Removal incomplete !
Discussion in 'Malware and Virus Removal Archive' started by jbarker, 2006/04/04.
  1. 2006/04/04
    jbarker
    jbarker Inactive Thread Starter
    Hope someone can help - a local computer chain store tech rep could not !
    Have Windows XP Pro
    Have Norton Anti Virus (up to date !)
    So, Norton found a virus named LostRun.exe and deleted it.
    We do a search and that program is not found.
    However, when we boot up - the computer stops during the process of loading Windows, and gives this message:
    "Windows cannot find C/Windows/System32/Tools/LostRun.exe. Make sure you typed the name correctly, and try again. "
    Of course Windoes can't find it - Norton deleted it !
    So, there is still a reference to that program somewhere, and the computer just stops with the above message.
    How can we locate that reference and remove it so the boot up can continue ?
  2. 2006/04/04
    Boot the comp in Safe Mode.
    Locate where the call to load LostRun.exe is coming from, either a startup folder or the registry or a system file. Delete the entry for it.
    There are approx 53 different places a program can load from at boot time.
    charlesvar
    charlesvar Inactive Alumni
