Resolved returning to ie8 from ie9 problem
Discussion in 'Internet Explorer & Microsoft Edge' started by savagcl, 2012/08/06.
  1. 2012/08/06
    savagcl Lifetime Subscription
    System is Vista SP2.
    Windows 9 was installed and started causing problems (winsock).
    I got the winsock file reset and it should be ok for a while.
    The problem is when i try to return to IE-8, I don't see IE-9 listed under the
    control panel>programs and features> windows components so i can not
    uninstall IE-9 (and cannot install IE-8 because a newer version exist).
    Under these conditions how can i uninstall IE-9
    Thanks,
  2. 2012/08/06
    SpywareDr
