right click menu in winxp empty??
Discussion in 'Windows XP' started by kassab, 2003/09/16.
  1. 2003/09/16
    kassab
    kassab Inactive Thread Starter
    for the first time i am using winxp home eddition.
    past,copy,cut are greyed out in right click menu, i did install many file into the registry to fix it, but no luck ..my computer is not listed in start menu.
    any idea
    thank you
  2. 2003/09/16
    Create another user account and then log on with it. If the problem has vanished, you have a corrupt user account and need to get rid of it. Good instructions Here.
    Otherwise, please amplify some on "i did install many file into the registry to fix it ".
