RNAdmin and ccApp ( Need help )
Discussion in 'Windows XP' started by ElaineChai, 2003/10/16.
  1. 2003/10/16
    ElaineChai
    ElaineChai Inactive Thread Starter
    Hi, i am running windows XP instead of windows 98, i have the same problem about notification for Wnd of RNAdmin ..
    i try to run the msconfig..but i dont know which should i disabled in the startup...
    and i couldnt find RNAdmin in that...
    It can be due to real player because i used real player this two days...
    Please , help me..
    Will this notification harm my PC.
    ANother thing is about the notification on ccApp..
    this is a synmatec shared stuff.....i can find this in mscofig...should i disabled it.. this is a programme i believe run by the anti virus..
    but in this case, the notification will go off itself during shut down..
    please help
    thank you
    elaine
  2. 2003/10/16
    Johanna
    Johanna Inactive Alumni
    ccApp is a Symantec program that needs to be in the startup. You can look on Black Viper's site for things safe to shut down on start up. I suggest leaving anything by Symantec ALONE- let it do its thing. What exactly is the problem or error message you are getting? Are there any problems with function? If you can be more specific, I am sure we can figure out what to do.
    Johanna
    Elaine,
    I don't have RealPlayer installed, but reading through that long thread in the 98 forum - which wandered off the point - it would seem that you have 3 options.
    1. Open up RealPlayer and somewhere (Preferences?) you should find an option to 'Check for updates' - make sure it is unchecked.
    The message will do no harm to your PC.
    2. Right click a blank area of the Taskbar > Properties > Start Menu Tab> Customise > Remove and remove RealPlayer from the Startup Folder. (I am running XP Pro with the Classic interface so it might be a little different) It will then not start when you boot the PC.
    3. Uninstall RealPlayer
    Don't disable CCApp - that is NAV - what is the notification re. ccAPP?
  5. 2003/10/17
    ElaineChai
    RNAdmin and ccApp
    Thanks PeteC on RNAdmin notification...
    I unchecked the realplayer updates and it seem to work but it is quite slow during the shut down process...but i will try again within this few days and see how things go.
    About ccApp, the notification goes too fast, i dun have enough time to read at the notification. this notification is different compare to RNAdmin because it will end by itself.
    anyway i will observe my pc a few days more and see.
    Thanks for your reply
    I will keep you update about this info.
