restore wont work
Discussion in 'Windows XP' started by muruga, 2007/09/05.
  1. 2007/09/05
    muruga
    muruga Well-Known Member Thread Starter
    Today i had a real disater one of my programs just disappeared. that is to say all the files (except data files - thak God) just disappeared from the HD.
    So my 1rst inclination was to do a system restore. I went to the closest date and after a while it went through a process but NOTHING happened. Got message - no restore happened no changes. I tried several dates to no avail.
    What is going on!!?? this is bad news when you can't do a restore PLS help
    Of course the other Q is why did those files disappear in the 1rst place????. all I did prior to that was a defrag using the MS defrag
    I run XP Pro
    thanks
  2. 2007/09/05
    Dennis L Inactive Alumni
    System Restore will not backup programs. Special backup programs can, just not System Restore. Without knowing what program you lost, I would backup the data files to another folder. Then run Add/Remove Programs and properly remove program from your computer. Now reinstall program. Test program for proper load/run. If good, move data back to proper folder(s).
    charlesvar
    charlesvar Inactive Alumni
    Thank you for the correction Charles.
    I was not aware SR protected via global file extension. "I assumed "... if it was not part of the Registry and/or a monitored OS system file(s) (deep dark secret only known by MS monks), SR would not back it up.
    We all know what they say about, "I assumed ". :eek:
  6. 2007/09/07
    muruga
    System Restore not working
    except for the data files and 2 .DLLs all the files of this program (AskSam) were GONE just plain disappeared from the whole HD
    a real mystery
    I managed to reinstall. but why did it all disappear???
