\~DF8500.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\~DF8888.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\~DFAB78.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\~DFBB93.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\~DFCA6B.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temp\~DFDA80.tmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Sqm\iesqmdata0.sqm not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\0000000001_000000000000000017246[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\109s97r3[1].js not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\114[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\1CF18435D0FF3626A71EA8916858D2[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\1[1] not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\1[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\2B3E9413DB2289C9D3739EEB13158[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\32[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\34E8E75EDB1E66A37FC069ADD9C5[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\37BA92E210D341BFDBF4126422A3D2[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\3AD8DF65D75C46B812418F5EF9B7C[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\4355E4969BC7E34459E03C464B4A1B[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\528E19AA57C59BD28F9241C1469F1[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\5472601571F31E1BF00674C368D335[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\5A5D85F9B957D3FE27E8F090B6CCC6[1].css not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\6F2735128705FA1DDB4EC8DCB6C8D4[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\78274680349be220bab5ed[1].mp3 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\7[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\8fuf9r0d[1].css not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\9[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\A0DC35BFFCC035CBDB268278998B[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\acct_common[1] not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\activex-infobar-generic[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\ADSAdClient31[1].txt not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\aqovf93n[1].js not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\arrow_green_normal_shadow[1].bmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\availablemarkets[1].xml not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\background_gradient[1] not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\base[1].css not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\bb_MyMSN[1].htm not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\Behaviors[1].css not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\bgbtn[2].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\BLANK[1] not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\block_bg22[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\block_bg25[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\BlueButton_Left[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\bmwpl3j1[1].js not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\bullet[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\c2[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\CA72U9DL not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\camera[1] not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\car[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\CAYFWHLV not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\cf[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\client.bg[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\ClientForm_03[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\ClientForm_13[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\ClientForm_18[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\client_04[1].png not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\Client_07[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\client_08[1].png not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\Client_11[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\Client_12[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\Common[1].js not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\cpwebvw[1] not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\createpage2[1] not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\c[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\d14[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\d23[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\d34[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\D7A04960FF7BDD129E6527A4554FF6[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\Day%20After%20Day[1].wma not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\DD8BDB17B67F7D8DDCBF904DE18DB[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\DEE21CB29FF5357826D36AC0B99D[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\deletepage[1] not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\desktop.ini not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\desktop_icon_02[1].bmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\dnserrordiagoff_webOC[1] not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\EA3217D34A79204E64F0D748D7C5B6[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\ECB668FB-DBBE-4FF2-8789-B76FEF2EB04F[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\ErrorPageTemplate[1] not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\eventob[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\favicon[1].ico not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\fbml_static_get[1].php not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\forum[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\g19[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\g1[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\g22[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\g25[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\g26[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\g34[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\g8[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\gar[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\ga[2].js not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\GFF[1].js not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\gms_logo_id[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\halloween[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\help[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\hpweb_1-2_topnav_hp_logo[1] not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\idol[2].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\IE7[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\image4[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\jquery-1.3.2.min[1].js not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\jquery.hoverIntent.min[1].js not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\jquery.scrollTo-min[1].js not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\jquery[1].js not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\kv_logof[1].png not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\LatestVersion[1].txt not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\login[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\lvl1_10[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\m4[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\mainpage[2] not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\menulytogame[1].js not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\msft[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\msninstallersvc[1].asmx not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\name_common[1] not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\NavBar[1].xml not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\navi[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\new[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\new[1].js not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\new[2].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\nonGenuine[1].aspx not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\nonGenuine[1].css not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\o3[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\o4[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\o5[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\o9[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\offeringtrans[1].xml not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\ovr2_iaW[1].css not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\piwik_route[1].htm not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\piwik_route[2].htm not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\piwik_route[3].htm not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\piwik_route[4].htm not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\piwik_route[5].htm not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\piwik_route[6].htm not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\piwik_route[7].htm not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\piwik_route[8].htm not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\piwik_route[9].htm not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\popup[1].js not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\pw_common[2] not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\q100000029967642_3084[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\q100000111381019_8493[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\q100000260931282_1773[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\q100000274961470_3736[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\q100000393772240_4684[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\q101248749887_774[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\q1115503010_7986[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\q1397035771_3628[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\q1432929483_471[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\q1488421078_5518[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\q1525404098_3255[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\q1545091944_3706[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\q1806138277_8605[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\q1826017656_2857[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\rf[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\rightRail[1].css not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\roemer[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\rt_corner_bottom[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\SETTINGS[1] not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\shared[1].css not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\shd[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\sidebars[1].css not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\sitemap[1].css not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\statsCABXRCZA.htm not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\statsCAPMKSOP.htm not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\statsCARG1TAW.htm not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\statsCASXXU6Y.htm not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\statsCAV0CC9Y.htm not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\statsCAV7CN5D.htm not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\stats[10].htm not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\stats[11].htm not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\stats[1].htm not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\stats[1].swf not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\stats[2].htm not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\stats[2].swf not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\stats[3].htm not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\stats[3].swf not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\stats[4].htm not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\stats[4].swf not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\stats[5].htm not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\stats[5].swf not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\stats[6].htm not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\stats[6].swf not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\stats[7].htm not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\stats[7].swf not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\stats[8].htm not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\stats[9].htm not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\styles[1].css not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\Sync[1].htm not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\t160_1[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\t170_1[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\t171_1[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\t2_9[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\t4[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\t4_3[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\t6[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\t8[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\taskbullet[2] not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\top10[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\train[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\travian_basics[1].css not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\twt[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\u04[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\u2[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\UAHelp[1] not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\ushpw[1].css not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\v1_romans2[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\videoModal_IE8_overrides[1].css not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\views[1] not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\waiting_animation_2_sm[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\WebResource[1].axd not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\wlHelper[1].js not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\ULOF2LMF\x[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\0D1034492B6F732AEBA7F4F427AC8D[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\268p0h7e[1].css not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\29[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\3njt45l2[1].js not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\3[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\4du0u7p9[1].css not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\526A7F8640C59B49811F6B45D5C548[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\5472601571F31E1BF00674C368D335[1].gif not found!
    Had to cut this right here
  18. 2010/11/25
    Go on....
  19. 2010/11/25
    mahisa78
    mahisa78 Inactive Thread Starter
    Sorry, I have a sudden business.
    Here's the rest of it.
    Files\Content.IE5\QT6HML0R\5472601571F31E1BF00674C368D335[2].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\57011FE37F98BE0EE74CE87A62BA9B[1].png not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\5pwsqvbc[1].css not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\5[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\614595FBA50D96389708A4135776E4[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\6C1DD5E3386DEAE0954D8340F25A[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\7AA93EDA2452557C82ABDE5FB6F675[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\7D5A8E90AA65E42B1A6086302F8E[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\82ei77r1[1].css not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\99E344C361659183A3DF4AA785B7A[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\A3E817C92397F2C131B9E577575D6[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\ADSAdClient31[1].txt not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\att2[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\B8E48686CCE34A648DF4F6481BE060[1].js not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\balloon[1].xml not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\base_ie8[1].css not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\bb_membercenter[1].htm not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\bgticker[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\blc[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\block_bg24a[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\blu2[1].css not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\BlueButton_Middle[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\btm[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\btnselgame[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\btn[1].png not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\bulletmenuright[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\bullet[1] not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\CAAV25TV not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\CAHZR3ID not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\ChangePage[1] not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\chg_common[1] not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\ck[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\ck[2].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\classic[1] not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\ClientForm_04[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\ClientForm_06[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\ClientForm_15[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\client_02[1].png not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\Client_03[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\Client_05[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\client_06[1].png not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\Client_09[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\client_10[1].png not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\Client_15[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\Client_16[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\clock[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\CommonFunctions[1].js not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\core[1].css not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\cpwebvw[1] not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\CreatePage[1] not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\createpage[2] not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\d00[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\D18A4E36CE14D7C371DD69509C13AA[1].png not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\def1[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\def2[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\default[1].htm not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\def_i[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\deletepage2[1] not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\DeletePage[1] not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\delete[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\desktop.ini not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\desktop_icon_04[1].bmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\dkodaow4[1].css not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\dyn_bg1[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\E0DFF84D072469886D35AFF7442F9D[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\Empty_Movie[1].swf not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\enableguest[2] not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\expandrest[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\favcenter[1] not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\favicon[1].ico not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\favicon[2].ico not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\favicon[3].ico not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\fb[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\fx[1].js not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\g11[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\g15[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\g18[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\g21[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\g23[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\g24[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\g37[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\g4[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\g7[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\gar[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\graphic_vistalogo_wga[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\header_bkg_wol[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\helpdoc[1] not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\HomePage[1].htm not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\hpdjjs_com[1].htm not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\iabullet[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\idol[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\INETPROGRESS[1] not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\inventLogoBlue[1] not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\isconfig_Adobe[1].dat not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\iso[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\kvrc[1].png not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\kvwrap[1].png not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\logo[1].bmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\lytogames[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\Maria[1].wma not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\marquee[2].js not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\msnauins[1].exe not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\mt-full[1].js not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\mt-more[1].js not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\mw[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\NavBar[1].htm not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\navigationIE6[1].js not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\newsblock02[1].xml not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\newsbox2[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\new[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\nusrmgr[2] not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\nusrmgr[3] not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\o6[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\o7[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\ok[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\online[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\PicturePage[1] not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\piwik_route[10].htm not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\piwik_route[1].htm not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\piwik_route[2].htm not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\piwik_route[3].htm not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\piwik_route[4].htm not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\piwik_route[5].htm not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\piwik_route[6].htm not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\piwik_route[7].htm not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\piwik_route[8].htm not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\piwik_route[9].htm not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\plus[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\primedns[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\pudhtml[1].js not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\q100000009043486_5522[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\q100000012561482_9352[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\q100000084453530_6727[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\q100000103549803_7539[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\q100000349756481_9237[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\q1310206647_9309[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\q1458007536_2418[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\q1671764956_2255[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\q1715816422_1318[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\q1800582455_7102[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\Reader9Manifest[1].msi not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\reset[1].css not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\reset[2].css not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\separator[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\service[1].do not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\setupbgsound[1].wav not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\shared[1].css not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\spacer[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\StartNoNav[1] not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\statsCA8F1UA1.htm not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\statsCATJVPSJ.htm not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\statsCAWD02NN.htm not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\statsCAY925EX.htm not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\stats[10].htm not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\stats[11].htm not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\stats[1].htm not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\stats[1].swf not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\stats[2].htm not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\stats[2].swf not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\stats[3].htm not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\stats[3].swf not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\stats[4].htm not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\stats[4].swf not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\stats[5].htm not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\stats[5].swf not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\stats[6].htm not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\stats[6].swf not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\stats[7].htm not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\stats[7].swf not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\stats[8].htm not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\stats[8].swf not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\stats[9].htm not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\stats[9].swf not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\t172_1[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\t1_5[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\t2[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\t2_6[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\t4_2[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\t4_8[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\t9[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\tabs[1].css not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\tkclose[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\tlc[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\tracking[1].js not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\t[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\u3[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\UAHelp_Metrics[1].css not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\updateshop[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\updateTSB[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\v2_teutons2[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\v4_nature2[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\Validate[1].aspx not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\vpc[1].css not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\welcome_image1[1] not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\QT6HML0R\Xml[1].js not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\136[1] not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\19[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\2[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\47391686037786BD2E5A0738F865CC[1].png not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\5472601571F31E1BF00674C368D335[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\74xjbsos[1].png not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\81BCD49FA56A1C88AD2777D43CDE[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\91A27DE572836E1BBBD623627BE31F[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\AAD198FE948572219D39D1749BDCAE[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\AccountPage[1] not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\accountpage[2] not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\activex-rightclick_id[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\AC_OETags[1].js not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\ADSAdClient31[1].txt not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\ADSAdClient31[2].txt not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\ADSAdClient31[3].txt not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\ADSAdClient31[4].txt not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\alert_warning[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\anl[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\arrow_green_normal[1].bmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\att1[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\att_all[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\b4z5s2jw[1].js not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\barnews[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\bb_membercenter[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\bb_mymsn[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\bgbannerkiri[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\bgticker[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\bg_span2[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\block_bg21[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\block_bg23[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\boxbg[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\broker[1].js not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\buttons2[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\button_b[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\c3[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\CHIMES[1] not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\clear[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\ClientForm_01[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\ClientForm_02[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\ClientForm_05[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\ClientForm_14[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\clients[1].htm not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\client_01[1].png not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\Client_02[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\Client_04[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\client_05[1].png not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\Client_08[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\client_09[1].png not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\client_13[1].png not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\Client_14[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\Common[1].js not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\compact[1].css not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\Context[1].htm not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\cpwebvw[1] not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\createpage2[1] not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\d03[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\d04[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\d10[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\d13[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\daftarbaru[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\dap[1].js not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\defender[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\def[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\deletepage2[1] not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\desktop.ini not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\desktop_icon_03[1].bmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\DF6AF3D96C6584DCEF2CA0399036F8[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\dnserror[1] not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\dropshd[1].png not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\EB8FA6EEA6972C1EE0C76975B72B[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\ebExpBanner_3_0_70[1].js not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\errorPageStrings[1] not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\evcads58[1].js not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\exchagemarket[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\F1AAC83C2F74493C3043FFBCCDAD[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\faq[1].css not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\g10[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\g13[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\g27[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\g28[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\g41[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\g5[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\g6[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\gamenotice[1].css not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\glow_b[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\glvl[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\HELP[1] not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\Homepage__DESKTOP[1].js not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\Homepage__SHARED[1].js not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\honey[1].mp3 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\ieW[1].css not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\image38[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\Include[1].htm not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\internet-explorer[1].css not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\INVENTLOGO[1] not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\jquery-1.3.2.min[1].js not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\jquery[1].js not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\keyline[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\keys[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\known_providers_download_v1[1].xml not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\kvarr[1].png not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\LegitCheckControl[1].cab not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\login[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\logout[1].htm not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\MainNavigation[1].js not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\mainpage2[1] not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\map[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\Mola-ing%20-%20May%20Doni%20feat%202AM[1].wma not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\n1[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\n2[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\n3[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\n4[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\NamePage[1] not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\navcancl[1] not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\navigation[1].css not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\newsblock01[1].xml not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\newsbox1[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\noConnect[1] not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\npc[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\o10[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\o11[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\o1[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\o8[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\off[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\passwordpage2[1] not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\ping[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\pipe[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\piwik_route[10].htm not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\piwik_route[1].htm not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\piwik_route[2].htm not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\piwik_route[3].htm not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\piwik_route[4].htm not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\piwik_route[5].htm not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\piwik_route[6].htm not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\piwik_route[7].htm not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\piwik_route[8].htm not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\piwik_route[9].htm not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\popup[1] not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\pwcreate_o[1] not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\q100000028320159_2945[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\q100000069082036_4187[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\q100000097248521_800[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\q100000187046548_4681[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\q100000301118985_1477[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\q100000306270682_5844[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\q1433811581_5792[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\q1442423127_3567[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\q1494357410_785[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\q1536300670_8192[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\q1704720955_3120[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\q1829184840_9742[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\q1833317645_2651[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\reply[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\report_icons[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\rh[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\rh[2].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\RioTracking2[1].js not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\rss[1].xml not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\rss[2].xml not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\seal[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\separator[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\spacer[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\stats[10].htm not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\stats[1].htm not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\stats[1].swf not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\stats[2].htm not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\stats[2].swf not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\stats[3].htm not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\stats[3].swf not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\stats[4].htm not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\stats[4].swf not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\stats[5].htm not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\stats[5].swf not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\stats[6].htm not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\stats[6].swf not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\stats[7].htm not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\stats[7].swf not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\stats[8].htm not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\stats[8].swf not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\stats[9].htm not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\stfind_3[1] not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\s_code[1].js not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\t161_1[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\t1[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\t2_1[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\t4_1[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\t4_6[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\tci4csrj[1].css not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\tickernew[1].css not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\tklbg[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\tools[1] not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\tools[1].js not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\UAHelp_Classic[1].css not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\ua[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\underline[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\unx[1].js not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\us[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\v3_gauls2[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\Welcome[1] not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\wlanalytics[1].js not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\MRCX6VU3\wlHelper[1].js not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\104[1] not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\106[2] not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\10E2119DBA116936E36BE56ABB86A2[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\2488442_b6a0cd57-cfbd-40dc-8a17-40db7cde7db6[1].js not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\2CB27734FC64380D96FF021210B768[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\406[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\4[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\55770DB0C7B6FC241B5B70BD01D295[1].css not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\633icjcy[1].js not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\63A4838D5D34F4153EAC3AD28A3789[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\68630ED64E5C4C8418E2DB6347ED[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\696[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\6[1].jpg not found!
    Another cut
  20. 2010/11/25
    mahisa78
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\76C28D17AF17B8A6FD32268DF70F9[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\87C1FD1AA0ECD7137569A01D2A9C[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\8y26waj1[1].js not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\9szggd3c[1].css not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\adServer[1].htm not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\alert_error_bg[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\alicgn5p[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\article[1].css not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\bg11[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\bg_b[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\bg_footer_image_wol[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\billboard[1].css not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\bing-logo[1].png not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\BLANK[1] not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\BlueButton_Right[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\body[1] not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\brc[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\BurstingInteractionsPipe[1].htm not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\C7C14D6153545017AF49F781ED68F[1].png not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\CBA40BFD35F4FAACB38B0C2517E7F[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\cf[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\ClientForm_12[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\ClientForm_16[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\client[1].xml not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\Client_01[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\client_03[1].png not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\Client_06[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\client_07[1].png not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\Client_10[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\client_11[1].png not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\Client_17[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\Common[1].js not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\core[1].js not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\d24[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\def_c[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\del[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\desktop.ini not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\desktop_icon_01[1].bmp not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\dir[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\down[1] not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\E035E474ECAA8441F96FD35EBF60[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\eqbwgmd3[1].js not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\f2[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\f3[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\F5DFA14F32557D1F1AB8D73364ED22[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\F7AFD6FD9371ACDFE1873AA174F5E[1].png not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\FA134E11C3EB51172B8C565507FAC1[1].png not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\favicon[1].ico not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\firstpage[1].htm not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\g12[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\g14[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\g16[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\g17[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\g20[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\g22b[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\g2[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\g3[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\g9[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\glvlp[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\guest_disabled[1] not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\HelpLA_lib[1].js not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\Honey[1].wma not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\hpda[1] not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\hptr[1].js not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\hp[1].js not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\httpErrorPagesScripts[1] not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\id[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\info_48[1] not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\kvlc[1].png not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\lang[1].css not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\launcer[1].js not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\layout[1].css not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\Layout[2].css not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\lclsrch[1].xml not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\localtext[1] not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\lytogames[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\m3[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\mainpage[1] not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\marqticker[1].css not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\mbox[1].js not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\menulytogames[1].css not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\msn_b2[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\mt-core[1].js not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\n12[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\namepage[1] not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\NewStyles[1] not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\newsver[1].xml not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\nonGenuine[1].js not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\NOTIFYDLG[1] not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\nusrmgr[2] not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\o12[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\o2[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\PasswordPage[1] not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\picturepage[1] not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\pilihgame[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\piwik_route[1].htm not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\piwik_route[2].htm not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\piwik_route[3].htm not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\piwik_route[4].htm not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\piwik_route[5].htm not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\piwik_route[6].htm not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\popup[1] not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\pwcreate[1] not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\pw[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\pw[2].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\p[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\q100000045610147_1425[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\q100000113861843_7804[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\q100000161677697_753[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\q100000166969005_7556[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\q100000191677095_3077[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\q100000283326585_1765[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\q100000370577458_1072[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\q100000499153435_8907[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\q101248749887_8972[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\q1093932767_6839[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\q1288838079_7660[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\q1671834571_4614[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\q1782876915_7536[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\rand[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\Reader9Manifest[1].msi not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\res2[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\rf[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\ro[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\ro[2].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\rt_corner_top[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\ScriptResource[1].axd not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\ScriptResource[2].axd not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\seal[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\selectable[1] not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\server_errcat[1].xml not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\shared[1].css not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\shared[2].css not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\sidebar_background[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\skill7[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\specials[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\statsCA2B7OQB.htm not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\statsCA5G4JMX.htm not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\statsCADDEUY8.htm not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\statsCADH06L6.htm not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\statsCAFY89XK.htm not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\statsCAJSZEU8.htm not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\statsCAKEG831.htm not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\statsCAS06LQU.htm not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\statsCASBR5ZS.htm not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\statsCAT7DWF6.htm not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\statsCAYU5JCO.htm not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\stats[10].htm not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\stats[11].htm not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\stats[1].htm not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\stats[1].swf not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\stats[2].htm not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\stats[2].swf not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\stats[3].htm not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\stats[3].swf not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\stats[4].htm not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\stats[4].swf not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\stats[5].htm not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\stats[5].swf not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\stats[6].htm not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\stats[6].swf not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\stats[7].htm not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\stats[7].swf not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\stats[8].htm not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\stats[8].swf not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\stats[9].htm not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\stats[9].swf not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\STB-6[1].png not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\t0[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\t162_1[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\t2_2[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\t2_7[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\t3[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\t4_7[1].jpg not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\t5[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\t7[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\taskbullet[1] not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\taskbullet[2] not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\tnd[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\travian0[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\trc[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\users32[2] not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\users[2] not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\video[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\view[1].txt not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\WebServiceError[1] not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\welcome[1].htm not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\WhatIsWin7[1].css not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\wingkiri[1].gif not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\7GSATMQO\xml[1].js not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\Content.IE5\desktop.ini not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\AntiPhishing\2CEDBFBC-DBA8-43AA-B1FD-CC8E6316E3E2.dat not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\desktop.ini not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Temporary Internet Files\SuggestedSites.dat not found!
    File\Folder C:\Documents and Settings\Admin\Application Data\Sun\Java\Deployment\cache\6.0\29\4304d1d-20acadf1 not found!
    File\Folder C:\Documents and Settings\Admin\Application Data\Sun\Java\Deployment\cache\6.0\29\4304d1d-20acadf1.idx not found!
    File\Folder C:\Documents and Settings\Admin\Application Data\Sun\Java\Deployment\cache\6.0\28\752f415c-5d55ebd6 not found!
    File\Folder C:\Documents and Settings\Admin\Application Data\Sun\Java\Deployment\cache\6.0\28\752f415c-5d55ebd6.idx not found!
    File\Folder C:\Documents and Settings\Admin\Application Data\Sun\Java\Deployment\cache\6.0\15\3a8eb78f-1d02a067 not found!
    File\Folder C:\Documents and Settings\Admin\Application Data\Sun\Java\Deployment\cache\6.0\15\3a8eb78f-1d02a067.idx not found!
    File\Folder C:\Documents and Settings\Admin\Application Data\Sun\Java\Deployment\cache\6.0\13\70d0290d-236eb367-5.5.8.0- not found!
    File\Folder C:\Documents and Settings\Admin\Application Data\Sun\Java\Deployment\cache\6.0\13\70d0290d-236eb367-5.5.8.0-.idx not found!
    File\Folder C:\Documents and Settings\Admin\Application Data\Sun\Java\Deployment\cache\6.0\13\70d0290d-33932e7b-5.5.8.0- not found!
    File\Folder C:\Documents and Settings\Admin\Application Data\Sun\Java\Deployment\cache\6.0\13\70d0290d-33932e7b-5.5.8.0-.idx not found!
    File\Folder C:\Documents and Settings\Admin\Application Data\Sun\Java\Deployment\cache\6.0\13\70d0290d-46cf2073-5.5.8.0- not found!
    File\Folder C:\Documents and Settings\Admin\Application Data\Sun\Java\Deployment\cache\6.0\13\70d0290d-46cf2073-5.5.8.0-.idx not found!
    File\Folder C:\Documents and Settings\Admin\Application Data\Sun\Java\Deployment\cache\6.0\lastAccessed not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\OfflineCache\index.sqlite not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\00ABA00Cd01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\026E06D1d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\029DCB89d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\048D62F1d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\04DA1456d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\06E31C23d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\074B03DAd01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\07BEDA3Ed01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\08123E36d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\0B5CDF93d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\0B820A06d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\0CD5092Ad01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\0D215D25d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\0D7310B7d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\0ED21595d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\11E2C452d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\124A5788d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\12BB5A2Cd01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\13C5B46Fd01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\14265CC6d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\14D3532Fd01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\168AA1B8d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\17635D62d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\19F12FDFd01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\1AD9019Ad01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\1D1F8B5Ad01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\1D2B8312d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\1DD81DA0d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\1F48FF79d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\1FF80479d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\20559564d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\2081E939d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\220AA917d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\23292C52d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\235C7553d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\23ABC8A0d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\24BD9E2Cd01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\26034A66d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\26582214d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\26A9825Dd01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\275B80F4d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\27EF5B30d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\2C07ABBFd01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\2DD44BA8d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\2E5B7218d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\304E0ABCd01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\30C1B9ABd01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\32120798d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\338BD0EDd01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\33A603BCd01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\3466A9BFd01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\3493970Bd01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\3495325Cd01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\34A8BB45d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\353A3B99d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\35C7D49Fd01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\37967ECFd01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\37C0D1E3d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\3D1DAB64d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\3D4B9CA9d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\3F30BA09d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\403FDC60d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\40F4BAF7d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\427634E5d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\460F4D9Ed01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\462752A2d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\46A1831Cd01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\46F59BE0d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\474CE157d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\47AA173Dd01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\47D383F6d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\4885252Cd01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\4ACB33F3d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\4B11E8D7d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\4B37B87Ed01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\501728EBd01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\5024C483d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\509A4A93d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\51C6A451d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\5248640Fd01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\5389E235d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\5391A481d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\546912A8d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\55DE27E9d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\56DB9067d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\570B74DFd01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\577DCCFCd01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\592CDB4Dd01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\5AB6CA81d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\5D05FCF0d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\5DC9D79Cd01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\5E45ADE9d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\61050F72d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\610C5C01d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\6115BDD4d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\62007F7Dd01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\62606488d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\64383F78d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\64583E50d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\65384D1Dd01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\6820BD01d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\68C179D5d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\69A09A72d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\6C789ECAd01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\6D2B909Ed01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\6D86B673d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\6D952487d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\6EAF67C1d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\6F938C5Cd01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\70771AC3d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\711F0CFAd01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\722CBCCEd01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\72683F0Ed01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\72A9129Ad01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\72C7A8A5d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\742B5404d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\74F434D4d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\788D4EBEd01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\78E4AED6d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\79196ADBd01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\7964C07Ed01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\79F4DAADd01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\7A09DE1Bd01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\7A96B218d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\7AEBA34Ed01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\7C34016Ad01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\7C67E771d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\7C92EA80d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\7D5E36AAd01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\7E7332AEd01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\7ECFDE37d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\7F877366d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\7FD92C13d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\800FB683d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\80573E6Cd01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\80B64019d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\80CBC5A3d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\813D50F2d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\85251B0Bd01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\8751E096d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\8939E74Ed01 not found!
    Another cut
  21. 2010/11/25
    mahisa78
    mahisa78 Inactive Thread Starter
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\8959ED51d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\89A10C39d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\8A09ADE6d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\8C38E88Ed01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\8D12C2D4d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\8D9AB39Ad01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\8E71056Ed01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\8E8926C3d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\8F5E7C04d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\8F7C35D9d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\8F93F688d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\911BBB06d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\932830B1d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\9489C1B6d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\949F0A25d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\957E9AD0d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\96B41EFEd01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\9743E216d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\97C33A26d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\98A0047Ed01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\99D565B9d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\9A798F40d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\9B441568d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\9C06172Cd01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\9D848D33d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\9E0C4C1Ed01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\A12A8047d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\A13B596Ad01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\A2DA56A0d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\A302174Ed01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\A3854D0Cd01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\A3A5ED53d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\A3C3296Fd01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\A4AECC64d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\A56F5D6Ad01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\A86A5802d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\A97AAD67d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\AA8E8C0Bd01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\AAB32387d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\AB19E8B5d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\ABAA8F9Ed01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\AE0628D3d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\AE828718d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\B122BEE4d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\B16AA673d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\B21DC76Ad01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\B34C27C4d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\B37E9224d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\B42E6BA5d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\B62FD27Ad01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\B8429682d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\B8C5B4C1d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\B8C63C03d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\BA0CE754d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\BA96B795d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\BAA243B2d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\BBA13A48d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\BBE0601Cd01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\BD5F9B59d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\BEE9FF14d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\C12C7BF6d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\C44491E4d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\C628DD5Cd01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\C6541853d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\C70049B2d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\C7B2C1B7d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\CA53B955d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\CAABE4C1d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\CC7C5D19d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\CCB6F6D2d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\CCF0ABC5d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\CDCD3799d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\CE90507Ed01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\CEE4A77Bd01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\CEEF1936d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\CF105F03d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\D02B3E30d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\D03ACAA6d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\D1808DF6d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\D626BB66d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\D68CAC30d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\D6D8F343d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\D766E315d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\D88D3291d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\D98439B9d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\D9A99FA6d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\D9FDA1A3d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\DA441C79d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\DBE5D81Ad01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\DC222288d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\DD31E9E9d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\DDD71209d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\DE00B0D3d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\E0447D56d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\E0504B8Ad01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\E06DDD1Ad01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\E089E10Cd01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\E15BB43Ad01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\E35D1320d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\E87038FDd01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\E879F38Ed01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\E8E6B87Cd01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\E90FA7E2d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\EAFFA043d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\EB871A74d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\EC50F605d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\EEAA1122d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\EEE34A8Bd01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\EF946C47d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\EFB1AA92d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\F0297ECBd01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\F1BD1227d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\F2CF81F7d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\F317DDD8d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\F4F40AFDd01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\F69E7EC5d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\F870DAE8d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\F8D28C59d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\F9EC2275d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\FA998A24d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\FD889465d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\FE7BE5A8d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\FE7EEF25d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\FFBD9E68d01 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\_CACHE_001_ not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\_CACHE_002_ not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\_CACHE_003_ not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\Cache\_CACHE_MAP_ not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\urlclassifier3.sqlite not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\XPC.mfl not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Mozilla\Firefox\Profiles\ulcw7np0.default\XUL.mfl not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\data_0 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\data_1 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\data_2 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\data_3 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_000001 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_000002 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_000003 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_000004 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_000005 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_000006 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_000007 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_000008 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_000009 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_00000a not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_00000b not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_00000c not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_00000d not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_00000e not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_00000f not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_000010 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_000011 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_000012 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_000013 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_000016 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_000017 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_000018 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_000019 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_00001a not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_00001b not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_00001d not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_00001e not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_000020 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_000024 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_000025 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_000026 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_000027 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_000028 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_000029 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_00002b not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_000031 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_000032 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_000033 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_000035 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_000036 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_000037 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_000039 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_00003a not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_00003b not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_00003c not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_00003e not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_000040 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_000041 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_000042 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_000043 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_000044 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_000045 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_000046 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_000047 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_000048 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_000049 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_00004a not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_00004c not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_00004e not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_00004f not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_000050 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_000052 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_000053 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_000054 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_000055 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_000057 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_000058 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_000059 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_00005a not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_00005c not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_00005e not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_000060 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_000062 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_000063 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_000064 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_000065 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_000066 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_000067 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_000068 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_000069 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_00006a not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_00006b not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_00006c not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_00006d not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_00006e not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_00006f not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_000070 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_000071 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_000072 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_000073 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_000074 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_000075 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_000076 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_000077 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_000078 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_000079 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_00007a not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_00007b not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_00007c not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_00007d not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_00007e not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_00007f not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_000080 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_000081 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_000082 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_000083 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_000084 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_000085 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_000086 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_000087 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_000088 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_000089 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_00008a not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_00008b not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_00008d not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_00008f not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_000090 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_000091 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_000092 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_000093 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_000094 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_000095 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_000096 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_000097 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_000098 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_000099 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_00009a not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_00009d not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_00009f not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_0000a0 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_0000a1 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_0000a3 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_0000a5 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_0000a6 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_0000a7 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_0000a9 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_0000aa not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_0000ab not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_0000ac not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_0000ad not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_0000ae not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_0000af not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_0000b0 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_0000b1 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_0000b2 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_0000b3 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_0000b4 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_0000b5 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_0000b6 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_0000b7 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_0000b8 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_0000b9 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_0000ba not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_0000bb not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_0000bc not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_0000bd not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_0000be not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_0000bf not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_0000c0 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_0000c1 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_0000c2 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_0000c3 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_0000c4 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_0000c5 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_0000c6 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_0000c7 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_0000c8 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_0000c9 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_0000ca not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_0000cb not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_0000cc not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_0000ce not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_0000cf not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_0000d0 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_0000d1 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_0000d2 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_0000d3 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_0000d4 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_0000d5 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_0000d6 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_0000d7 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_0000d8 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_0000d9 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_0000da not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_0000db not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_0000dc not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_0000dd not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_0000de not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_0000df not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_0000e0 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_0000e1 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_0000e2 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_0000e3 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_0000e4 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_0000e5 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_0000e6 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_0000e7 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_0000e8 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_0000e9 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_0000ea not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_0000eb not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_0000ec not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_0000ed not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_0000ee not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_0000ef not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_0000f0 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_0000f1 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_0000f2 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_0000f3 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_0000f4 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_0000f5 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_0000f6 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_0000f7 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_0000f9 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_0000fa not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_0000fb not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_0000fd not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_0000fe not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_000100 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_000101 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_000102 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_000103 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_000104 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_000105 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_000106 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_000107 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_000108 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_000109 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_00010a not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_00010b not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_00010c not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_00010d not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_00010e not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_00010f not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_000110 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_000111 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_000112 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_000113 not found!
    File\Folder C:\Documents and Settings\Admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Cache\f_000114 not found!
    Cut!
