removing SP2 problems...
Discussion in 'Windows XP' started by backer, 2007/01/22.
  1. 2007/01/22
    backer
    backer Inactive Thread Starter
    Hey guys im back yet again.
    i try to follow the steps on this website http://support.microsoft.com/KB/875350
    when i cant find Sp2 on my add remove list so i try
    Use the hidden $NtServicePackUninstall$ folder
    I get this message..
    c:\windows\$NtServicePackUninstall$\spuninst\spuninst.exe refers to a location that is unavailable. It could be on a hard drive this computer or a network. Check to make sure that the disc is properly inserted or you are connected to the internet or your network and then try again.
    and the system restore is all out of wack
    Please help
  2. 2007/01/23
    If your version of XP came with SP2 preinstalled, it can't be deleted.
