replacement CD for a retail OS
Discussion in 'Legacy Windows' started by So0o0Confused, 2003/01/21.
  1. 2003/01/21
    So0o0Confused
    So0o0Confused Inactive Thread Starter
    how do i get a replacement CD for a retail Version of Windows98 SE full install?
    I scratched mine and am unable to get past 17% of the installation process
    I tried using all kinds of products on it but the scratch is just to deep to repair.
  2. 2003/01/22
    markp62
    markp62 Geek Member Alumni
    Miz
    Miz Inactive Alumni
    Call Microsoft. They are usually quite helpful in replacing a legally purchased damaged Windows CD.
    You can also borrow a 98SE from a friend and just enter your CD's numbers when it asks for them.
    Finally, if you haven't already formatted the drive you're trying to install 98 on, the the C:\Windows\Options\Cab folder contains the contents of the 98 CD. You can do a reinstall from the setup.exe file in that folder.
    Miz,
