Reset Display Settings
Discussion in 'Windows XP' started by telephonics, 2009/01/29.
  1. 2009/01/29
    telephonics
    telephonics Inactive Thread Starter
    Use XP Home with SP-2 and IE6.0. Is it possible to reset the display playertices to those that were originally used by manufacturer (Dell)???
  2. 2009/01/29
    I have not seen that facility - what is your basic problem?
    The only two settings are likely to be screen resolution and colour depth - I doubt colour management was set.
    telephonics
    When I open web sites the font size that appears is overly large to the point wher I have to reduce the size of the letters considerably. I do have an eye problem and perhaps some time in past I set a convention ( not sure that is the right word) and that is now causing problem. Is there a place where visually handicapped users of XP can learn about these options?
  5. 2009/01/30
    In Internet Explorer > View > Text size gives you several settings.
    Is everything OK in Windows in general?
  6. 2009/01/30
    mickzer
    mickzer Well-Known Member
    Or if you have a mouse with a scroll wheel, hold down the Ctrl button and scroll up and down until you can see clearly.
    mickzer.
