[Replacement for] Dell dimension 4400 motherboard
Discussion in 'PC Hardware' started by eyedea40, 2006/04/24.
  1. 2006/04/24
    eyedea40
    eyedea40 Inactive Thread Starter
    Hello every one. Does dell make any other mobo that is compatible with the 4400 mobo.My mobo in my 4400 has shorted out and I now need a replacement.
    Here are the specs on the 4400 mobo the dell rep gave me
    Hello does dell make any other mobo'a that are compatible with the 4400 mobo.My mobo in my 4400 has shorted out and I now need a replacement.
    p4 nothwood(478 pin) processor and the intel 845d (brookdale) chipset. this system is designd for ddr memory.
  2. 2006/04/25
    Can you get an exact replacement?
    r.leale Lifetime Subscription
    r.leale Well-Known Member
    Hi eyedea40,
    If you can't get an exact replacement be very sure that a new mobo will fit in the Dell case. They tend to have tailored Mobos, much smaller than normal.
    Roger
  5. 2006/04/26
    Whiskeyman Inactive Alumni
    If you don't get an exact replacement you will have trouble with activation after doing a needed repair or fresh install if you are using XP. XP OEM on proprietary computers such as Dells are tied to the motherboard. When changing to another motherboard that is not the same Microsoft considers it a different computer and requires the new purchase of XP.
  6. 2006/04/26
    Scott Smith
    Scott Smith Inactive Alumni
    I looked on Ebay for ya but no luck. All I found was used 4400s.
