Restore Registry and Adobe 9 (2 problems)
Discussion in 'Windows XP' started by tanya, 2009/10/22.
  1. 2009/10/22
    tanya
    tanya Inactive Thread Starter
    Hi,
    Windows XP (up to date), when I right click start, C is not expanded. It has a plus sign next to it. I don't know why this occurred.
    Up to a few days ago it opened with the folders on C showing (no plus sign on C) Now it does not display the folders unless I click the plus sign.
    Yesterday, Adobe installed reader vs. 9.0 and since then this memory challenged celeron PC has had further slowness. (Adobe installed after the right-click start problem had occurred)
    Has anyone had problems with adobe 9 (as to slowing the system?) - I removed it features from start-up (msconfig) no help
    Has anyone experienced a different display pattern for right-clicking the windows xp start button
    The reason I am concerned about the right-click (windows explorer) alternate display is that it occurred on another computer (windows 98) and after that the other PC was never the same.
    Thank you in advance!
  2. 2009/10/22
    tanya
    Partly Solved - Restore Registry and Adobe 9 (1 problem now)
    Hi,
    The explorer issue has been solved: I had too many folders on C to have them all displayed when right-clicking the start button. I only had to remove some folders.
    Despite restoring the registry, the adobe issue persists...
