RSRC32.dll Help
Discussion in 'Legacy Windows' started by talker111, 2003/02/23.
  1. 2003/02/23
    talker111
    talker111 Inactive Thread Starter
    I installed TClockEx, it came back with message RSRC32.DLL not found, it is in my system and windows folders. Any one know why the clocl gives me this message?
  2. 2003/02/23
    Daizy
    Daizy Inactive
    Hi talker111
    Welcome to the boards!
    I wonder if you went to Add/remove and uninstalled resource meter....... rebooted...then tried to re-install it, if it would work?
    Daizy
    Daizy
    Daizy Inactive
    Hi again talker111
    Thank you for the note. If it's ok, I'll paste it back to the board. This way others that come along, with a similar problem, can use the search feature, and see that there was a solution. :)
    And you're most welcome! Now stick around.......it's good to have you here.
    Daizy
