Resolved Remote Desktop only works on port 3389
Discussion in 'Networking (Hardware & Software)' started by Jeremie, 2011/08/09.
  1. 2011/08/09
    Jeremie
    Jeremie Inactive Thread Starter
    I have tried to configure remote desktop to use a different port rather than the standard 3389,but nothing is working. I have changed it in the registry and on the router no luck.
    I am already using a computer on the standard port and I want to setup another computer on a separate port.
    how do I do ?
  2. 2011/08/09
    What version of Windows are you talking about?
    Jeremie
    WIN XP SP3 to WIN 7 Ultimate 32
  5. 2011/08/10
    Why do you want to change the port number? You can have more then one connection at a time both using 3389.
  6. 2011/08/10
    Jeremie
    I am remoting into a network that has 1 IP. From there the port forwarding is set to use port 3389 to one of the designated PCs. If i set both the PCs up on port 3389 theirs no way to determine which computer your going to remote into.
  7. 2011/08/11
    And did you also change the port on the computer you are connecting from?
  8. 2011/08/12
    Jeremie
    That seemed to do the trick. I changed the port on my router and did not change in my registry. Thanks for the help guys:D
