Removal of the IE Q813489,OE and removing then Q811493?
Discussion in 'Windows XP' started by lringer, 2003/05/07.
  1. 2003/05/07
    lringer
    lringer Inactive Thread Starter
    Would removing the IE Q813489, OE Q330994 and removing the "Q811493 ", then reinstalling the IE Q813489 and OE Q330994 be preferred or could this present problems?
    Concerned!
  2. 2003/05/07
    miniB
    miniB Inactive
    Q811493
    Hi
    I certainly removed this one and hadn't any problems.( Q811493) I know one thing I didn't think the computer was slow until I removed this & the PC sped .....
    I did not have the IE & OE updates at that time as these are more recent. It may be advisable to remove them first as you have suggested.
    I am not sure if they are interlinked but as things can get scrambled it might just be wise to do so.
    Shemp
    Shemp Inactive
    I uninstalled Q811493 without first uninstalling any other patches that were installed after Q811493. During the removal process I received a warning that some of the patches installed subsequent to my installation of Q811493 may not work properly. I ignored the words of caution and proceeded with the uninstall of only Q811493 and I have not experienced any problems.
    - Shemp
  5. 2003/05/10
    miniB
    miniB Inactive
    Hi
    Great to hear that you have proved that sometimes the warnings are not as they seem ! I would have been like yourself being very cautious.
    I hope your computer likes the improvement.
    It is nice to hear how things worked out ~ Thanks.
